displaying posts 26 to 50 of 50
Pages (2): 1 [2]
Author Subject: another gti project....
mike rallye
some good progress
Posted 24th Jan 2010 at 23:53
marksorrento205
Good effort mate! I will pop up friday morning to take a gander Thumbs up
Posted 26th Jan 2010 at 14:42
jaydog81
Has that sump taken a knock?
Looks nice and clean in the engine bay. I would like to just pull mine out and freshen up.
*jay81.
Phase 2.5/S-99
Team i live for working,Paying bills and funding my hobbies. I wish my life could be just living for a pink "I love the 6 sticker".Laugh my ass off
Posted 27th Jan 2010 at 02:49
jord294
not 100% what happened.
it's definately not the cause of a faulty bottom end. it may have happened when engine was removed
but fitting newer and better condition sump tomorrow Thumbs up
Posted 27th Jan 2010 at 03:33
marksorrento205
How you getting on mate?
Posted 30th Jan 2010 at 03:40
jord294
absolute nightmare mate Angry
reasonably dry today, but bloody cold !!!!
managed to get the old sump off and cleaned up surfaces and bolts
then it started snowing !
that's all i could do.
Posted 30th Jan 2010 at 03:53
jord294
woke up to this Angry
luckily, i'd managed to do what i needed over the last couple of days Big grin
i'd fitted the newer sump, fitted o/e oil filter and filled engine with oil
connected a few more plugs, fitted radiator and cowl, and filled with coolant , then bled system
fitted battery, and cranked over. no weird noises, just wouldn't start
i'm such a *anker !
i have now learnt why the car won't start Doh
when i bought the car, the key fob was knackered. so i got hold of a decent fob and just swapped over the key part, and the button internals and threw the old fob away
unknown to me there was also a transponder chip in the original fob aswell Doh so after a lot of questions and some very helpful replies, (thanks guys) i have learnt that an unlocked ecu is the answer
so once i get an ecu, it should only be a case of connecting up and getting the car running
only thing then is, re-fit the headlights and front bumper, fill the gearbox with oil and bleed the o/s/f brake caliper
job done Thumbs up (i hope)
Posted 31st Jan 2010 at 17:01
jord294
with thanks to rich-w (another person on my list of good sellers Thumbs up ), the unlocked ecu has got my car running Big grin
took the car out for a drive, and all was well Big grin
no tapping Big grin temp reached about 80deg. no leaks, but a little hesitant when accelerating. (no induction fitted at mo)
my plan is that once i tax it, i'll take the car to skip brown for a tune.
then i'd like to lower the car about 40mm (need decent struts and springs first), i'll lower the rear myself, but will do a re-build on the beam while i'm at it.
apart from lowering it, and induction kit, they're the only modifications i plan on doing, as i like originality in my cars
here's some pics
cheers
Posted 7th Feb 2010 at 21:53
Top work mate Thumbs up
Posted 8th Feb 2010 at 04:19
jord294
Post #35
cheers buddy.
thanks for your help aswell
much appreciated Thumbs up
Posted 8th Feb 2010 at 04:21
rich_w
Post #36
Glad the ECU did the trick mateBig grin
Contact Details:
07732 822546
Posted 9th Feb 2010 at 02:44
jord294
Post #37
bad news i'm afraid Cry i'm proper gutted Tired
the car starts perfect, and there is no tapping, so at least the head is good Big grin
but when revved or under load the engine knocks Sad
as said, i'm gutted. think it might need new big end bearings.
unlucky for me, i'm back in work tomorrow and have to use the car for the next 4 days. but luckily, i only work 4 miles away
so i have to wait till monday to whip the sump off for closer inspection
just hoping Clapping a new set of shells is all i'll need
Sad
Posted 17th Feb 2010 at 23:22
Post #38
Thats shit news mate Sad
Posted 18th Feb 2010 at 01:43
lotek
Post #39
Sad
Posted 18th Feb 2010 at 01:46
jord294
Post #40
it is indeed
Posted 18th Feb 2010 at 01:49
rich_w
Post #41
That's an arse mate.
Sorry I missed your call earlier - I can't really answer when i'm in the office at work.
It's incredibly unlikely you will get away with doing just the shells - from experience you are likely to want a crank or get it out and get it polished at least Sad
Contact Details:
07732 822546
Posted 18th Feb 2010 at 03:08
jord294
Post #42
luckily i kept the old engine, so i might get the bottom end rebuilt on that, then just swap the head over.
at least if i do that, i'll know that if i decide i go down the s/c route, it should be a good engine to convert Clapping
Posted 18th Feb 2010 at 09:50
jonnie205
Post #43
unlucky, you will be able to make one good lump from the two, plus you will remove and refit it much faster than before now you got some practiceBig grin
Posted 18th Feb 2010 at 20:13
jord294
Post #44
it's a shame to give up on it, as it is quite a nice car to drive
i've been in touch with someone today about building a new short block for me, and hope it will only cost me about
Posted 19th Feb 2010 at 00:00
jord294
Post #45
well here's an update folks.
had to bin the gti6, problems with engines and dvla
so got my hands on this gti6 wannabe Big grin
this one is for keeps
2000 w-reg 2.0 16v non sunroof 306 xsi and in 10 times better condition than the gti 6
unfortuneatly, previous owner had the cyclones pinched, but lucky i had a spare set
that's better Wink
lucky i had a spare donor car
already changed the oil, and fitted genuine filters. also fitted new discs and pads to the rear
i'll be fitting the gti 6 interior aswell Big grin
in time i'll lower it slightly, and get some spare cyclones i've got re-furbished
bye bye gti
Posted 16th Apr 2010 at 01:25
binkagti
Post #46
Was the bonnet no good on the gti or the boot?
TEAM Supercharged Rallye
Posted 16th Apr 2010 at 16:08
fletch
Track Head
Post #47
Looks immaculate in the pic doesn't it!
Post #48
quote:
If you could get another one just the same you could have a mega game of car-conkers! Big grin
Posted 16th Apr 2010 at 19:36
jord294
Post #49
the bonnet on it, is what i took off my xsi, as on the n/s/f edge had blistered and was a slightly different shade
Posted 16th Apr 2010 at 23:40
jjrossi636
Post #50
It was a shame it had to go to GTI6 heaven, but at least i got to raid it a bit before hand, thanks again Andy. Thumbs up
Posted 19th Apr 2010 at 04:16
Pages (2): 1 [2]
