displaying posts 51 to 75 of 93
Pages (4): first .. 2 [3] 4
Author Subject: just thinking about N/A engine mods
jcphat
Post #51
dented_vts wrote:
There is no n/a production engine at any price that makes more than 120ish bhp per litre.
My Triumph makes 108 bhp from 675cc, isn't that 160 per litre?
It does rev a bit but for
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 10th Mar 2010 at 03:04
dented_vts
Post #52
mxcrazy wrote:
getting a bit off topic lads, but just thought id chime in with the vtec lump in the honda s2000, 237bhp @ 7800rpm stock.
exactly that makes peak torque of 162ftlb...at 6.5k
Posted 10th Mar 2010 at 03:05
mxcrazy
Post #53
gti-dan wrote:
right - i was getting confused reading all the different threads and was unable to get conclusive information on all the dimensions of all the various components of the millions of XU engines there have been! Some conrods would be the right lenght but big end too small, some blocks were bettr to be bored out, some cranks needed differnt rods but standard pistons etc etc...so i thought a phone call to qep was in order - spoke to matt who confirmed what i wanted to here - getting a 6 engine is a great basis as both the block and head are what i want for the build im aiming for. So just collecting parts. MXCrazy - i look forward to hearing how your build progresses because we have faily similar plans by the sound of things. I am also going to collect all the parts first - do as much as i can myself but use a proper engine builder for some of it. So shopping list now - 92mm crank, 6 engine thats had a cambelt failure (might just use my 6 engine, cams - not going to rush into this will prob be last thing i buy when i know more about them and I know what characteristics i want from the engine - may go for PeterT regrinds, bearings, Jenveys and engine management - what is going to be the best system? emerald? megasquirt? i know nothing about either. What is mega spark too???
DrSarty's build thread is very inspiring - as you read it you can see the learning curve he went through when building each part of it - It would be great to get anywhere near where he got with his build.
So what are you going for? 92 x 87mm?
Im using one of Colin Satchell/Sandy Browns gsxr1000 throttle body set ups, it has a nice long intake tract, 44mm bodies.
Ill be using an emerald ECU too, wideband lambda sensor for initial set up etc.
The Newman PH2 cams have been recommended to me as a good spec for this type of engine, not too much lift to warrant different springs and head/oil spray bar mods, and not too much duration that the engine requires revving (bit of a generalisation there) to get power.
Posted 10th Mar 2010 at 03:07
dented_vts
Post #54
dented_vts
Post #55
Posted 10th Mar 2010 at 03:10
mxcrazy
Post #56
ahh the other thing would also ideally be an exhaust manifold made to suit the characteristics of the engine, this cold be the difference between 220 and 240 bhp.
Posted 10th Mar 2010 at 03:58
Post #57
There are dozens I can think of that make 160-220bhp per litre, an S1000RR can peak past 90lbft/litre with just a bolt on exhaust system, and it'll hold 80% of that over a 6000rpm spread....
And that's a production road engine.
Posted 11th Mar 2010 at 06:57
Post #58
dented_vts wrote:
but if you rework the head and re-cut the valve seats you would have to re-profile and match up the valves anyway, so they would not be "standard" any-more anyway Crazy
Hardly in the same realms as a reshaped and oversized valve and seats is it?
Posted 11th Mar 2010 at 06:59
gti-dan
Post #59
hi mxcrazy, yes going to go for 92 x 87. Just picking up pieces now and information. I want to keep costs down but at the same time if you know you are going to be spending a fair bit you dont want to save money anywhere where it counts!
I may go for the colin satchell bike bodies - i find them more "interesting" than jenveys but I think i have read recently that jenveys are better that using bike bodies? that will be one of the last things i buy though. Same with mapping as i need to find a quality mapper up north somewhere.
I also want to do as much of this build myself so i can learn about all the various bits but again - will leave the really technical stuff to the guys who know what they're doing!
I need to read up on cams don't want anything with too long a duration as i want drivability and wide power band. I like torqey engines and want a strong pull through the revs.
On the head going to go for 3 valve seat, will un shroud the valves. If I can be convinced to go for larger valves i will. I know everyone says don't but if there is much to be gained I might do.
Lastly exhaust is a biggy - who and how do they get the pulse right for that particular engine? I'd imagine a fair bit of trial and error and bespoke fitting and testing....i.e. a lot of money!
In the mean time i may strip out the 6 - if you could get anywhere near 230 bhp and 1000 kg - that would make for a very quick car!!!!
mxcrazy - when do you think you will have your engine complete?
Posted 12th Mar 2010 at 01:45
mxcrazy
Post #60
Regarding bike bodies, at the end of the day all it is is a bit of metal with a butterfly in it, no reason one should be better of worse than the other. The normal reason bike bodies dont work is because they are spaced badly, held with rubber connectors and dont use trumpets, ie, shit!!
Colins set up uses a nice long smooth intake manifold, and decent sized and shaped trumpets.
Cams wise as i say im looking at the newman PH2 spec, there is no reason not to use of of petert's cams, DrSarty has had great power with his.
Up to you with the big valves, but its soo much money to get done right, alot of places could fit big valves for you, but finding someone to 'work' the head to make use of them will cost a bomb. The seats are 3 angle as stock, but can be improved on.
Im not aiming for any particular figure with mine, above 220bhp and as close to 200ft lb torque as i can will be nice, but, without seeing over 7250 ish rpm limiter, ie, stock.
Manifold wise, im thinking now and having done a fair amount of research that the shape and length of it will work well with this spec engine, ie, similar power placement, just more of it. Its the primary diameter that seems to be the restriction over 230bhp.
Id like to have a manifold made, to resemble the stocker but with larger primaries and feed into a minimum of a 2.¼ inch system, peter taylor suggested somewhere that anything over 220bhp would be ok with 2.5 inch.
To spec a manifold seems quite involved, rpms, bore, stroke, cam specs, port sizes etc etc.
I think ill try and keep it simple on mine, have a stock manifold copied maybe with larger primaries, failing that something like an equal length maniflow thats not designed for a BTCC car.
Posted 12th Mar 2010 at 02:02
dj_turbo
Post #61
Personaly i think hunting for numbers is pointless it doesnt show the bigger picture a spread of good power and torque is what you should aim for as it will make for a much more driveable engine changing form my old to sandys engine was a massive improvement yes its got more power but its the way it delivers it that makes it worth every penny. sandy goes to great lengths to make all the components work well together this is vital to get the most from a build.
Posted 12th Mar 2010 at 02:20
jcphat
Post #62
Team Zimmer™
Posted 12th Mar 2010 at 02:21
mxcrazy
Post #63
Ofcourse, this is what i am aiming for, to get the numbers i refered to from an engine that doesnt rev to 9000rpm should in theory make it a useable lump.
Have you read the DrSarty build thread on 205gtidrivers? he has hit 230bhp and lots of torques, with a good spread of power with a re-profiled inlet cam, bodies etc, but he doesnt have to rev the engine.
My build may well be a little more revvy than a 92mm stroke lump, but i am keeping it a square bore/stroke ratio as per stock, just a bigger displacement. My choice of cam may well bring the power up a little higher in the rev range, but not excessively.
EDIT, just to add i have conferred with Sandy about a few elements of my build and he has guided me some what to my choices. Wink
Posted 12th Mar 2010 at 02:39
mxcrazy
Post #64
Whilst im here i may aswell also add, going with a big valve head is even more un-necessary on an engine thats not going to be revved high, if your aim is to make a lot of horsepower at higher RPM's the bigger valves and ports 'may' help you on the way to high figures, probably at the sacrifice of more bottom end power.
With these bigger bore, longer stroke, not as high revving engines the increase in displacement makes the head work better than in a 1998cc lump.
Picture this, you have a running open ended garden hose, now cover half the end with your thumb, we've all done it. What happens? that water is now travelling alot faster! its not all about massive ports and valves, its about flow and intake charge velocity.
One engine i have had a lot of dealings with is the Honda CRF250 motocross engine, when it first came out in 2004 the ports were huge, gaping great round things, 2005 model came out, slightly smaller ports, flat bottomed slightly = more power and torque, 2006 came, even smaller ports, even flatter bottomed = even more power and torque again, the same valve sizes where used, the same carb and basically the same cam, though this engine revved to 13.5k it had useable power from about 5k up to the limiter, my particular bike was 'breathed' on (a head clean up, 14:1 compression, stock cam re-timed, advanced ignition by 4 degrees, full exhaust system, and a carb size reducer, from 40mm to 37mm), it made max BHP (worked out to be around 28% increase over stock power of a 30 something bhp race engine) at 11.5k and dropped one bhp all the way to 13.5k, it made max torque at 9.5k, but the torque curve was really quite smooth and flat before peak for an engine like this and didnt drop off like a stock engine did.
It was an incredibly usable engine, i raced it against 450 4 strokes and 250 2 strokes with reasonable success, mainly because it was easy to ride, most 250 four stroke motocross engines you have to keep on the boil, miss a gear and they will bog out, mine was like trundle the tractor compared to most others.
Its a bit off on a tangent, but most people bolt an exhaust system on their mx bikes and start chasing BHP numbers, i was different, i was chasing usability and torques, and a by product of that was BHP.
Posted 12th Mar 2010 at 03:04
sandy
Post #65
Interesting discussion Smile
Those that think 90+ lbft/litre from a race engine isn't possible, aren't up to speed. The Aussie V8 cars are getting almost 100lbft/litre from 2-valve heads! Formula one is a distraction, they aim for lower VE at higher rpm than most other disciplines.
Posted 13th Mar 2010 at 13:03
cosmic spanner
Moral objector
Post #66
dented_vts is the new Mr. Whippy and I claim my
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 13th Mar 2010 at 21:01
vts_tibi
Post #67
as far as I know such port shape downsizing had happened to the GSXR too (it can be a different bike tho., I'm not really confident in this one)
taking this into consideration when talking about throttle bodies, these may be interesting:
Active Technologies shaftless throttle bodies
40mm throttle bodies - "It is to be used in applications where a conventional 45mm DCOE Throttle Body would be used."
that's 5mm diameter difference
VTS
best 60' : 2.272
Team Trackday™
Posted 14th Mar 2010 at 00:27
dented_vts
Post #68
My comment was regarding that level of torque AT 9k rpm on standard size valves- ie those levels of torque on a 4pot 2 litre. That is quite different from that level of torque at say 5k. And different from engines with significantly different cylinder capacities. Formula one is the pinnacle in engine design- the problem is you just can't hit those rpm's with vavles operated by springs. 900bhp+ from 2.4litres and just look at the massive inlet valve area vs. capacity. they use 10 cylinders not 4 for a reason. The current Formula one engines could make significantly more power if they were not rev limited by regulation.
Agreed from a full race build 2ltr 4 pot such figures are possible as up to 130% volumetric efficiency PEAK has been shown to be achieved with pulse tuned set ups- but how many ft/lbs does that equate to? Inducting air at 30% more than atmospheric pressure is quite an achievement
There was a famous E30 M3 engine that was said to make about 300bhp that revved to about 10300 i think- anyone got any details as the inlet and exhaust diameters and tube lengths may be of interest here. I'll search my machine, think it was by a German tuning company.
Posted 14th Mar 2010 at 00:57
dented_vts
Post #69
That didn't quite sound right- Sandy i know you know that already etc. Read some of your posts the other day regarding suspension setups with interest, great posts. I was thinking about having some dampers made up but don't want to spend much so was thinking of using the readily available Eibach springs- what damping rate would you recommend with those?
Has anyone on here any experience with the Puma Race Engines throttle bodies that were available for short while? I saw a set, but never saw any before and after power measurements to see how effective they were. I'm considering tracking down a set.
Posted 14th Mar 2010 at 01:06
dented_vts
Post #70
Very interesting- did you conclude that the port shaping was creating unwanted turbulence and hence hampering flow? I made a mistake which was kinda related- fitted near standard cams to a head that had been ported to optimise flow at very high lift ( at the time i had little experience and thought if it was ported it was optimal for all cams!). Didn't perform well at all- not much over a standard head. Friend bought it, fitted it with massive cams and wow, huge difference.
Posted 14th Mar 2010 at 01:12
dented_vts
Post #71
I suppose another example of bigger isn't better is the old Golf mk.2 16v engine- people often said the earlier cars were faster. I drove some and they did actually appear faster. Eventually I noticed the early cars had 42mm inlets but the later cars had 50mm. 50mm gave more power at the red line but it just wasn't usable with standard rev limit IMHO, and hence the 42mm with better torque at 5k was the quicker engine.
Posted 14th Mar 2010 at 01:20
mxcrazy
Post #72
It was Hondas doing, every year it made better power and the main thing to change was the port shape and size. I think it works just as i described crudely, mixture speed/velocity was much improved, probably a better mix of air and fuel and better cylinder filling.
Posted 15th Mar 2010 at 01:43
sarthe82
Post #73
They're V8's not V10's and have been for a number of seasons, they are indeed rev restricted....to 18,000, rather a lot. That is all. Wave
Steve Big grin
Posted 15th Mar 2010 at 08:29
sandy
Post #74
Our engines tend to be around 90lbft/litre at peak power. If you can get a good spread of efficiency, there isn't the need for revs in most cases.
I've only seen the Pumaracing TBs on Kate Osbourne's 205. They were always falling apart. Maybe the ravages of time, but not ideal.
The AT-Power bodies are being pushed hard by suppliers on many forums. Clearly the look well made and finished, but be cautious about zealous sales pitch regarding their design. The have not re-invented the wheel as far as I can see. The closest comparison I've seen has been between a 1.6 16v Saxo running the ATP direct to head bodies and Catcam "708s" and a 106 1.6 16v (it's the same engine), also on "708"s, but with our GSXR1000 based TB kit. Just to be clear, both these cars were tested on newly installed Supeflow rolling roads and I had no involvement:
ATP Bodies Saxo:
GSXR kit 106:
Overlay:
Posted 15th Mar 2010 at 12:57
dented_vts
Post #75
ATP Bodies Saxo:
GSXR kit 106:
Overlay:
Thanks for that very informative post. The bodies you fit look significantly better on that engine, and same power at lower engine speed (or more in your case) should lead to better reliability? No point making the power if you brake down over the finishing straight.
Interesting comments re the Puma bodies- i only have experience with the guys head work.
Posted 15th Mar 2010 at 18:47
