displaying posts 201 to 225 of 485
Pages (20): first .. 8 [9] 10 .. last
Author Subject: My Rallye - V6 install page 3
Post #201
Cool - yeah its all digital ecosol maxx inks for me Smile
Very handy indeed. I would have done the RS engine on my own, but this something completely different.
Posted 26th Jan 2010 at 00:41
Post #202
I have used a Litho press, worked at a small family run business for a year Smile
Just an old single colour Heidelberg.
Posted 26th Jan 2010 at 02:15
Post #203
Rad fan problem sorted - Pacet Thermostat Adaptors
32mm internal diameter with the OE 22mm switch option - cheaper than the Revotec system with no extra wiring needed Big grin
Posted 26th Jan 2010 at 17:57
shimmy
Post #204
When she going to be finished, cant be far away?
You qualified Mei? I run a 6 colour komori atm.
Team V6
Posted 26th Jan 2010 at 18:04
Post #205
Should be this week i'd have thought.
Kind of depends on everything working ok Smile
Posted 26th Jan 2010 at 20:37
shimmy
Post #206
Saw you mentioned about a better right hand lock, how is that gained?
Team V6
Posted 26th Jan 2010 at 23:20
Carl Chambers
Post #207
No 6 speed gearbox anymore so will have more room, although rack or at least the pas ram will have to be changed aswell in order for it to happen
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 26th Jan 2010 at 23:27
Post #208
Just ram I think.... anyway its changed over now so we'll see if it is just the ram thats needed.
If not then i'll hunt down a Xsara VTS rack cos they're quicker Smile
Posted 27th Jan 2010 at 00:28
Carl Chambers
Post #209
Yeah the ram does control the lock so you can just change that, might be better to do it now while the bed etc is off.
might have a standard 306 one will check tomorrow if you want, Xsara rack would be better if you can get one.
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 27th Jan 2010 at 01:36
Post #210
Thanks Carl - i've already changed the ram for a normal 306 one whilst its off the car. Got to create a feed hose for the PAS to the pump tomorrow, but otherwise i'll just be bolting the subframe on and creating the water circuit.
Once the water is on i'll try to start it. Fingers crossed!
Posted 27th Jan 2010 at 02:32
Post #211
Update:
Gearshift installed - needed to cut out more than I thought but ok now. Clutch cable stop point made, but might re-make it a bit better. Need to get the cable run sorted out, but the clutch seems to work.
Re-assembled the stuff on the subframe, but need a new steering rack gaiter so waiting to put the frame on until thats done.
Plumbed in the water system but not put water in yet as have to put in the fan pipe thingy.
Posted 27th Jan 2010 at 22:47
Post #212
Update:
New gaitor, Baker top mount, fan switch adapter arrived. Has to be moved to another unit on sunday so subframe will have to go on, shafts etc. Chuck the rad on the front and hope it works enough to get it on the trailer.
PAS (feed to the pump) and exhaust are the last things to be sorted.
Posted 30th Jan 2010 at 04:58
sloppy
Post #213
how did you get on with the lower mount behind the block, any pic's?
Posted 31st Jan 2010 at 02:17
Post #214
chop and weld at an angle, pretty easy it has to be said LOL
Posted 31st Jan 2010 at 02:28
sloppy
Post #215
sounds good to me! Smile
Posted 31st Jan 2010 at 20:03
james205
Post #216
any pictures of the clutch set up? never seen any pictures of anyone using a cable on these box's
Posted 1st Feb 2010 at 03:30
Post #217
sods law (AKA ITS Fecking French!) meant that the multiplug wiring from the R reg 6 don't quite match the S reg rallye, but it does spin over, and boy does it spin fast!!
these have a pretty beasty starter motor.
current progress, subframe back on, bottom mount modded slightly to clear d/shaft intermediate bearing carrier, transmission mount modded slightly to give more CV clearance.
RAD fan switch takeoff fitted.
PAS return pipe modified to clear exhaust collector pipe, feed pipe next.
Clutch cable was being an arse, self adjusting bit wasn't working for some reason, I think I have a manual one at hiome unused.
James205, there's a few using a cable on the clutch for these, its a case of fixing the clutch fork to the shaft and extending the shaft out through the top bush and fabricating an arm to suit, hence every one is different LOL
several are running a converter box from the cable to the hydraulic master cylinder, basically a box of levers, and I have heard of the master cylinder being fitted into a modified pedal box.
n/s driveshaft fitted perfectly, small issue with the length of the drivers side one to be rectified asap.
Posted 1st Feb 2010 at 15:57
Post #218
Beasty enough starter motor to rip the driveshaft out anyway LOL
So to-do jobs:
2x PAS pipes (1x pressure, 1x feed)
bas**rd f*cking clutch cable mother f*cker (know why its broken now Mei).
Sort out a bit of dodgy wiring (Razz)
Cut and reweld the shaft
Battery tray and general sorting out of things.
Exhaust cut and weld
Add water and wait for the bang.
Posted 1st Feb 2010 at 18:30
brownboy
Post #219
Any more photos of the build?
Posted 1st Feb 2010 at 18:35
Post #220
erm... nope! Not a great deal has changed as far as photos are concerned tbh - the engine has moved slightly has a few wires and pipes attached etc
Will take a few tomorrow if I get time.
Posted 2nd Feb 2010 at 01:03
shimmy
Post #221
Have you cracked the wiring?
Team V6
Posted 2nd Feb 2010 at 01:08
Post #222
He's not been about today so nope!
Posted 2nd Feb 2010 at 01:21
Post #223
I have a feeling that this isn't going to get done for a long time now. Work has had to kick in and its looking insanely busy now until after May (can't complain about that mind!).
Although the more expensive option, another RS engine was probably the way forward as I really need another car now.
Very, very tempted to just cut my losses at the moment and break it Sad
Posted 3rd Feb 2010 at 15:16
shimmy
Post #224
After all that work? Is there that much left to do?
If you do decide to break it il have your wiring loom. Lol.
Team V6
Posted 3rd Feb 2010 at 15:20
Post #225
Not really and the wiring doesn't currently work mate so not much point you buying it LOL
Just f*cked off with the thing and i've got no time to get it sorted now.
Posted 3rd Feb 2010 at 15:36
