Author Subject: Safe?
iplay
Is is safe to drive without the little torx screws which retain the front discs onto the hub? both of mine have sheared off ... which is a bit weird!
Posted 15th Nov 2009 at 20:39
Rich E Forum Admin
Yes, absolutely fine. They are only there to stop the disc coming loose when the wheel is off.
Posted 15th Nov 2009 at 20:42
Yes aslong as you've tightened the wheels up to the right setting you'll be fine.
*edit* beaten by the best! Doh
Posted 15th Nov 2009 at 20:49
Yep, the wheel bolts clamp the discs on, as above, I don't think they're going anywhere with 18 tons of pressure holding them in place LOL
Posted 15th Nov 2009 at 21:07
Just a pain in the arse when it comes to fitting wheels as unless you line them up perfectly first time. When you put them on the disk spins on the hub and blocks off the holes for the wheel bolts. Annoying trying to look down the holes to see if it all lines up whilst trying to support the weight of a wheel and tyre.
Posted 16th Nov 2009 at 20:38
