displaying posts 51 to 69 of 69
Pages (3): 1 2 [3]
Author Subject: Standard Brakes or Uprated?
jcooper776
Post #51
Shouldn't be hard around here, nothing on the road LOL
South West ish coast. Middle of nowhere Thumbs up
Sold my GTI-6 now riding in a Scooby
James
Posted 31st Mar 2010 at 03:28
oldbrownshoe
Post #52
some point to consider : if some of you going the big brake rout (meaning big rotors big calipers ) only in the front,you'll surprise to find that the stopping distance increased.
as for bedding , theres a recommendation to bed new pads with old disks
took it from http://mrtperformance.com.au/forums/archive/index.php/t-2.html
"Generally it is not recomended to bed new rotors and new pads together. The reason being that during the bedding process of the pads, excess resin from the pad material is expelled. Bedding the rotor is done to season the rotor material which relieves stresses and lines the rotor braking surface with a light even coating of resin material. Depending on the type of resin in a new pad this can be like pouring a jug of gravy onto the rotor surface and expecting it to be an even layer. DTV from resin wipe off is the result. The amount of DTV that can be generated is dependant on the type of pad. Sometimes its none and on other occasions brake shudder is totally unaceptable. When people say they have warped their rotors bedding in or in the first 1500 kms its generally resin wipe off"
French military victories?
Did you mean French military defeats?
Posted 2nd Apr 2010 at 14:30
jcooper776
Post #53
I'm not using big brakes just uprated pads.
And I'm not putting new pads on old discs. I have new discs going on as well.
But thanks.
James
Posted 3rd Apr 2010 at 03:42
jcooper776
Post #54
Fitted these new discs and pads today with the help of a couple of mates.
It was a long day LOL
Gladly the discs and pads were both the correct part number as I was slightly concerned about buying the wrong pads.
When comparing old discs to new though, the old ones were a fair bit smaller in size. Looks like XSI discs or something were on before for some reason. (Previous owner must have done it).
Had a bit of a nightmare doing the first side. Firstly, couldn't find a 17mm spanner LOL Found a motorbike spanner and improvised with that.
Main problem was clamping the piston to push it back. I bought a 100mm G clamp from halfrauds. For ages we were trying to clamp the edge of the piston ring. And it wasn't working because the clamp wasn't big enough.
We even went and bought a larger clamp, but only a plastic one. Which broke after about 30seconds!
Then we figured out we were all being dumb and we could fit the 100mm clamp inside the piston hole Doh
So after taking about 4 hours to do the first side LOL The other side only took about 20mins.
All good practice as I will know how to do it myself next time I suppose!
James
Posted 4th Apr 2010 at 03:02
stu
Post #55
Should have invested in one of these -
Makes things a lot easier. Yes
Sounds like you sorted it in the end though. Thumbs up
Posted 4th Apr 2010 at 02:59
oldbrownshoe
Post #56
just shove inside the piston an handle bar of small jack like this and push,
you'l have to release the nipple a bit.
it's simple ,effective ,fits perfectly in the bore and wan't harm the seal.
Posted 4th Apr 2010 at 04:28
jcooper776
Post #57
LOL yeah would have been. Halfrauds were trying to sell them for about
James
Posted 4th Apr 2010 at 04:29
oldbrownshoe
Post #58
it wan't move cause the fluid inside has nowhere to go, you had to release the nipple on the caliper letting it flow .
i never use other tool then that.
Posted 4th Apr 2010 at 04:32
jcooper776
Post #59
Didn't want to release the nipple as all the brake fluid would have come out. And I didn't have a bleed kit.
I just took the cap off the brake fluid reservoir in the engine bay and then used the clamp to push the piston back Smile
James
Posted 4th Apr 2010 at 04:42
stu
Post #60
Posted 4th Apr 2010 at 04:44
oldbrownshoe
Post #61
you got a friend ? he is your bleed kit.
just a bit of brake fluid will flow out, not all .
you can build bleed kit by you'r self ,
just need a jar and the right size tubing or
Dr frankenstein laboratory
Ninja
Posted 4th Apr 2010 at 04:51
jcooper776
Post #62
James
stu
Post #63
It's because the pistons wind in and out instead of just sliding back and fourth.
You can buy a special tool which will probably make things easier, however it can be done with a long screwdriver and lots of patients.
Have a read of Post #15 here. Thumbs up
Posted 4th Apr 2010 at 04:56
Post #64
jcooper776 wrote:
stu wrote:
Posted 4th Apr 2010 at 04:58
oldbrownshoe
Post #65
i just use large flat screwdriver and retract the piston inside by turning and pushing at the same time.
if you go and overhaul the caliper using the special grease it wan't stuck in the future anymore.
Posted 4th Apr 2010 at 04:59
Post #66
Me too, they screw in clockwise Smile
Posted 4th Apr 2010 at 05:01
jcooper776
Post #67
daveyboy wrote:
jcooper776 wrote:
stu wrote:
jcooper776 wrote:
Halfrauds were trying to sell them for about £30 though. I wasn't going to pay their rip off price on principal..
I got mine cheap off eBay, worth keeping an eye out for one if your planning on doing more brakes in the future.
Yeah might get one. Seen some for about £10 which is more reasonable.
Another one is needed for the rear brakes as well isn't it? A reverse one.
And apparently rears are harder to do? Is that due to something about the handbrake cables?
You might want to invest in a Haynes manual at the same time, or at least research upcoming tasks in the FAQ section Wink
I did.
I even printed off the brake pad change faq and took it with me.
Doesn't really help when you haven't done it before and have no idea what you are doing though. Wink
It's all good practice, I will be able to do it at lightning speed next time LOL
After changing them I have noticed a vibration or judder through the steering wheel. But it only happens at 60+ mph and only when accelerating. Any ideas?
James
Posted 5th Apr 2010 at 03:38
oldbrownshoe
Post #68
You probably clipped off one of the wheel balancing weight that taped inside the wheel.
happen to me too, when i convert the ZX reflex little brakes to Berlingo's ones
it was touching the wheel that i had to grind the
caliper.
Posted 5th Apr 2010 at 10:13
jcooper776
Post #69
Sorted now. I hadn't put the locking wheel nuts back in as when changing the pads, I didn't have the key with me.
They easily came out with a 21mm socket mind. Shows how useful locking wheel nuts are!
They are back in now and the vibration has gone Smile
James
Posted 5th Apr 2010 at 20:57
Pages (3): 1 2 [3]
