displaying posts 1 to 25 of 43
Author Subject: D2 racing coilovers
mxcrazy
Having a look around for suspension, decided that the Spax RSX kit i had wasnt what i wanted for my track car.
I have been looking at the D2 racing coilovers, havnt found anything Peugeot using them as of yet, but they seem to be regarded quite highly with JAP car owners, the earlier ones seemed to have a few problems with leakage, but that seems to have been resolved.
It seems that they would come with adjustable top mounts too.
clicky
Posted 2nd Mar 2010 at 23:57
jap coilovers=spine breakers!
typically that is, not a clue on these.
Posted 2nd Mar 2010 at 23:20
mxcrazy
They seem to get quite a good review on the 'ride' side of things, with spring pre-load and height adjust-ability separate. Mine would be for a track only car so it doesnt matter to me too much anyway.
Posted 2nd Mar 2010 at 23:59
lotek
jap coilovers seem to send jap cars into barriers at every trackday ive been to Shut up
Posted 3rd Mar 2010 at 00:45
mxcrazy
Is that limited to the JAP cars with coilovers, or any Jap car? The Peugeot handles in the first place remember. LOL
Posted 3rd Mar 2010 at 03:11
Jap roads and tracks are billiard table smooth, and as such their suspension kits tend to be very hard to maximise grip on those types of surfaces, this does'nt translate to good grip on our bumpy roads at all. And high kerbs and rumble strips on track will upset cars that are set up too hard as well. Best not be a guinea pig for these and find out the hard way that they don't work for you. Best to get in touch with the manufacturers and ask if they can put you in touch with a satisfied customer or two who are using them as you intend to and preferably in the same model of car.
Posted 3rd Mar 2010 at 03:18
mxcrazy
I think that is maybe where the problem lays though. They are adjustable, and different spring rates available like most coilovers, im sure the valving will be changable too if needed.
The good thing with them is the separate height adjustment and spring pre-load, you can have the car with a low stance but still with travel.
Posted 3rd Mar 2010 at 03:31
Which is a good thing, unless you forget that it's then possible to make your wheel arch part of the bump travel LOL
Posted 3rd Mar 2010 at 03:33
mxcrazy
Ofcourse, there is a compromise i understand that, some coilovers if set 'too' low will be prone to bottoming though. I know the 306 doesnt want to be too low for handling purposes anyway.
Posted 3rd Mar 2010 at 03:41
How much are they?
Posted 3rd Mar 2010 at 13:47
orso
Here in Bulgaria they are about 900 euros. Another taiwanian coilovers XYZ (very similar to D2) are about 850.
Posted 3rd Mar 2010 at 14:17
AST money Smile
Posted 3rd Mar 2010 at 15:55
mxcrazy
Posted 3rd Mar 2010 at 17:32
Can find a car with them on so you can actually try them out? I'd be concerned about spending that much on something I have no experience. Thats just me though and obviously no one would sell anything if everyone was the same!
Any particular reason to go for these over something like a Bilstein 205 Group A coilover setup? Or alternatively find some second hand 205 AST/proflex etc etc. They do fit Smile
Posted 3rd Mar 2010 at 17:54
mxcrazy
As said before it is a risk to be the first one to try them. there is no reason to chose these over anything else, its just finding something like the Bilsteins or ASt's etc second hand.
At
Posted 3rd Mar 2010 at 18:01
mxcrazy
Im trying to crack a deal with the guy to get a set of these possibly and try them on my road car, thats then a real world tester for the kit. There are a couple of decent b-roads round my way i can give them a fairly decent going over on, and some decent smooth roads too. There are different spring rates to chose from when supplied, ill also have to get my dad to drive the car, he does more miles than me and has driven many a different type and spec of car over the years on the same route to work at Quaife.
I would then, if it goes ahead, come back to you guys with a report on them.
In the guys words 'there is no reason why these would be any harsher, and or stiff than anything else out there', its spring rate that determines that, and damping that controls the speed of movement, and that is adjustable.
Bearing in mind that adjustable top mounts are what,
Posted 9th Mar 2010 at 19:58
What rate springs would you go for on a road car then?
Posted 9th Mar 2010 at 20:18
mxcrazy
That was going to be my next question too, ive got some 21mm tb's to go in the rear, and a hybrid ARB so would like some advice if anyone has any? LOL
Posted 9th Mar 2010 at 21:32
I'm using standard rear TBs, hybrid rear ARB and 285lb front springs. Nice compliant ride for the road. The awesome damping helps as well Big grin
Posted 10th Mar 2010 at 02:31
mxcrazy
I had a good look around and was thinking in the 250-300lb mark for the road.
They do a 5kg/mm spring which is, if im not mistaken 280lb/in.
I think im just going to order a set, nuts to it, im not sitting around waiting for someone else to do it LOL just got to sort the final details out, double check a few things.
Posted 10th Mar 2010 at 03:43
mxcrazy
Update on this slightly, i did order a set and they should be here in the next week or so, so i will get them fitted not too long after, though they will be combined with solid beam mounts, rich's wishbone bushes, 21mm tb's, rose jointed drop links, Hybrid ARB.
Posted 13th Apr 2010 at 23:55
Cool, be interested to see what you think of them. Could be quite a weapon you have there with all that kit on it Ninja
Posted 15th Apr 2010 at 14:28
mxcrazy
Will be a bit unfair to be honest to bolt all that on at the same time regarding comparisons though. No doubt it will be far better than my worn out OEM stuff.
It should be even more of a weapon if i end up building this 2335cc N/A lump for it. Whistle
Posted 16th Apr 2010 at 00:16
Very true, was hard for me to do a direct comparison as it took about 3 months to get the kit sorted out. You know when its working properly though.
Posted 17th Apr 2010 at 14:55
denwar
just get them horsed on....
denwar
Posted 21st Apr 2010 at 23:28
