displaying posts 1 to 25 of 79
Pages (4): [1] 2 3 .. last
Author Subject: *WORKING* Mappable PnP ECU...!
luthor1
Hi there all,
I'm Andy, I run Datashift IT Ltd and I make bespoke ECU's for various cars. The main theme is that they are custom made and packaged to be 100% plug and play on the car, whilst future proofing your car against further modifications.
For example, whilst I will operate the stock idle valve, use all the stock sensors, MAP, IAT, CLT, TPS and so on, there is also a 2.5bar MAP sensor onboard for if you'd like to turbo your car, and it'll also support Throttle Body conversions, and superchargers.
I've successfully made and sold in the Saxo community, and I have many satisfied testimonials now, I've mapped a turbo saxo, and a couple with Throttle Body conversions, but mainly it's the uprated camshafts that prompt people to need management.
Anyway - since you 306 GTi boys have exactly the same ECU plug as the Saxo, to make the ECU run your cars is a little rewire, the addition of a 2nd VR input circuit, and sorting out your COP arrangement.
My ECU also works out the box with the Innovate LC-1 wideband controller, but can also be calibrted to work with any other wideband.
I can add (based on interest) launch/flatshift, closed-loop boost control, that sort of stuff!
So - anyone interested? If so, I'll need a volunteer to be a donkey, preferrably in the Southampton/Hampshire area, who will have an ECU put on their car and mapped up as a test/demonstrator. Obviously you will be paid petrol, plied with tea, and bacon sandwiches and will receive an enormous discount on one of the first units.
Also, you'll be able to write back to the group whether you think my product and I are any good!!
Here are some pictures of the Saxo unit, obviously the 306 one will look very similar!!!
ECU Pic Click here
ECU Pic 2 Click here
ECU Pic 3 Click here
Kind regards
AndyRazz
Posted 19th Sep 2010 at 02:03
Does the Saxo use the Magneti Marelli 1AP ECU of the GTi-6?
Posted 14th Aug 2009 at 01:51
luthor1
Yeah I think it does, but the important thing is the plug which I believe is identical Smile
Andy
Posted 14th Aug 2009 at 02:09
miles
You can give me a ring as I'm only local, A mate has said about you I think from the Saxo Forum's
www.pugracing.com
Posted 14th Aug 2009 at 04:55
craigy_87
hey andy, i'm a member on saxperience aswell nice to see ya moving over here
i mentioned you awhile ago on here but your much better at explaining than i ever could be lol
Posted 14th Aug 2009 at 05:01
chris with a pug
So basically you use your ECU instead of the OEM one and the loom stays the same?
What sort of money are we talknig? and could you be able to map say a supercharged one?
Posted 14th Aug 2009 at 05:14
luthor1
Hi craig - nice to talk again mate Smile
Miles - hi there, ringwood is just down the road! I am just off the M271 junction of the M27 so no distance for you Smile
Chris - yes, my ECU will plug in. Installation takes oh, maybe 60seconds. Then plug laptop in, go mapping!
The Saxo group buy for 10x is currently
Posted 14th Aug 2009 at 05:24
basically just like what KMS do already then Smile
Posted 14th Aug 2009 at 16:39
luthor1
No, well my understanding is that KMS requires an adapter loom which plugs in between the ECU and the car loom, and the KMS ECU is a 'generic standalone' which is configured to run whichever car it's put on.
My ECU does not have any adapter loom, the ECU contains the Motronic 55-pin plug which just plugs to the car, therefore the costs are significantly cheaper - check out the picture links in my first post Smile
My ECU currently runs at
Posted 14th Aug 2009 at 17:24
sorry, it was VEMS Doh yours is a hell of a lot cheaper I must say especially if each unit is mapped to suit, the VEMS ones come with a base map for each engine I believe.
Posted 14th Aug 2009 at 17:37
miles
One question I have on here which is always the killer and having worked in the Electronics industry before
Is what is your back ground ?
What Support, Warranty and Back up do you provide ?
Product Testing and re-liablity figure's ?
www.pugracing.com
Posted 14th Aug 2009 at 17:46
luthor1
Ah yeah - I know the VEMS unit. I'm not 100% certain, but I believe that inside their ECU they use a generic board but run wires to the plug. I don't think the plug connects directly onto the PCB (please correct me if anyone knows different!).
As for warranty - I offer a no quibbles hardware warranty, if your unit fails through no fault of the customer, simply return it and I will either repair the problem or just replace the board.
Usually I can send a replacement ECU with *your* map on it in the post so you're not without an ECU during the repair process.
Not that this has ever happened!! I did have an ECU back last week as part of the free hardware upgrade and turned it round in a day.
I now run closed loop idle control, so you just enter the target RPM for a number of coolant temperatures and the ECU alters the idle valve automatically, this required a little mod on some of the older ECU's out there.
The ECU on my Saxo has been running over a year, and easily 20,000 miles now without drama, and none of the Saxo customers have had hardware problems, or a failure!
My background is 10 years in the IT industry, and as a hobbyist tuner I've tuned over 40 cars of my own, and one day I realised that the Engine Management industry was making a black art out of something that should be straight forward.
It appeared to me that the ECU was the main stumbling block people had to overcome on their way up the tuning tree. By the time you're at cams you need management, forget turbo's and 'chargers!
Established management can cost over
Posted 14th Aug 2009 at 18:02
allanallen
Will you also be selling theses on a supply only basis, ie without mapping?
Will other rolling roads/mappers be happy to map them or will they turn you away like many seem to do with the megasquirt set-up? Cheers al
Facebook
Posted 14th Aug 2009 at 20:01
luthor1
When I say I do the mapping for free, I really mean that! There is no difference in cost to supply only or mapped.
I am in the process of getting various reputable mappers round the country onboard and happy to map them up, obviously most of them have their favourites, I just need to make sure mine is one of them Smile
Andy
Posted 14th Aug 2009 at 20:11
mabgti
NV motors
right... give me some time to read through all this... and PM me your number. interestingYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 14th Aug 2009 at 20:34
gti-si
You'll certainly have my business if you can get a mapper on board in the North
1990 Cherry Red 205 Gti-6
2000 Mitsubishi Galant V6
Posted 14th Aug 2009 at 21:18
luthor1
Mike at mikeanics has mapped up one of my Saxo units before, he's in Cheshire... he's a nice bloke! No frills mapping - he normally works on rally cars Smile
Mikeanics Website
Andy
Posted 14th Aug 2009 at 21:27
soton_s16
If Miles needs a car to use I'd be happy to help Smile
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 14th Aug 2009 at 21:32
24seven
I don't suppose you offer a similar product for motronic 4.1/1.3 ECU plugs do you? I know the 52 pin 3 row 1.3 is common on a lot of cars, but if you offered something that fit these plugs you'd be very popular on the 205 forums, and I'd definitely put my name down.
Posted 14th Aug 2009 at 21:38
clen666
hmm this is getting interesting! subscribed Dry
Team 'unintentional rat look'
Posted 14th Aug 2009 at 22:01
chris with a pug
luthor1 wrote:
EDIT: Chris - are you *in* Southampton????
Yes I am.
We need to talk I think LOL
Posted 15th Aug 2009 at 12:30
-sinden-
are you the one that does the predator ecu for saxo's on saxperience? if so the saxo boys are giving nothing but praises to your work
fixed my heaters and found out my aircon works Big grin
Posted 15th Aug 2009 at 20:09
luthor1
Hi Sinden,
yeah that's me over there Big grin
Kind regards
Andy
Posted 15th Aug 2009 at 20:35
-sinden-
thought it was you. i was one of the many waiting for the 3 plug vtr lol. any way top work mate and i can vouch that if the 306 ecu's are the same quality as the saxo ones then they are top notch.
Posted 15th Aug 2009 at 21:06
gti-si
Excellent, congletons only 30 mins down the road for me. When will these be available and what would be the final price?
I don't mind trying one out for you... Cool
Posted 15th Aug 2009 at 21:21
