displaying posts 26 to 50 of 73
Pages (3): 1 [2] 3
Author Subject: A bit disappointed!
rallyestyle
It will be your intercooler and piping thats holding you back craig Yes
Are you using the generic low boost map? That was from Zac's orginal low boost which had the larger cooler setup.
Chris (Farmer) has/had the same IC setup and was running around the same as you. I have some printouts of mine, i will post them up Yes
Just Drive It
Posted 24th Feb 2010 at 20:09
rallyestyle
Just Drive It
Posted 24th Feb 2010 at 20:12
smegal
Mine's running a bit leaner Richer than yours at higher Revs too. Hmm
Ex SC-6
Now in a Megane R26
Posted 24th Feb 2010 at 20:33
rallyestyle
smegal wrote:
Mine's running a bit leaner than yours at higher Revs too. Hmm
Yes
I basically set up my rallye to mimic Zac's car, his produced around the 260bhp mark with the map and i managed to get pretty close to that. Am getting it on the rollers again in a few weeks as for all we know the ones i used may be out, was odd though as everyone else on the day seemed to be down on power!
Just Drive It
Posted 24th Feb 2010 at 20:24
smegal
I like how yours was also on a dyno dynamics roller. What PSI is yours boosting?
Ex SC-6
Now in a Megane R26
Posted 24th Feb 2010 at 20:26
Yours is at 12.5:1 AFR, Rallyestyle is at 13:1 to 13.5:1 AFR, no?
Ergo, yours is richer Ninja
Posted 24th Feb 2010 at 20:30
smegal
Sorry I was confused about the reading.
Ex SC-6
Now in a Megane R26
Posted 24th Feb 2010 at 20:32
rallyestyle
Is that how it works Doh Laugh
Just Drive It
rallyestyle
Roughly 7psi mate Yes
Just Drive It
smegal
Post #35
That's the same as mine so that isn't an issue.
Ex SC-6
Now in a Megane R26
Posted 24th Feb 2010 at 20:35
rallyestyle
Post #36
Its the intercooler and piping Yes
Just Drive It
Posted 24th Feb 2010 at 20:49
smegal
Post #37
When Zacs was first mapped back in the day though it had this [actual] IC, although my pipe bends are welded which will be restrictive.
Ex SC-6
Now in a Megane R26
Posted 24th Feb 2010 at 20:52
Post #38
Well, if it's on the same map, and it's running richer at high rpms, then it's definately pointing to not getting as much air in...
Posted 24th Feb 2010 at 20:56
rallyestyle
Post #39
I think its the latter map he had done though with the bigger IC Yes
Just Drive It
Posted 24th Feb 2010 at 20:58
rallyestyle
Post #40
yep, more air = more power Devil
Just Drive It
Posted 24th Feb 2010 at 20:59
smegal
Post #41
Can I just Dremel the f*ck out of my restriction ring or am I risking DET too much?
Ex SC-6
Now in a Megane R26
Posted 24th Feb 2010 at 21:00
rallyestyle
Post #42
That would be the last thing i would do Yes
Have a word with rich to find out the map you have, if its for the bigger IC then it might be worth getting it remapped. Given the cost of that though it may well be cheaper to upgrade to a bigger IC Yes
Just Drive It
Posted 24th Feb 2010 at 21:04
Post #43
It'd get you the airflow but there would be more heat in the intake charge, so I'd speak to Rich about that first!
Posted 24th Feb 2010 at 21:05
rich_w
Post #44
Craig,
You should see more than 7 PSI boost - you should see about 9 PSI.
This could easily equate for the power loss.
I think the issue could well be cam timing.
Your car has an extremeley poor idle, possibly caused by lack of manifold vacuum / too much cam overlap. I mentioned this to you when you collected the car Smile
With too much overlap, some of the boost will go straight down the exhaust, rather than pressurize the combustion chamber and inlet plenum, hence the low reading on the dyno's boost gauge.
It's definitely worth checking and tweaking the cam timimg on the dyno Yes
The problem won't be the intercooler - plenty are using the Forge intercooler and getting 240-260 BHP which is the target power for the conversion.
Also check what size the restrictor is before the supercharger - let me know what it is.
Regards,
Rich.
Contact Details:
07732 822546
Posted 24th Feb 2010 at 22:00
allesclar
Post #45
couldnt it be the case that the car could be over fuelling, rather than not getting enough air? Dunno
Team allesclar ®
Posted 24th Feb 2010 at 22:05
rich_w
Post #46
It's unlikely, there's less to go wrong on the fuel side of things.
Craig supplied all the parts, including the injectors etc. I don't know but I assume they are new.
Smile
Contact Details:
07732 822546
Posted 25th Feb 2010 at 01:46
smegal
Post #47
The injectors are Zac's old ones from a proven car so they should be ok. I'll look into the boost ring but 27mm is ringing a bell, although I could well of dreamt that number.
Where would be the best place to get the cam timing looked at?
Ex SC-6
Now in a Megane R26
Posted 25th Feb 2010 at 02:04
Post #48
Smile
what injectors did you supply me mate? they say ford on them lol
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Feb 2010 at 02:33
smegal
Post #49
They are the correct ones.
Ex SC-6
Now in a Megane R26
Posted 25th Feb 2010 at 02:35
simonjames
Post #50
Smile
there from a 1.4 fiesta from out the back of workshop
MY EBAY ITEMS
07943066306
Posted 25th Feb 2010 at 02:38
Pages (3): 1 [2] 3
