displaying posts 76 to 100 of 108
Pages (5): first .. 3 [4] 5
Author Subject: Ap 4 pots. Batch
saveloy
Post #76
Lovely looking calipers, granted.
But given the piston sizes, they are far too small for the intended application.
I wouldn't entertain anything with less than 40mm pistons.
Surely those calipers were only used on the rears of TVRs.
Posted 11th Oct 2009 at 02:16
SteviePut
Post #77
rob&the6 wrote:
thats easily sorted you just remove the nips and fit the pipe on the otherside of the caliper and the nips on that side.
Or just fit the calipers on the right side of the carWink
Posted 11th Oct 2009 at 02:18
Post #78
If they're the same size as normal 6600 calipers then they're a spot-on match Wink
And I'd imagine the calipers are that way around because the bleed nipples + crossover pipes need swapping over.
Posted 11th Oct 2009 at 02:25
Post #79
Technical hiccup there, have a closer look at the photo's Whistle
Posted 11th Oct 2009 at 02:26
SteviePut
Post #80
Dunno Other than TVR would be the wrong way up if you fitted them on the other side of car. Or would they?? LOL
Posted 11th Oct 2009 at 02:34
Post #81
Nah, keep trying, someone's spotted it surely?
Posted 11th Oct 2009 at 02:37
rage buggy
Post #82
these calipers have two different sized pistons and with a 55mm x 125mm pad area with 335mm discs they will be excellentSmile
Posted 11th Oct 2009 at 02:40
saveloy
Post #83
No way. Perhaps on a TVR they'd be fine, since they are far lighter than a 306.
But they simply won't be powerful enough on a 306. You would need to offset that with huge discs. And wheels!
I used 4 pots on my 205 GTI, and they had 4 x 38.6mm pots. Wonderful stopping power. Overkill perhaps, but what's the point of having 4 pots otherwise?!
I wouldn't go any smaller on a car that's over 300 kgs heavier.
Posted 11th Oct 2009 at 02:48
Post #84
CP6600 standard piston sizes are ~ 38mm and 41mm...
Posted 11th Oct 2009 at 02:50
SteviePut
Post #85
Which TVR weighs only 900kgs?
Post #86
My bad, just noticed the different piston sizes on the first page.
Even then the disc size or a simple swap down to an S16 master cylinder would probably sort that out...
Posted 11th Oct 2009 at 02:56
saveloy
Post #87
38mm and 41mm! Now that's more like it. With a large disc it will give very good stopping power. And won't lengthen the pedal too much.
The 900 kg I was referring to is the weight of a 205 GTI.
You'll need to remove that allen headed bolt from the bell!
SteviePut
Post #88
Disc's are on the wrong side of the car?
Posted 11th Oct 2009 at 02:57
Post #89
Nope, keep trying, good spot though, I hadn't noticed LOL
Posted 11th Oct 2009 at 03:01
rage buggy
Post #90
you need to look at the last pictureBig grin
Posted 11th Oct 2009 at 02:59
SteviePut
Post #91
I give upLOL
Posted 11th Oct 2009 at 03:06
Post #92
LOL
I'll see if anyone else spots it.
Posted 11th Oct 2009 at 03:07
SteviePut
Post #93
You're not referring to how the car has been jacked up are you? Surely not??
Posted 11th Oct 2009 at 03:12
Post #94
Nope, it's the calipers.
Posted 11th Oct 2009 at 03:25
SteviePut
Post #95
IF they have different size pistons should one always be the leading one (maybe the smaller one of the two??) Is that issue??
Posted 11th Oct 2009 at 03:27
Post #96
Thumbs up
That's why the bleed nipples are upside down and need swapping over rather than the calipers just swapping from one side to the other...
Posted 11th Oct 2009 at 03:30
SteviePut
Post #97
phillipm wrote:
Thumbs up
Thank f*ck for thatLaugh my ass off
Posted 11th Oct 2009 at 03:32
SteviePut
Post #98
I assume TVR's have the calipers mounted at 180 degree's to Peugoets?
Posted 11th Oct 2009 at 03:33
Post #99
Yes
Posted 11th Oct 2009 at 03:35
SteviePut
Post #100
Is there any advantage to that Phil? Or is it just a packaging thing??
Posted 11th Oct 2009 at 03:36
