Author Subject: Best place for wishbone bushes?
dommo
Hi folks, just failed an MOT on a number of things, two being my front wishbone bushes. On GSF these are the related parts available, am I best going for the whole wishbones at 50 quid for the pair (do they come with both bushings?), or going for 2 of the more expensive and presumably better bushings? The list is below and will hopefully come out formatted correctly, if not I'll put it in another post!
Or finally, should I get the bushes from elsewhere? Cheers.
N42210 FR CONT ARM L/H 306 (REQUIRE BALLJOINT) 25.00 Add
N42211 FR CONT ARM R/H 306 (REQUIRE BALLJOINT) 25.00 Add
N42234 FR CONT ARM FR BUSH 306 4.85 Add
N42234A FR CONT ARM FR BUSH 306 3.25 Add
N42235 FR CONT ARM REAR BUSH 306 10.20 Add
N42235A FR CONT ARM REAR BUSH 306 6.75 Add
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 25th Oct 2009 at 04:10
did it fail on the p-bushes or the front ones as i didnt think the front ones failed
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Oct 2009 at 13:13
smegal
I would make sure the bushes are lemforder (sp?) as QH ones may not last too long.
Ex SC-6
Now in a Megane R26
Posted 25th Oct 2009 at 13:56
dommo
It didn't really state which were the problem, just front suspension bushes or something. But I'd probably do all four if I do any.
I've noticed that if I get someone to drive forwards, then reverse, you can see my front wheel move backwards and forwards slightly, is this the P bush?
GSF do stock some lemforder parts don't they, I had a Lemforder drop link from them before now but I had to ask for it.
Posted 25th Oct 2009 at 14:02
mechanical_repairs
Yes thats the p bush, very common to fail now as the cars have got older, i buy them from Citroen as you can buy just the bush from them.
Carl
Posted 25th Oct 2009 at 14:31
dommo
That sounds good, how much are the bushes from citroen? and are they easy to change? do you chop the old bush out and heat up the metal then shove the new bush in? can you press them in with a socket and a vice?
Posted 25th Oct 2009 at 15:47
cut the old 1 off with a angle grinder and you can tap the new ones on, but you have to position them correctly(at the correct angle)
Posted 26th Oct 2009 at 12:54
dommo
I've read that about the right angle thing, cheers andy/katie.
Is the other wishbone bush (not the P bush) one piece or two pieces?
Cheers!
Posted 25th Oct 2009 at 23:57
dr-evil
What size hubs do you have?? If you have 16mm ball joints then you can get complete wishbones from CES for 30 quid a side or the bushes are roughly 6 quid a piece but i haven't bothered to use them yet so can't comment on hardness
Edit: two round ones at the the front pivot and one p-bush at the rear of each wishbone = four rounds and two p's to do both sides Smile
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 26th Oct 2009 at 02:58
dommo
According to servicebox I've got 18mm hubs?? Sounds quite big?
I'll probably just get the more expensive bushes from GSF tomorrow, but I'll ask them to check what bushes come on the wishbones they stock as well. Cheers matey.
Posted 26th Oct 2009 at 03:00
dr-evil
18's work out more expensive because the wishbones and ball joints are only sold seperately much to my disgust because out of all the 306's we've got or had my current rallye and previous six had 18's Roll eyes
Edit - sorry didn't mean to confuse you the size's are in reference to the balljoint sizes - all the bushes are identical across phases
Posted 26th Oct 2009 at 03:14
dommo
Yeah I knew you meant the ball joint sizes, I think the ones from GSF come without ball joints anyway so I should be alright. I'll see what make the bushes they stock are tomorrow, cheers matey.
Posted 26th Oct 2009 at 03:31
aknight
A nice upgrade for the P bush is to use one from a 406 or Picaso . Just need to drill out and retap the locator hole on them I believe from 8mm to 10mm.
Team 330mm.Team Rallye.
Posted 26th Oct 2009 at 03:52
motaquip from motaparts.co.uk, dirst cheap and decent quality Smile
Posted 26th Oct 2009 at 04:05
I was under the impression that these were actually softer, even though the bush was larger.
Posted 26th Oct 2009 at 04:21
Im sure hovis/someone else tried these and said they were crap.
what you want are some nice group n ones like ive got Smug
Posted 26th Oct 2009 at 04:35
dommo
Just decided to buy whole wishbones from GSF, no idea if they're decent quality or not (they said they were.. hmm..) but my old P bushes were bo***cksed!
Cheers for the advice folks, and I'll probably open this topic again if the bushes are shagged in a few months!.
Posted 27th Oct 2009 at 04:09
matt_gti
Just replaced mine with complete w.bones from Pug. Not cheap but won't have to replace them anytime soon. I took the old ones off as there was play in the p bush (turned out to be wrecked!) and that in time then caused the front bush to deteriorate.
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
E39 535i - Daily driver
*Newest edition* E60 M5 5l v10 - The weekend car Smile
Posted 28th Oct 2009 at 23:07
dommo
Same here matt_gti, how much were the wishbones from Pug? My old P-bush was goosed!
livy
you dont want to know.
im sure there over 300 for both sides with balljoints.
im sure euro do the lemforder bones with bushes.
about
Posted 28th Oct 2009 at 23:23
i think mine from pug came to about
Posted 29th Oct 2009 at 00:54
lotek tried the xsara ones and they worked out to be shite guys
Posted 30th Oct 2009 at 01:47
matt_gti
Yeah mine just nearly fell apart!. Without the ball joints the arms were
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
Posted 10th Nov 2009 at 01:04
SteviePut
He must have bought cheap non-o.e ones as they're exactly the sameConfused
Posted 10th Nov 2009 at 03:20
I got Motaquip ones for not a lot of cash and they seem to be very good Smile
Posted 10th Nov 2009 at 03:41
