displaying posts 51 to 75 of 79
Pages (4): first .. 2 [3] 4
Author Subject: *WORKING* Mappable PnP ECU...!
mabgti
NV motors
Post #51
good stuff... you know mine was available after our convo.. but carls is a fine example..
I'd change the map sensor for a cossie one (place after charger) if i were you.... not a good idea to map on vacuum and calculated boost if you've not done it before.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 30th Aug 2009 at 04:48
Post #52
nice Big grin will you be using the original map on the engine or the ecu's on-board one?
Posted 30th Aug 2009 at 04:49
luthor1
Post #53
My ECU will read the stock MAP sensor, but also has a 2.5bar one built in. You just switch a jumper inside to choose which one you're using, so for non-boosted cars use the car one, and for turbo/'charger cars flick it over to the onboard MAP and map up to 21psi. If you want more boost than 21psi, I can fit a 400kPA one!!
Kind regards
Andy
Posted 30th Aug 2009 at 05:46
nat205gti
Post #54
wow im really interested in these and i love the name too Smile progress looks good, il be keeping an eye out on this one.
ive got a 205 with 6 lump, inlet regrind and custome itbs. i have got an megasquirt ecu but no loom and dont think i could manage to map it myself lol
nat
Posted 1st Sep 2009 at 05:21
trell
Post #55
If i were to buy a unit of you, would u consider me being a seller for your ecus in wales? I have spent 100's of hours researching ECU's adn stand alone management that is far from plug in and play. I have a S2.5 gti-6 and i have been looking at an after market ECU that plugs in. In regards to the remapping could u send the software out so i can do it my self?
My problem is that i race my 306 but as it is at the moment its not economical but its stupidly fast but to pop down t he shop and get milk its not funny having to put a
Scorpion DEcat, Powerflow catback, Rebuilt head ( stage 1 ), Fast road Cams ( Kent ), Viper Induction, Cobra Monaco Pro's, OMP 10pt bolt in cage. port and polish 4 - 2 - 1 hi flow exhaust manifold and 200 kgs lighter
Posted 23rd Sep 2009 at 21:12
robthe6
Post #56
is this dead in water or still going?
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 17th Dec 2009 at 20:34
luthor1
Post #57
Ok - thread revival...
Hi there everyone, been a bit of a mental year my end (long story), but now got round to finalising the 306GTi PnP ECU!
I'm in need of someone near Southampton to allow me to hook it up to their car and do some testing!
I used Carl @ C&G last year so I don't want to go nagging him again if there is someone nearby to help out Smile
Hope someone can help!!
Obviously whoever helps will get a really good deal on a finished unit. PM me if you're interested Smile
Kind regards
Andy
Posted 11th Sep 2010 at 01:17
mark-house
Post #58
Hello mate was wondering what had happened to this. So how long will you need a car for?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 11th Sep 2010 at 02:59
309btcc
**DODGY SELLER**
Post #59
my car is currently with andy getting the ecu fitted and testd he knows his stuff ill keep you boys updated
Posted 12th Sep 2010 at 18:25
luthor1
Post #60
Hi all,
Just a quick update. I got the test-ECU working using the VR crank signal and CAM signal correctly. I've got the engine running, and I've got it running in sequential Coil On Plug ignition.
I'm just getting a couple of parts together to make the injection sequential too then the tests will be completed and the ECU ready to be made.
Yay! I'm starting to get excited!
There will soon be a Plug and Play 306 GTi-6 ECU running Sequential injection and Sequential COP, with launch control/flatshift, switchable maps and boost control available. Oh, it runs the stock idle controller too... and has a 250kPA MAP sensor onboard Smile
If anyone thinks I'm missing something, now is the time to float the idea!! Before I make a batch of them Smile
Will give more updates soon!
Andy
Posted 19th Sep 2010 at 02:02
Post #61
not using the stock o.e MAP? might be worth adding the capability for those using boost, as the 250 kpa onboard wont cope with 1 bar+ of boost will it?
sounds top notch otherwise, mapped up yet?
Posted 19th Sep 2010 at 02:09
rallyeash
Post #62
do you do bespoke wiring looms too?
im possibly looking at having a dash/body loom made for my 205.
Ash
309 3dr K20 Type R
Posted 19th Sep 2010 at 02:15
luthor1
Post #63
Hi,
yeah forgot to mention, the car's MAP sensor can be used, *and* the ECU is fitted with a 250kPA on for user choice, and it's switchable between them, so if boosted then use the ECU's one, otherwise the car's one is fine.
The ECU one will read and can be mapped up to 21psi positive boost. Other higher value sensors can be fitted to special order though, and calibrated, since the map sensor stage takes different 'innerds'
Mapping tomorrow...
Keep the questions coming, don't want to miss anything!!
Andy
Posted 19th Sep 2010 at 02:18
luthor1
Post #64
Ralyeash,
I tend to make PnP ECU's to prevent having to making wiring looms!
Seriously though, it's not something I've ever got into? What do you need making?
Posted 19th Sep 2010 at 02:21
Post #65
good stuff Smile
Posted 19th Sep 2010 at 02:28
rallyeash
Post #66
no problem, worth asking, basicly ive a track spec 205 which pretty much only runs lights so was looking into having a loom made for the car which only has what i need. i work in hampshire and everyday im always going up and down the m27 around soton so thought could be easy Smile
309 3dr K20 Type R
Posted 19th Sep 2010 at 02:30
luthor1
Post #67
Ash, I can certainly help out if you want?
Posted 19th Sep 2010 at 02:34
rallyeash
Post #68
do you have all connections, connectors, heatshrink, conduit etc to make a loom?
309 3dr K20 Type R
Posted 19th Sep 2010 at 02:49
luthor1
Post #69
Hi rallyeash, no I don't have any of that stuff but I'm just saying if you're local I'm sure we can sort out your loom for you
Posted 21st Sep 2010 at 21:49
luthor1
Post #70
I got the 306GTi-6 running fully sequential fuelling AND ignition today. Quite pleased!! I will now go through with the production Smile
Andy
Posted 21st Sep 2010 at 21:50
mark-house
Post #71
So how much are these gona be?
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 22nd Sep 2010 at 00:23
mabgti
NV motors
Post #72
good stuff mate, seems ages since we had a chat... pricelist?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 22nd Sep 2010 at 00:35
cwspellowe
Post #73
And also, speaking of mappers.. have you thought of contacting Ecosse? I know rich W has spoken to them regarding his supercharger kits, they may be interested in PnP ECU's and mapping too. Not sure if Rich has offered a preferred management system to them though..?
Would be handy for us boys north of the border too Yes
Bye bye Sundance Kid Sad
Posted 22nd Sep 2010 at 02:07
karoshi
Post #74
Handy for us Aussies too......
Bill
Posted 22nd Sep 2010 at 02:41
mark-house
Post #75
I had a look on his website and he is doing the 106 ecu's for £550 + £75 for mapping and fitting which i think is pretty good. Not sure if this includes a rolling road session tho.
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 22nd Sep 2010 at 03:49
