custom carbonfibre and fibre glass parts. 07513059320
| Author | Subject: dimma/maxi wide track drive shafts |
vittesse_tuning
Senior User Location: silverstone Registered: 20 Jul 2009 Posts: 631 Status: Offline |
hi new to the site just wondered if this is any helpto anybody. i have found a shaft that might be usable for wide tracking a 306. the shafts are from a dispacth van. the lenghts are 675 and 965 the 306 ones are 635 and 925. these aren't perfect measurments as only had an old tape. the only problem i can see is they are the smaller diameter shaft like the small engined pugs. does anybody have any more info that could help? cheers james________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
406 ones can be used, they are thick bar |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
you'll never get anything done eating popcorn Mr Midlife ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
vittesse_tuning
but 406 ones aren't as long as the dispatch ones. the short shaft is only about 15mm longer than 306. am i right in saying the smaller dia shafts are solid?________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
puglover
Banned!Location: Far out there Registered: 08 Jun 2006 Posts: 6,095 Status: Offline |
correctwhich shafts exactly do you mean? |
vittesse_tuning
they are from a dispatch 1.9turbo diesel. so they should be strong enough. not sure how much torque they would take. i know some one on here produces the kit to wide track the rear but can't remember who. ________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
puglover
martin j |
puglover
vittesse_tuning wrote: they are from a dispatch 1.9turbo diesel. so they should be strong enough. not sure how much torque they would take. i know some one on here produces the kit to wide track the rear but can't remember who. what is a dispatch?? a van?? this could be just what a few members have been looking for. |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
Citroen dispatch van ? i can check the proper lengths of the shafts if needs be.________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
dispatch/expert same thinghas to be from a BE box though, the ML gearbox has different splines. shortening them is a doddle if they're the larger type as they are hollow. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
vittesse_tuning
they are from the van. it does have a BE box and i've checked them in a pug diesel box. got a good friend that works at a french scrap yard so get to play with a few bits so always help full. would be nice if we could get a wide track setup without having to pay dimma silly prices. forgot to check the shafts fit a 306 hub but they did look the same. ________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
vittesse_tuning
so if the larger ones are easy to shorten is it not possibe to make a solid section the increase the length of them?________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
birk
Send me a shaft and i will see if it fits my dimma ![]() ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
vittesse_tuning
ok will try and get one sorted next week once i've been paid. are the dimma ones the smaller dia?________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
puglover
this sounds promising.phillip does wishbones martin does back spacers and track rod extensions these driveshafts if work are the last piece of the puzzle. After my rallye is built i know what im doing ![]() |
midlife
puglover wrote: After my rallye is built i know what im doing ![]() Looking for it behind a bush ![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
vittesse_tuning
what about top mount conversion for struts. i know bakerBM do some really nice ones that are camber and caster adjustable for ________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
vittesse_tuning
managed to buy some arches for 280 delivered from a guy in ireland. said he could do the skirts for an extra 50 but going to build my own. same with the bumpers. fancy an extra wide phase 3 front.________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
birk
If you make a ph3 bumper, then let me know, i want to change my ph1 front end aswell.________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
vittesse_tuning
will do i'll try and put some pics up at some point. its the rear bumper thats causing me problems at the minute. can get the top looking ok but then the bottom only comes half way across the rear wheels. prob don't help their 10 inches wide lol.________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
birk
Yea, pics would be great.So how have you done the front one then ? ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
vittesse_tuning
only stripped the front down so its without its grill and fogs really and taken a few measurements. thinking about blending the very bottom of a phase 2 SP bumper on. just the low vents. was going to sell it but would rather have a lush looking bumper for myself. has anyone got a good pic off just one end of rear bumper taken so i can see what lines to follow.________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
birk
I thought about getting a ph3 bumper, splitting it in the middle and just adding some in the centre, but i also thought that the edge of the bumper maybe a little off, as the dimmer bumper curves alot more, asif the bumper has been stretched________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
vittesse_tuning
yer it just needs the top and bottom needs cutting then if u heat the bumper u can pull it out wide enough. but it just takes time. in the middle of trying to do one side of the rear now so better get on lol________________________________________ custom carbonfibre and fibre glass parts. 07513059320 |
