displaying posts 76 to 100 of 267
Pages (11): first .. 3 [4] 5 .. last
Author Subject: Track Car Project Gti-6
Disco_Stu
Post #76
Rear beam time. I was dreading this point as I have heard lots of horror stories about the state some have been when taken apart. Luckily this rear beam was in very good condition inside (although a pig to get apart – bloody torsion bars!).
We have replaced the bearings and seals, give it a coat of paint (if you could not have guessed) and we are currently in the process of reassembly (at the minute this is a nice piece of furniture in the front room).
Need to get some solid rear mounts (looking to give you an order at some point daveyboy!) then it will be fitted back to the car – when this snow clears)
Sanded tube:
Painted:
Snow has caused a standstill like most of Britons roads!
Stuart
Peugeot 306 Gti-6 Track car (soon to be supercharged)
Project page
Blog
Posted 15th Jan 2010 at 00:22
farmer
Post #77
Looking good!
Did you change the rear ARB or the torsion bars at all?
Good to see another track car being done properly Smile
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 15th Jan 2010 at 16:42
clen666
Post #78
Did you fit the bearings yourself or get somewhere to do it?
Team 'unintentional rat look'
Posted 15th Jan 2010 at 17:14
Disco_Stu
Post #79
farmer wrote:
Looking good!
No we have left the standard ARB and torsion bars.
Project page
Blog
Posted 16th Jan 2010 at 19:59
Disco_Stu
Post #80
Hi, we replaced the bearings ourselves - make a bearning puller with some threaded bar and large sockets (+ plenty of grease). Was quite easy work in the end.
Project page
Blog
Posted 16th Jan 2010 at 20:01
nick!
Post #81
Nice thread mate. Wish I could clean up every part of mine as well but I use it everyday so wont get the chance unless i buy a banger to run for a month or so!
Cherry Red Rallye - 179.1bhp@fly, 148.4bhp@wheels
Posted 16th Jan 2010 at 20:08
clen666
Post #82
Hmm, I have a feeling I may not find it as easy, expect a thread full of swearing soon LOL
Posted 16th Jan 2010 at 20:48
Disco_Stu
Post #83
Waiting for some parts for the rear beam so we started to look at engine bay wiring yesterday & today. We were planning to do battle on the ABS wiring (we have removed ABS from the car). We spent hours finding the ABS wiring diagrams and marking wires to cut, only to find that the ABS wires are on a separate wiring harness
Project page
Blog
Posted 16th Jan 2010 at 21:11
Disco_Stu
Post #84
Whilst we are waiting for some bits to finish the rear beam we turned our attention to the gearbox. Firstly we repaired the small leak on the speedometer housing (new seals). The in true spirit of our build we cleaned the gearbox and painted it!
The gearbox to start with:
After a bit of elbow grease:
A few coats of black heat proof paint:
And a few red bits added:
Stuart
Project page
Blog
Posted 24th Jan 2010 at 19:49
jonnie205
Post #85
you gonna get a non abs master cylinder? best one is from a non abs 406
Posted 24th Jan 2010 at 20:57
Disco_Stu
Post #86
I was not planning to, going to use 1 port for the fronts and 1 port for the rears - through the bias valve.
Is there a reason to use a non-abs cylinder?
Project page
Blog
Posted 24th Jan 2010 at 21:24
jmh306
Post #87
nice looking gearbox Smile
FB: South Downs French Car Club
Diablo 6 2001 low boost
Diablo 6 2000 100% standard working air con
Vw Caddy tdi work van
Posted 25th Jan 2010 at 01:23
rallye1999
Post #88
mines done the way you plan to do it, seems fine to me
Posted 26th Jan 2010 at 04:09
Post #89
yep same here, works fine
front port = front brakes to a T piece
rear port = one line into cabin down the tunnel, to a bias valve, out to a T piece splitting to both rear wheels
Posted 26th Jan 2010 at 05:05
Disco_Stu
Post #90
Thank you for confirming this Thumbs up
Project page
Blog
Posted 26th Jan 2010 at 13:39
rallye1999
Post #91
on my brakes the rear port goes straight to the back but instead of a t piece it has two round connectors withe a bolt going through them both , forget what there called but seen them on some calipers
Posted 26th Jan 2010 at 17:57
Post #92
Banjo bolts Smile
Posted 27th Jan 2010 at 22:37
Post #93
looking good looking good.wanted to do my subframe while it was off but weather was shit.my summer job is to waxoil the car LOL
Posted 28th Jan 2010 at 04:03
Disco_Stu
Post #94
In between the rain and snow we have started to reattach some of the engine components (ie front wiring loom, fuse box, power steering tank, washer bottles & window wipers)
We have also received some more parts for the interior - driver and passenger foot rests:
Stuart
Project page
Blog
Posted 3rd Feb 2010 at 00:18
scoobyai
Post #95
looking good Big grin
Posted 8th Feb 2010 at 20:11
fbmmart
Post #96
Hi !
Great build, takes a lot of time and effort I know but it's much more rewarding after ! Keep up the good work and updates !
Picked up a semi-track prepped GTI-6 today, it's stripped but there is lots of remaining (and pointless) wiring..
In this photo there are a few things I'm not quite sure about..
Black box on the floor, just to the right of the middle.. What is it !?
2nd Black box in the Drivers rear ¼, again what is it ?
Cheers, Mart
Posted 14th Feb 2010 at 02:25
Disco_Stu
Post #97
From what I can remember the one under the rear seats is the central locking control unit and the one in the rear
Project page
Blog
Posted 14th Feb 2010 at 16:32
ceesrfs
Post #98
Nice trackcar! Do you have further plans with the engine or will it be original?
Gr,
CJ
Car I drive with pleasure - 205 2.0 16V RFS
Car I drive for fun (track) - 306 2.0 T16
Car I drive as daily - 607 2.7 HDiF Executive
Posted 14th Feb 2010 at 20:54
fbmmart
Post #99
RIghty oh, I don't need them either ! Any Advice on Removing them ?
Cheers..
I generally just drive the Nurburgring in the Summer/end of season, so a whole heap more of that !
Electrically I need to remove the ABS, C/L, Air Bag gubbins, Electric Windows, Rear Wiper/Heater, Air Con, Seat Belt tensioners..Save a bit of weight and make the whole thing alot tidyer !
Posted 14th Feb 2010 at 21:28
Disco_Stu
Post #100
sounds good!
With regards to removing these boxes I just traced the wires back to the dash ect. and then cut them out. Just remember that the fuel pump wires are in the same bundle so check twice and cut once Big grin
Project page
Blog
Posted 14th Feb 2010 at 21:48
