displaying posts 1 to 25 of 56
Pages (3): [1] 2 3
Author Subject: 2.1 engine build
rallyeash
over the next couple of months i will be building a 2.1 bottom end for my 205 rallye. i already have a rebuild gti6 head with catcams and itb's to drop straight on it.
i know theres a few people intrested in the 2.1 conversion so im going to try to do a bit of a step by step guide and show all the cost of doing it.
so far ive got a bare block to build from. here is pic of it before i gave it a good clean with a wire brush and some degreaser.
looks much better after a clean, will stick up a pic tonight.
the block i managed to pick up for only
309 3dr K20 Type R
Posted 21st Sep 2009 at 17:06
dannygti-6
will be keeping a close eye on this to see how you get on been thinking about a simialer setup for a bit
good luck!!!
Xbox Live = Sp4n
Team one gti-6 - 2 cherry rallye's
Posted 21st Sep 2009 at 17:15
could use an S16 rod+oversized piston combo, as they sit 1mm below deck as standard (flat top piston)
Get the intruder and cutouts adjusted to suit the compression and clearance you need.
Posted 21st Sep 2009 at 17:57
rallyeash
im awaiting to hear back from one company, they can supply 87mm wossner pistons and hoping they can do forged 160mm rods. then would be sorted Smile
309 3dr K20 Type R
Posted 21st Sep 2009 at 18:03
dannygti-6
so your using the crnk out of a 1.9td 306 any paticular model or ar they all the same???
Xbox Live = Sp4n
Posted 21st Sep 2009 at 21:08
rallyeash
yup 1.9 td 306, citroen xantia
most xud 1.9 turbos i believe
309 3dr K20 Type R
Posted 21st Sep 2009 at 22:11
mxcrazy
What about using the crank out of the 2.1 12 valve td? presumably shorter rods or pistons with a shorter pin to face height would be needed, would there be enough bore length at BDC to accomodate though?
Dont know the stroke length on it exactly but its longer again than the 1.9td, that plus the 87mm pistons?
Posted 22nd Sep 2009 at 16:40
that's 92mm IIRC, enough for a 2.2 or 2.3 if offset ground and big bore.
Posted 22nd Sep 2009 at 16:46
rallyeash
i bought some red engine paint for the block and some mobil 1 motorsport 15w50 today for when shes all built up, scared of not using good oil after seeing a couple of engine on here.
sandys got me a 87mm piston and 160mm rod combo sorted out with rings and ARP bolts that will drop straight in after the blocks been machined. just need to find the cash...
also done a favour at work for a local machining company, had to get a tech drawing for a tractor crank. thought i'd drop in i need some work done and there going to sort me out Smile
will be getting on service box later as theres loads of small bits ill need from pug. luckily i have a mate there and can get a good price when he puts them on a weekly stock order Whistle
309 3dr K20 Type R
Posted 22nd Sep 2009 at 18:24
mark-house
How much are the pistons and rods setting you back?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 22nd Sep 2009 at 23:38
rallyeash
309 3dr K20 Type R
Posted 22nd Sep 2009 at 23:42
mark-house
ooooooouch! thats a lot of notes!
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 23rd Sep 2009 at 00:09
rallyeash
i know but you cant skimp on some items.
you can get them cheaper but the length of rod isnt correct and the pistons need machining. these ones will drop straight in.
so in the long run should be better Smile
309 3dr K20 Type R
Posted 23rd Sep 2009 at 00:39
matt h 306
Are they the same rods and pistons as mine?
Posted 23rd Sep 2009 at 00:54
rallyeash
im not sure mate, would believe so
309 3dr K20 Type R
Posted 23rd Sep 2009 at 01:15
rallyeash
picked up a complete bottom end this evening for
309 3dr K20 Type R
Posted 24th Sep 2009 at 02:16
just use the 2.0 MI16 /S16 mount, no cutting required and far lighter Smile you'll find it on a lot of 8v iron blocks too.
also, I'd recommend getting new flywheel bolts not re-using old ones, I've had some break on me, and it is advised in all the haynes manuals and by peugeot LOL
Posted 24th Sep 2009 at 02:30
rallyeash
will do. need a few things from pug so will add to the list.
i'll see if i can pick a s16 mount would look tidier. if not a chopped 6 mount will have to do.
309 3dr K20 Type R
Posted 24th Sep 2009 at 03:21
spiky
cool dude Big grin
i take it you got fed up of the old setup?, shame really Sad
bigger and better, no worries with the cams again either Big grin
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 24th Sep 2009 at 04:06
rallyeash
yeah was sick of every session have to take the wheels off, get through a can of brake cleaner just to clear the oil up.
thought about just using a standard bottom end as i could have it build by the weekend but im pretty sure my cams won't clear standard pistons, so im just going to do it right and have abit more grunt tooBig grin
309 3dr K20 Type R
Posted 24th Sep 2009 at 15:24
spiky
yeah, must have been frustrating Sad
this is partly why i havent fitted cams Sad it's a gamble
though they are fine in my 306 gti6 Sad
MY YouTube Videos'
Posted 24th Sep 2009 at 15:26
t11hac
Just seen the tin in the photo i like it this is one of my engine with a tin LOL
t11hac has attached the following image:
Team Black Rallye
Posted 24th Sep 2009 at 15:44
rallyeash
spiky, its not the cams thats the problem. more of the mi16 bottom and gti6 head combo. just you cant get a decent breather setup sorted.
309 3dr K20 Type R
Posted 24th Sep 2009 at 16:22
spiky
sorry, my reply was a bit crap.
that basically what i was saying,
and that i havent cam'd mine as the clearance issue, as i have std gti6 engine.
MY YouTube Videos'
Posted 24th Sep 2009 at 16:23
rallyeash
ahh i see, i read it wrong. yep works out alot more than
309 3dr K20 Type R
Posted 24th Sep 2009 at 18:15
Pages (3): [1] 2 3
