displaying posts 1 to 25 of 42
Author Subject: Heat wrapping manifold
eddy_gti6
just wondering how many of you have done this and any idea how much heat wrap would be needed?
just thought ad ask as i have my engine out and my manifold is sitting in the back of my car.
some people say paint it black and outhers say heat wrap it, dont now what painting it black would do? not alot i would of thought Huh?
Posted 24th Aug 2009 at 08:25
aknight
Black high temp paint would make it look nice...
Heat wrap wise a role should do it ,I think thats all I used.Just make sure you use the right clips to hold the ends and use the spray paint stuff that goes with the wrap as well as it will last longer then - still pretty fragile though.Sad
Team 330mm.Team Rallye.
Posted 24th Aug 2009 at 09:16
mr swampy s16
**BAD SELLER**
A roll will do it?
What size roll? Width and length as they are all different.
Id use thermotec gen 2 in the 2inch wide,not sure how much you would need.
Make sure you apply it wet, use gloves and stainless steel clips.
And use the silicone sealant over it.
You could get it ceramic coated which does the same thing though its not cheap.
Demon tweeks do a home apply version not sure how good it is though.
Posted 24th Aug 2009 at 11:54
eddy_gti6
where do you get the thermotec gen 2 hear wrap from? i was looking on ebay and found:
EXHAUST MANIFOLD FIBREGLASS HEAT WRAP TAPE 1" x 5 METRE made by LMA motorsports
do you get the silicone sealent with the heat wrap as one package when you buy it?
Black high temp paint may make it look nice but the only thing is no one can see the manifold on a gti6, also what would black heat paint actualy do?
what would be better? black heat paint or heat wrap?
Posted 24th Aug 2009 at 15:36
mr swampy s16
**BAD SELLER**
Should find it on ebay.
If not raldes, merlin or demon tweeks
you wont get the sealer or the securing things with it.
5m may just do one header.
Posted 24th Aug 2009 at 16:07
eddy_gti6
found it on ebay mate Thumbs up would yo say about 20meters should do the manifold then?
Posted 24th Aug 2009 at 16:20
eddy_gti6
anyone got a picture of theres done?
Posted 25th Aug 2009 at 06:19
3rd time lucky
20 metres!!!Shock
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 25th Aug 2009 at 15:09
allanallen
I found the stainless zip- tie things were crap and ended up using stainless lockWire, it was much cheaper and is still going strong after 30k.
Facebook
Posted 25th Aug 2009 at 15:53
mr swampy s16
**BAD SELLER**
Yeah think i had a 25m roll and had a bit left.
Yep ss lock wire is best to secure it.
Posted 25th Aug 2009 at 16:08
millsyxsi
My heat wrapped 106 mani
http://i511.photobucket.com/albums/s351/Millsyxsi/IMGP0465.jpg
"They've done studies, you know. 60% of the time it works, every time."
Posted 25th Aug 2009 at 16:57
eddy_gti6
well decided yo buy some black heat paint to spray my manifold. have to say it looks good Big grin
pics from start to finish:
manifold is out
just painted
now its dry
think next i will heat wrap it
Posted 25th Aug 2009 at 19:19
ben306
Arent there meant to be problems with wrapping mild steel? With regards to water getting in and them cracking?
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 25th Aug 2009 at 19:32
eddy_gti6
not sure? not hurd of anyone having problems with that. may have to look in to that. water shouldnt sealy be a problem tho if you wrap it then cover it with the silicone sealant
Posted 25th Aug 2009 at 19:38
ben306
Might be the sealant that keeps the water out then! Dont even know where I heard it so might be something I've made up lol
3 sisters circuit
Few laps at Blyton
Posted 25th Aug 2009 at 19:45
eddy_gti6
LOL only problem i have hurd about is them setting in fire if you have oil leaking on to them Huh?
Posted 25th Aug 2009 at 19:56
cress87
More to the point, are there any benefits of actually wrapping the manifold?
P.S. The manifold looks good painted but I can't imagine it'll last long...
Posted 25th Aug 2009 at 22:14
eddy_gti6
no i dont think the paint will last long either LOL thats why i want to wrap it, i have already had my manifold heat shield set on fire and heat wrap is suppose to reduce heat in the engine bay
Posted 25th Aug 2009 at 22:43
ben306
Reduces heat in the engine bay, also keeps the exhaust warmer, and therefore the air inside it alot 'thinner' (less dense) meaning it can escape quicker. I've heard of rally cars having the whole exhaust wrapped.
Its all about getting the air in and out as quick as possible aswell as cold dense air going in, and hot, thin air out!
Thats how I understand it anyhow
3 sisters circuit
Few laps at Blyton
Posted 25th Aug 2009 at 22:51
eddy_gti6
i have been tempted to paint and wrap my whole exhaust think al just do my manifold for now tho
Posted 25th Aug 2009 at 22:52
jcphat
I can vouch for the reduction in local heat with a 6 manifold on a cabrio it does matter! There must be a theoretical risk of corrosion but only if you get the manifold wet and leave it wet. I cant see how this is likely unless you go through a flood and immediately decide to turn off and leave the car to cool down immediately. If you run the engine for any length of time it would dry out. if the flood has stopped the car you may have greater problems anyway. I suspect this is a risk for open engine designs stored outdoors.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 25th Aug 2009 at 23:12
eddy_gti6
well i wrapped my manifold today, i havnt put any silicone sealant on as i couldnt find any where that had any and the place i got my heat wrap from was sold out of it, ant idea where i can get some?
here it is anyway
Posted 30th Aug 2009 at 15:54
blatant case of did not read the f*cking label.....
what do you want the sealant for?
Posted 30th Aug 2009 at 16:58
eddy_gti6
haha its on. 4 now, jubale clips will do me LOL
i aint bothering with the sealant now as the manifolf is fitted 2 my engine and my engine is back in my car now
Posted 30th Aug 2009 at 21:13
eddy_gti6
well here is the manifold now on the car. not that you can see much LOL
Posted 30th Aug 2009 at 23:55
