displaying posts 1 to 25 of 33
Author Subject: Geometry
jimmy_boy
Right knowledgable folks.. (that excludes about 75% of you lot Whistle)
I had our Rallye laser tracked and adjusted this morning.
We knew it'd be way out since the KW's went on plus the eccentric top mounts.
Well the tow in was way too much so that was adjusted back out and castor was increased to the max we could get while maintaining camber.
The problem was the rear.. we've changed the whole rear beam and trailing arms for refurbished ones. Fitted 25mm torsion bars and an uprated hybrid arb. At the same time some solid rear mounts from Jim.
We have about 1 degree camber on the nearside but practically none on the offside Huh?
Plus and more worryingly we have neutral tow on the nearside but the offside is towing in quite a bit more than standard.
Here are our print outs..
PRE ADJUSTMENT
POST ADJUSTMENT
Obviously no adjustments available on the rear but there is a discrepancy between the pre and post results for the nearside rear toe.
I'm pretty happy about the front but welcome opinions on the tow.
We still have the old beam and trailing arms but I can't believe we have bought an odd pair Citroen/Peugeot Erm?
What do you guys think we should try with the rear?
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 27th Oct 2009 at 00:06
smighall
Smeg-all
I reckon you've got different trailing arms as I said to you. Minimal toe and negative camber would point to that in my mind.
Meh
Posted 26th Oct 2009 at 22:11
khj100
Spoke to Dave earlier, Jim. I'll try and get the old trailing arms off tomorrow night and if necessary get them couriered down.
Unless you fancy joining us at Al's this weekend for a resumption of weekend festivities?
Posted 26th Oct 2009 at 22:13
fletch
Track Head
Slightly bent trailing arm/stub axle?
Could the toe on the back not be solved by unbolting and carefully aligning the rear mounts, on the rig?
Posted 26th Oct 2009 at 22:17
jimmy_boy
This would actually be easy to resolve as our hybrid arb will still fit with those trailing arms!
Cheers Sean
Kev they're f*cking heavy! I may join you this weekend to collect and enjoy F1 finale with you northerers.
I wonder if I could fly up and put them in my hand luggage? Whistle
I thought that about the whole beam Matt.. but what about the camber on one side but not the other? I don't think there's any room in the bolt holes for adjustment anyway.
Changing them would eliminate the arms and point to the beam tube or something else though I guess. Cheers Thumbs up
GTI-6 & Rallye
Posted 26th Oct 2009 at 22:29
khj100
There was a small amount of room in the bolt holes Jim Yes
But that said, the mounts are so rigid where they are bolted on the beam you'd effectively be trying to bend the whole thing. The way we put it on was "at rest" so it seems silly to do anything else.
Assuming that wasn't a joke, let me know if you're flying up - can pick you up from LBA Friday evening.
Posted 26th Oct 2009 at 22:38
there's probably enough slack in all the mounting bolts for the front brackets and manufacturing tolerances to account for the different readings.
Posted 26th Oct 2009 at 22:43
jimmy_boy
It's
GTI-6 & Rallye
Posted 26th Oct 2009 at 23:04
what about it?
Posted 26th Oct 2009 at 23:12
jimmy_boy
Ah you mean the different readings for the pre and post readings of the nearside toe.
Not the fact that one side is towing in and the other is tracking straight ahead?
GTI-6 & Rallye
Posted 26th Oct 2009 at 23:22
iplay
I fall into the 75% ... disclaimer Whistle
I had mine done today so this is quite useful to see a comparison.
Camber issue: Wheel bearing? Warped wheel? Uneven tyre tread?
Rear toe: I would say the position of your rear beam is slightly off. ie the left side of the beam needs to be pushed forward slightly - 1or2mm (undo bolts in boot reposition). maybe the company who did the geometry settings could jack the rear up and adjust the position of the rear beam.
edit: It looks like your front pre-adjusted toe settings were trying to imitate a snow plough a bit out Wink
double edit: my settings after rear beam adjustment Big grin
Posted 27th Oct 2009 at 00:17
^^What Neil said, the rear toe you should be able to tweak with the slack in the bolts on the body mountings, but the wheel with 0 degrees of camber is a concern, are the stub shafts straight?
Posted 26th Oct 2009 at 23:35
puglover Banned!
15mm TB Blink
Posted 26th Oct 2009 at 23:40
I think he meant 25mm? LOL
We've just put a pair of 28mm TB's in the buggy Ninja
Posted 26th Oct 2009 at 23:41
marra
i have never seen the rear of a 306 ever be in spec and i have been doing four wheelers for many years!!
Posted 26th Oct 2009 at 23:47
jimmy_boy
puglover wrote:
15mm TB Blink
That was a test Whistle
Mean't 25mm Doh
GTI-6 & Rallye
Posted 27th Oct 2009 at 00:07
jimmy_boy
It really does seem that simple doesn't it! I don't know how much you can move if forwards on one side without affecting the other though.
Hasn't anyone else had to "align the beam" when changing it over?
Laugh my ass off Flip
Purely guesswork on Dave's part Whistle
GTI-6 & Rallye
Posted 27th Oct 2009 at 00:13
I 'aligned' mine by strapping the rear wheels to a fence and creeping forwards to pull it straight, quick check via the string method and tightened the bolts, sorted LOL
Where's that pikey smiley when you need it? LOL
Posted 27th Oct 2009 at 00:15
jimmy_boy
You think we can get them even? If there is any room for adjustment then I'm suprised no one else has had to do this Unsure
Re the camber - It has to be either bent or the inner beam tube damaged? It all looked fine though. Perhaps changing the stub axels back over will eliminate one or the other.
GTI-6 & Rallye
jimmy_boy
So there is a need to align the beam evenly?? Even if the car is straight?
LOL @ the method though
GTI-6 & Rallye
Posted 27th Oct 2009 at 00:19
iplay
It is easy to adjust ... undo 6 beam retaining nuts in boot ... i am sure someone here could do the calculations to tell you exactly how many mm to move left side forward. better to ask geometry company to jack up car on sills and move beam with laser kit attached. your rear arms will be 20/20 when moved ...
Posted 27th Oct 2009 at 00:21
iplay
so that is your advanced method eh ... i used your other method of loosening the bolts a bit and driving down a private runway with a friend in the boot ... apply brakes and tighten Whistle
Posted 27th Oct 2009 at 00:29
jimmy_boy
Cheers for all the responses so far guys.
I'll be changing the stub axels back over to see if that cures the camber. If it doesn't alter the toe correctly we'll f*ck about with the whole beam.
GTI-6 & Rallye
Posted 27th Oct 2009 at 00:33
c_j_m
Just got a PM from Jim as It me he bought the beam off.
Just reading whats put I'm going with a bent arm/stub axle as the car the beam was from was a write off.
as far as I know both arms are GTI items.
From lowering my mates car to the same hight with a good beam (new bearings and pins at some point) the camber on the passengers side seams about right.
Posted 27th Oct 2009 at 01:20
the guys have said precisely what I was going to elaborate on with the mounting bolts, there's 8 bolts that you could loosen and move the beam around on very slightly, probably enough to make the differences up.
Posted 27th Oct 2009 at 01:22
