Author Subject: EVO Brembos
lotek
i have a fullset of brembos that i want to get on to my car , they are evo brembos that were fitted to a galant vr4 twin turbo.
my question is what discs could i use ???
I wont be using the rear calipers as they dont have a mechanical handbrake.
I will need some brackets made up what shouldnt cost too much i would have thought??
Posted 7th Oct 2009 at 21:11
rallyeash
cant help with the discs but brackets shouldnt be a problem, on my 4 pots i basicly made a template out of wood then got a local engineer to make it from alloy, he30 grade i think from memory was the stuff to use Smile
309 3dr K20 Type R
Posted 7th Oct 2009 at 21:23
^^6082 T6 these days.
He15 is fine too (2024 T6), but corrodes faster and doesn't anodise quite so well.
Posted 7th Oct 2009 at 21:27
lotek
that means having to take my hub off.. damn.. anyone have one they could lend me? lol
these discs are going to be a bloody nightmare
Posted 7th Oct 2009 at 21:47
Whistle i'll have the two pots if i can get them to fit Angel
Posted 7th Oct 2009 at 21:52
lotek
if it helps the discs these go on standard are 355x32 ?? on a evo
what size are the xantia v6 discs?
Posted 7th Oct 2009 at 21:59
rallyeash
yeah hub needs to come off, i took my hub to work stuck it in the vice, bolted the disc on and just played with the wood with a file until sat perfectly. Smile
309 3dr K20 Type R
Posted 7th Oct 2009 at 22:02
lotek
ok il have to take that approch, i will have to get some 16's what isnt a biggie but im still worryed about what discs will work, whats the biggest disc pug do that will fit a 6 hub?
Posted 7th Oct 2009 at 22:19
lotek
debating just getting 406 brembos.... there 4 pots aswell and bolt straight on?
how much better is the braking?
Posted 7th Oct 2009 at 22:55
paul_13
Read my text LOL
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 8th Oct 2009 at 00:01
rallyestyle
Have a read of my AP Racing Project thread mate, it will give you a bit of an insight into what needs to be done when making a brake kit Yes
Are these calipers lug mounted?
I have a few spare hubs if you need to borrow one Thumbs up
Just Drive It
Posted 8th Oct 2009 at 00:18
was going to ask what rallyestyle asked, what's the fixing method, lug or radial?
if its lug then you're probably better off getting some radial and some brackets, or some 406 ones.
Posted 8th Oct 2009 at 02:27
lotek
i have no idea. lol
they just got the 2 holes like the 406 ones do. lol
Posted 8th Oct 2009 at 08:23
lotek
right chopping them in for 406 ones lol.
Posted 8th Oct 2009 at 18:05
