displaying posts 376 to 400 of 485
Pages (20): first .. 15 [16] 17 .. last
Author Subject: My Rallye - V6 install page 3
shimmy
Post #376
Sounds good, pictures of the finsihed article? How does the MOT work with the emmissions now?
Team V6
Posted 8th Mar 2010 at 20:56
Post #377
easy, rock up, probe up tailpipe, printout pass sheet, job done Big grin
Posted 8th Mar 2010 at 21:03
shimmy
Post #378
Well wont it have higher emmissions?
Team V6
Posted 8th Mar 2010 at 21:06
Post #379
Don't know tbh. Its got an unknown GTi6 cat on it so hopefully that will be ok. Carl's red rallye passed ok with a similar setup.
Photos will be along shortly.
Posted 8th Mar 2010 at 21:39
Post #380
pics? Hyper
Posted 9th Mar 2010 at 00:17
shimmy
Post #381
Good luck with the MOT? Be soon rumbling around. Big grin
Team V6
Posted 9th Mar 2010 at 16:22
Post #382
What a bloody palaver... no MOT as yet, due to light alignment (sorted thanks to CUJ), PAS pipe hitting the rack (sorted with a cable tie), a couple of bulbs (also sorted) and mainly due to the car being too low for their ramp (FFS its a 30mm drop max on the front).
Being retested tomorrow and we'll overcome the ramp issue one way or the other.
Currently has 2 small water leaks, clutch needs fettling a tad (still), speedo doesn't work and the driveshafts need to be balanced.
Apart from that I found that it didn't wobble too badly in fourth gear when it was rolling and that it gets from 2k to 5.5k rather rapidly in 4th. Now loving the Brembos and i'm remembering just how awesome those ASTs really are. Doesn't feel nose heavy at all, in fact a lot better than the 16v mk3 golf i'm currently driving LOL
Going to be a proper beast Ninja
Posted 9th Mar 2010 at 18:51
Post #383
check the VSS is plugged in, this might have been unplugged when we were checking the wiring Smile
Posted 9th Mar 2010 at 18:52
rallyestyle
Post #384
Did you sort the rear brakes adam, will probably get you a fail in the MOT unless they are working ok Yes
Just Drive It
Posted 9th Mar 2010 at 18:55
Post #385
well I did soak the compensator a few weeks ago and gave it a damn good wiggling when it was up in the air getting the exhaust done, but I have a feeling one of the cables is sticking Sad
Posted 9th Mar 2010 at 19:02
Post #386
VSS is plugged in yes. Compensator is fine, cables i've got no idea about yet.
They aren't able to check the brakes due to the height so it'll be an on-road check and it'll pass that no probs Devil
Apart from the lights and the PAS pipe there wasn't anything else he wasn't really unhappy with. Emissions might be the only thing, but he didn't want to do that cos of the small water leaks. He'll do it tomorrow with or without them as its hardly leaking anything and takes about 8 litres of coolant.
Posted 9th Mar 2010 at 20:15
rallyestyle
Post #387
LOL Its not that low surely? Dont they hook it up to a machine these days?
Just Drive It
Posted 9th Mar 2010 at 20:19
Post #388
No it really isn't that low at all. Same height as when you saw it! Just a crap lifter thing they've got on their test ramp.
Well due to it not going on the ramp he doesn't want to risk it on the brake machine. Anyway either should be fine. Can't personally see what all the fuss is about!
Posted 9th Mar 2010 at 20:22
CUJ
Post #389
I'm seriously liking my temporary black masks Love
Your car looked and sounded very well mate, can't wait to go out for a proper drive in it once you've got the ticket sorted, good luck for tomorrow Thumbs up
The Brembo squeal is a nightmare though tbh Blink
340 horses
Posted 9th Mar 2010 at 20:31
Post #390
Needs those shafts looking at though. Had an interesting chat with Andy Gwynne about them, so a couple of avenues to explore yet.
Thanks for the lend mate - i'm kind of missing them though Smile
Post #391
We're on phase 74657 of clutch fettling and its just needs a tad of shortening to sort it out. Nothing major - 10 mins and a small cut with a grinder.
My wobbling is only happening on acceleration, not around corners and not cruising on say 10-15% power. Basically I think its probably one of the 406 cv joints (the inner one) thats knackared. Got a spare pair to try out anyway but its a bugger to lose the gearbox oil so soon. Could be a shaft isn't straight but considering how tight the pins were in them i'd be surprised if I was getting that much wobble - its bloody loads on 75% throtttle compared to 10%.
Nah i'm not doing anything to the front to get it higher. They'll have to sort something out - I don't really see why its my problem tbh. There is another test station down the road that can do it.
Why will I fail the emissions? Its got a cat on it?
Posted 10th Mar 2010 at 00:20
shimmy
Post #392
Higher emissions on the 3 litre then the standard engine. Not sure how it works, do you not just tell the tester of the engine change? So they allow for the higher emission?
Team V6
Posted 10th Mar 2010 at 03:12
Post #393
Well i've not informed the DVLA yet so I guess it might fail, however the tester said that he has to say on the test sheet the engine fitted and its number. I might need to provide proof of its age as well - not hard really!
Posted 10th Mar 2010 at 12:37
shimmy
Post #394
Just have to find a nice tester. Im sure it will be okay. How do you prove the age?
Team V6
Posted 10th Mar 2010 at 13:44
Post #395
Right well basically it failed for about 15 minutes on the emissions, but finally went through with the exhaust and engine roasting hot. It could only be tested as a 2 litre hence the issue. Bit of p*ssing about with the coolant system helped as its fine now, no leaks and the fan is melting a nice groove in the bumper for itself LOL
2x new Conti permium contact 2s tomorrow and she'll be back. Passed everything else Big grin
Still wobbling on power, but fine everywhere else. Hard to judge just how quick it is without a speedo but it blitzes through 2nd, 3rd and 4th pretty easily. Hits the limiter at 6.5k rpm no problem in 4th. Ninja
Posted 11th Mar 2010 at 00:41
jimmyrallye
Post #396
WE WANT TO SEE SOME PICTURES!!!!!!! LOL
Posted 11th Mar 2010 at 00:44
Post #397
Okey dokey.
Looks exactly the same from the outside by the way Razz
Posted 11th Mar 2010 at 01:15
Post #398
So still dirty then? LOL
Posted 11th Mar 2010 at 01:17
allesclar
Post #399
nice Smile what about the road tax?
Team allesclar ®
Posted 11th Mar 2010 at 01:28
cosmic spanner
Moral objector
Post #400
It's a pre-March 2001 car, so you should pay the same whether it's a 2.0 4 cyl, 3.0L V6, 5.0L V8.. or anything bigger than a 1.6 in fact.
I see it's going up from
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 11th Mar 2010 at 01:57
