displaying posts 376 to 400 of 549
Pages (22): first .. 15 [16] 17 .. last
Author Subject: andys reborn 6
Post #376
Where are you going for the dyno?
Posted 6th Jul 2012 at 12:08
Post #377
Jim recommended me a place out chesterfield way, it's just for a power run then we know what we're starting with power wise and I know it's all perfect and ready to rock.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 6th Jul 2012 at 12:14
Post #378
Nobles?
Post #379
It might be, I can't remember LOL
Posted 6th Jul 2012 at 12:19
fletch
Track Head
Post #380
Give us a shout if you fancy a drive out sometime, looks like im local to you, would like to see what shes capable of Smile
Posted 6th Jul 2012 at 14:52
Post #381
Yes I will do fletch, infact everyone's waiting and I've been too busy at work to do s**t
Posted 6th Jul 2012 at 15:12
fletch
Track Head
Post #382
Cool, let us know if the dyno is 4WD as well as I fancy getting a run, cheers
Posted 6th Jul 2012 at 15:44
Post #383
I know where there is a 4x4 road around here, where are you mate?
P m me
If you want.
Posted 6th Jul 2012 at 17:24
pugjim
Post #384
phillipm wrote:
Nobles?
No i hear that nobles has gone down hill recently. The place is called power developments near clowne. I have had 2 205's mapped there and phil who owns the place is a DTA specialist.
Posted 6th Jul 2012 at 19:13
Post #385
^^Definately!
Posted 6th Jul 2012 at 19:42
Post #386
Brakes fitted:
I can't help but think I've got an issue with my charger, it is always leaking oil from the canister breather cap, even if it was overfilled it would of found its own level a long time ago by now and wouldn't still be leaking it out as though it was overfilled.
I was told if there was an issue with the oil supply it would of seized a long time ago, but I hardly use it and it's getting noisyer each time i start it from cold, sounds like a pulley bearing is f**ked but they havnt done much mileage and it goes away he warm, it could be the belt sticking to a roller but my low boost one did that and it sounded more of a squeak than anything and it went when I cleaned the rollers.
Here is what the pulley area sounds like from cold:
And here 5-10 mins later when the noise has subsided to its lowest:
Posted 15th Jul 2012 at 21:13
Post #387
I have no idea if the vids above are working, looks like there not from my phone.
Posted 15th Jul 2012 at 21:27
Post #388
http://i403.photobucket.com/albums/pp115/andygti6/fadadfc0.mp4
http://i403.photobucket.com/albums/pp115/andygti6/9d6af41a.mp4
Posted 15th Jul 2012 at 22:24
Post #389
Brakes look goodThumbs up
That noise is not niceNo
That one pulley looks very close to inner wing too,I would be keeping an eye on that after a track day/good blast etc,engines move about more than you think under heavy cornering/high torque through themWink
Posted 16th Jul 2012 at 11:33
Post #390
There 8 rib pulleys mate not the usual 6 rib, that's why it looks closer than usual, because it's wider.
Posted 16th Jul 2012 at 12:14
pugjim
Post #391
This is true, i have seen it on a 205 MI16, never on a 306 though.
Posted 16th Jul 2012 at 13:01
Post #392
Live update from the last ten minutes:
So 2 rollers have seized up and snapped the belt, I'm kinda glad because now I know why I think the power was zapped, it had nothing low down compared to before and felt lethargic high up to me.
This is why, it will have been using a good lump of power just to turn the belt I reckon.
And the towing eye seems to have done a excellent job, I'll check it behind tmmrw but I'm confident it's solid and better than the standard one if anything.
it was weird how it panned out, there was a rope next to where it broke down, it snapped 300 yards down the road.
As i got out the car after it snapping a guy in a green discovery pulled up, threw one of those stretchy proper towing ropes, then drove off, I didn't even get chance to say thanks, before I knew what he'd done, he'd gone. Awsome guy, goes round doing good deeds and doesn't even want thanking, he has restored my faith in the human kind.
All in all, broke down 4 miles from home an was back in ten mins thanks to disco guy and my jock freind from work.
Posted 16th Jul 2012 at 20:44
Post #393
hopefully when the map sensor wire snapped off it cut the engine before any cambelt damage.
Posted 16th Jul 2012 at 21:00
pugjim
Post #394
It's cursed that car sell it :-)
Posted 16th Jul 2012 at 21:01
Post #395
You want to buy it?
Posted 16th Jul 2012 at 21:17
Post #396
Oh dearThumbs down
Fingers crossed there is no further damage.
How many miles have the pulleys done?Shock
It happened to a Gti6 powered 309 at Pugfest couple of years ago,going up the hillThumbs down
Plenty of room between pulley and chassis when the car was sat still,but you could see the mark on the chassis where it had shifted over and touchedYes
Chucked the aux belt which then took out the cambeltSad
Post #397
All the pulleys are free, alternator and p/s is also free.
It hasn't touched the bulkhead there's no marks there anyway, I was also going steady when it happened, if all the pulled are free why was it making that noise before, hopefully the noise was a knackerd belt.
Posted 16th Jul 2012 at 21:20
pugjim
Post #398
im pretty sure the noise it was making was the belt slipping rather than a pulley making the noise.
Posted 16th Jul 2012 at 21:48
mabgti
NV motors
Post #399
belt alignment is critical.. a few degrees out and you have sheared rubber. I use a weighted string wrapped around the pulley to determine belt alignment.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 16th Jul 2012 at 21:50
Post #400
when it happened, I was in a 30 going really steady, it sounded like I was driving through a load of grit, I then realise there was an issue put it in neutral and rolled around a junctIon, I stopped and went to turn her off, she cut out as my hand was just about on the key, I think or hope this was the point where it pulled the map sensor wiring snapping it in half and cutting the engine.
Cambelt off tmmrw to check timing eg, maybe a new cambelt would be a good idea aswell.
I'm tempted to send the charger off to be tested/checked over by rotrex.
how do you go about aligning the belt? I thought the pulleys was either on or off?
Posted 16th Jul 2012 at 22:06
