Author Subject: Volumetric Efficiency???
smegal
Anyone know what the Volumetric Efficiency for our engines is?
Ex SC-6
Now in a Megane R26
Posted 15th Jan 2010 at 23:03
Peak?
Posted 15th Jan 2010 at 23:10
smegal
Yeah please, I'm trying to fathom out how to use a turbocharger compressor map.
Ex SC-6
Now in a Megane R26
Posted 15th Jan 2010 at 23:12
I've never measured it accurately but IIRC it's just under 89% around peak torque.
Posted 16th Jan 2010 at 00:21
smegal
How do you measure it?
Ex SC-6
Now in a Megane R26
Posted 16th Jan 2010 at 00:23
You need the mass airflow and the BMFC figures.
Posted 16th Jan 2010 at 00:25
r*byb
89% is good really, most performance cars now run around 80% i believe.
Team Low Compression
Posted 16th Jan 2010 at 01:54
BMW M5 peaks about 110%...
Posted 16th Jan 2010 at 02:49
rich_w
Volumetric efficiency is the engines actual flow divided by the theoretical maximum flow.
As you say, 80% is a good figure to use for a modern performance engine.
If you're looking at Rotrex compressor maps - be very careful - they aren't particularly accurate. This is because Rotrex use maps straight from the compressor wheels they use in their 'chargers, which are generally derived from turbos by Holset, Garrett etc. Obviously, the same compressor wheel will vary in performance when used in a S/C compared to a turbo application.
Smile
Contact Details:
07732 822546
Posted 17th Jan 2010 at 03:52
smegal
I was looking at compressor maps for a turbocharger as a uni project. I did look at the rotrex map and was confused but I didn't give it a second thought.
Ex SC-6
Now in a Megane R26
Posted 17th Jan 2010 at 03:56
bobdylan_55
be careful about if you need peak or at redline or at max power etc, peak is often mid way up the rev range.
309 GTi6-T
Posted 17th Jan 2010 at 04:10
So it can't be more than 100% Dunno
Posted 17th Jan 2010 at 04:58
chris with a pug
it can if the theoretical
maximum is less than actual
Posted 17th Jan 2010 at 05:34
It can, google resonance supercharging Wink
Posted 17th Jan 2010 at 05:54
smegal
I'm using Steve's lecture notes and am finding the imperial calculations confusing. I was aiming for peak efficiency to be between 4-6k and am liking some form of Garrett gt2860 turbo.
Ex SC-6
Now in a Megane R26
Posted 17th Jan 2010 at 07:54
osm2121
Sorry to revive the thread, but didnt wanted to open an other.
Talking about resonance, this is only when the inlet has a plenum? Where the vibe rebounds back into the cyilinders in the plenum? Or with throttles bodies also matters? Cause if it doesnt have a plenum, theres no rebound back to the cylinder. I assume the shorter would be better to get rid of the resonance going out as soon as possible so it doesnt affect the air coming in. Although I´ve read in the forum, people said is the other way round, the larger the better, up to a limit. I think 370mm was said as the best measure for it, without going to a fine tune.
Im just talking without any studies or background, just wondering and wanting to know a ittle bit more about this
Posted 11th Nov 2014 at 20:52
jamiek_uk2000
Only Rich is still in this thread from the original post. The forum is flat out!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 11th Nov 2014 at 21:12
allanallen
The 370mm inlet runner length was a length derived by sandy brown to give the best torque curve IIRC. No idea what resonance was like at that length though.
Facebook
Posted 12th Nov 2014 at 22:35
pete_rallye
You don't need a plenum to benefit, but I have always thought it would help. Very basically the air waves that bounce of the back of the closed valves and resonate back up the inlet leave a vacuum behind them, as soon as they are out of the inlet and into open air, there is a rush of air back into the inlet to fill the vacuum, and the idea is you time this rush of air getting to the valves at the same time the valves are fully open. There is no real 'ideal' length. It depends on what cams you are using (as the valves will open at different times depending on the cams) and where you want you're power, you can alter the length to move the power up and down the rev range, although you may well see a jump in power at certain revs with a certain length.
This is how you get VE above 100% also, by using the ram effect to fill the cylinders.
Lap of the 'ring
Posted 12th Nov 2014 at 23:31
Puggitt
The ram effect? Able to elaborate?
Posted 12th Nov 2014 at 23:39
pete_rallye
I'm speculating here but I would expect VE to be calculated using air speed calculated from piston speed and port size and the associated air velocity, and not taking into account any effect of ramming the air in caused by the above explanation. So if you can design an engine to have as close a VE to 100% as possible, the 'ram' effect caused by the above would not be included in the calculation, and so when the engine is actually run, the VE at certain points in the rev range may exceed 100%....
Lap of the 'ring
Posted 14th Nov 2014 at 22:35
