displaying posts 51 to 58 of 58
Pages (3): 1 2 [3]
Author Subject: dimma/maxi wide track drive shafts
jonnie205
Post #51
its easy enought to lengthen the 6 shafts. cut them in half, extend using solid bar internally making sure you have the correct length. Seam weld the outer shaft to the inner bar and then plug weld through to the bar at a few spots along the bar all the way round. Done this once and they have been fineBig grin
Posted 25th Jan 2010 at 23:07
Post #52
feck, that's a bit ott on the pricing!
1, single, specialist CV joint for the buggy is
Posted 25th Jan 2010 at 23:13
Post #53
maybe, but how much grip and power do you have? quite a lot more I'd imagine Razz
Posted 25th Jan 2010 at 23:30
jonnie205
Post #54
I run a fleet of 8 honda pilot buggies at the rally school, you lot are spoilt on prices of car parts, pilot prices are mad
rear caliper
Posted 25th Jan 2010 at 23:35
Post #55
Simmonites are selling theirs off if want some more Jonnie, they were in great nick last time I saw them.
Posted 26th Jan 2010 at 04:29
Post #56
On the 2wd!
They're light and very efficent tho'...
The shaft is only 28mm thick, and it still takes all the stick from landings, etc LOL
Posted 26th Jan 2010 at 05:01
jonnie205
Post #57
Yes thanks i saw the simmonites ones, i have more than i need at the moment. I bough an extra 2 for a large job i had up noirth last year and they have just been parked up since. One than got crashed hard so i broke it for spares so ime doing ok
Posted 26th Jan 2010 at 14:34
puglover Banned!
Post #58
martinj wrote:
...if you have sufficient time on your hands, go to a scrapyard and find a 1.9 (non turbo) citroen dispatch van (or equiv Peugeot / Fiat) and get one of the shafts of it - compare the shaft to the 306 gti and you should be able to then confirm if it is the +40mm required.
If it is, then you have a much cheaper solution than having bespoke items made. I had a quote of circa
Posted 27th Jan 2010 at 00:35
Pages (3): 1 2 [3]
