displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: Which shocks for lowered rear suspension?
idnan
Hello all,
the rear suspension on my 306 is lowered 30mm and is currently on cheapo motor factor shocks. As a result the rear end feels saggy and soft. I'm guessing this is mainly down to the torsion bars but would using uprated shocks help?
The options are the standard K6 shocks from Pug, or some uprated similar price ones such as Gaz GTs, Apex, Koni, Avo shocks etc. Which would be better?
Posted 26th Jan 2010 at 21:41
greenbelt
I asked Rich about this last week and he said the standard k6 shocks from pug are more than up to the job Thumbs up
Standard Black 6
Black HBSC6 Smoke
Posted 26th Jan 2010 at 21:47
idnan
Cheers, will get a set when I have some money available.
Posted 27th Jan 2010 at 20:31
jonnie205
some good secondhand ones are the way to go
Posted 27th Jan 2010 at 21:05
idnan
haha the lowered beam was from you anyway Razz
I'm splashing out for solid rear beam mounts and other stuff so I suppose new shocks aren't too expensive from Pug especially if I can get a discount.
Posted 27th Jan 2010 at 23:04
china_306 Banned!
lol just answered my question! BUT there are two types of standard rear shocks avalible, my other question was "oil" filled or "gas" shocks? btw my 306 is lowered by 40MM Smile thanks in advance guys! r they hard to fit or is it somthing i could do myself, have limited tools tbh....
Posted 28th Jan 2010 at 06:23
You want the gas ones if you're going for Bilstiens, the oil ones are a very old twin tube design on low gas pressure, they don't generate enough low speed damping.
Posted 28th Jan 2010 at 06:37
if you7 are going for the Black Bilsteins get the ones for the ZX Smile
Posted 28th Jan 2010 at 14:50
idnan
Have you got a part number for the ZX shocks? How do they compare to the oem 3606K6 shocks from Pug?
Posted 28th Jan 2010 at 17:16
slightly shorter bodied, was recommended them by Miles.
BNE-1932 is the code for them, just from the pictures on the Bilstein Webkat they look better than the slightly weedy BNE-1931
Posted 28th Jan 2010 at 17:51
idnan
Cheers, will get some from Euro Car Parts when I get the chance
Posted 28th Jan 2010 at 18:47
eddiebeano
Bump for this thread rather than starting a new one. I currently have cheap motor factor dampers on the rear, with 21mm tbs and kwv2s up front, both down around 35-40mm. Would I benefit from fitting a pair of 'PUG 205 COMPETITION CHALLENGE SPEC REAR BILSTIEN SHOCKS EACH PART NUMBER B461038' or would I be better changing to a hybrid arb first?
team: Stealth Ninja
Posted 8th Jul 2012 at 11:25
jord294
Personally, i'd try decent shocks first Thumbs up
Posted 8th Jul 2012 at 11:43
eddiebeano
Ok thanks, from experience what difference will different rear dampers make to the way the car handles?
team: Stealth Ninja
Posted 9th Jul 2012 at 10:37
I've heard those group n bilsteins are veryyyy stiff. Fine for a track I would assume, but probably not so much for any road thats not like a glassy surface Razz
Posted 9th Jul 2012 at 10:56
eddiebeano
I heard that too, they look pretty beefy compared to oems. I've got a saggy rear end tho. Well, compared to the front anyway!
team: Stealth Ninja
Posted 9th Jul 2012 at 11:11
they'll be fiiine Smile
Posted 9th Jul 2012 at 12:50
miles
I use them on allot of 05's & 06's, not too hard at all I think
www.pugracing.com
Posted 10th Jul 2012 at 01:25
davewagon
What sort of price are they please?
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 10th Jul 2012 at 19:54
Ok so i was hovering over the buy button for b8's remembered this thread and thought about these instead.
For the two they are only 60 quid more (260 quid)
Basically
the setup will be
b8s and eibach up front
No solid rubber replacement up front just standard bushes etc
Up back solid mounts
21mmtb
hybrid arb
and either these or the b8's
Obviously they are stiffer than b8's BUT if I use them on the road and travel 300 miles at a time will they do my head in?
Posted 27th Jul 2012 at 09:28
very much personal preference.
I have them though and can't fault them, and this is on a lighter and stiffer 205 (shorter 21mm torsion bars, so higher spring rate) it's the front damping I'm not so keen on.
Posted 27th Jul 2012 at 09:30
Tbh i think I am quite tolerant.
I.e I have driven a corsa vxr a fair bit and didnt find it stiff.
A lot of people would disagree.
I assume this means I should probably just get them Razz
Although my main worry is imbalance between front and rear as a result?
Posted 27th Jul 2012 at 09:33
better to be slightly stiffer at the back than too stiff on the front, they tend to understeer more if they're too stiff on the front and soft on the back.
Posted 27th Jul 2012 at 09:46
hmmm this is a tough decision... Will think it over for a bit.
Posted 27th Jul 2012 at 10:01
We are talking about these yes?
Seems like a billy bargain
http://www.ebay.co.uk/itm/PEUGEOT-205-CHALLENGE-SPEC-GROUP-N-REAR-BILSTEIN-/260896440620?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cbea3c12c
Posted 27th Jul 2012 at 10:12
Pages (3): [1] 2 3
