displaying posts 26 to 42 of 42
Pages (2): 1 [2]
Author Subject: Melted piston
That's upmarket car repair technique in Donny that....
Posted 19th Sep 2009 at 04:57
birk
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 19th Sep 2009 at 06:09
aaron6
rich_w wrote:
< 50 RA is the general guideline in terms of MLS gaskets - this doesn't have to be ground, it can be done on a good flycutter.
I would also check the block for a crack - however it will be very small, and not necessarily visible!
Smile
Is that all?! Im a toolmaker by trade and a roughness average or 50 is awfull. With the right cutter, speeds and feeds you can easily achieve a 1.6 ra or better. Grinding will of coarse be better but why bother when milling would be so easy. Wouldnt you just scrape the block flat to save stripping it down? Thats all i did on my birds TU engine when rebuilding after a cambelt failure and that works a treat. Just takes a little time. Smile
Posted 20th Sep 2009 at 04:47
chrisd306
Wait til you see the pic of my piston tomorrow i think it should be bad.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 21st Sep 2009 at 00:06
birk wrote:
There is no carbon on the top of that piston, I read somewhere thart that is a good sign of a water leak into that cylinder. Having suffered with overheating issues in the past this is looking very much like you have a crack in the bore somewhere. Can you get the block out, strip it and then have it pressure thested?
Posted 22nd Sep 2009 at 00:12
birk
The block is already out of the car dave Smile
Ive replaced the engine as i couldnt be arsed figuring out what was up with the block
Not sure what to do with it now, probs just strip it down at some point and get it tested, then maybe sell it.
07889376885
Dan
Posted 22nd Sep 2009 at 00:25
chrisd306
wait till you see my thread mate, all 4 pistons are f*cked!! its bad pitting due to running normal unleaded instead of super, epic fail!!
& Audi Q5 S Line
Posted 22nd Sep 2009 at 00:42
so high octane fuel is a must on these s/c 6`s then is it??????????
andy
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 22nd Sep 2009 at 01:18
I would have thought that would be a given!
Posted 22nd Sep 2009 at 01:20
Post #35
Posted 22nd Sep 2009 at 02:21
chrisd306
Post #36
yes it is, i totally forgot to be honest, as i never new for sure!
no damage to valves
& Audi Q5 S Line
Posted 22nd Sep 2009 at 03:21
birk
Post #37
Nasty Sad
07889376885
Dan
Posted 22nd Sep 2009 at 03:32
chrisd306
Post #38
oops on my part like!! stil able to build an engine as got set of pistons that are ok and a spare head and bottem end aswell, so will end up with 3 engines complete, still a bas**rd, that was still runnin before i took it out, just didnt idle, but when reved still went ok lol
& Audi Q5 S Line
Posted 22nd Sep 2009 at 03:42
rich_w
Post #39
It turns out Chris' pistons melted becuase he was using regular unleaded - 95 octane.
This isn't nearly as stable, and doesn't burn as controlably as super unleaded like V-Power or Tesco 99 octane.
The result is detonation, and melted pistons as can be seen by the pics. So, all low-boost S/C users, please fill up with a high octane fuel like V-Power or Tesco 99 octane, as recommended in the installation guide.
The problem is high compression engines like the XU10J4RS, particularly when boosted, will be prone to det if poor quality fuel is used, or they run lean, too hot etc.
If you want to use regular unleaded [95 octane] I can supply some modified ECU software with less ignition advance [and slightly less power!].
Smile
Contact Details:
07732 822546
Posted 22nd Sep 2009 at 05:21
Post #40
You can see where the flame front has got to before the rest has simply detonated under the pressure No
Posted 22nd Sep 2009 at 05:34
chrisd306
Post #41
Post #214
Rich, i totaly acept the blame for this, as both counts was my fault, shit oil then wrong fuel, the kit is an excellant kit and i was very happy with it, so i recomend it to anyone, as long as they use good oil and the correct fuel.
& Audi Q5 S Line
Posted 22nd Sep 2009 at 13:30
rich_w
Post #42
Chris, not trying to blame anyone mate! These things happen, I mean look at how many engines I have killed getting to where I am now. I raised the point purely because I dont want other people to have the same issues :-)
Contact Details:
07732 822546
Posted 22nd Sep 2009 at 15:05
Pages (2): 1 [2]
