displaying posts 126 to 150 of 280
Pages (12): first .. 5 [6] 7 .. last
Author Subject: Custom Cages at discount rates!
puglover Banned!
Post #126
Hyper cheers dude
Posted 10th Jul 2009 at 23:57
Post #127
you could take it to Giles Phillip if you are up north. i did enquire a few times with him but had no response, hence i took it elsewhere
Posted 11th Jul 2009 at 00:01
Post #128
Or you could buy a welder off me and fit it yourself Whistle
Posted 11th Jul 2009 at 00:03
puglover Banned!
Post #129
would be the worst idea of my life Yes
Posted 11th Jul 2009 at 00:06
Post #130
It's easy, a monkey could do it! LOL
Posted 11th Jul 2009 at 00:08
Post #131
i think phil said that even if i was a competent welder i'd have still needed some hydraulic pipe benders and a set of 3-point rollers to complete the job!
atleast it'll be a lot stronger in the cabin area now than a lot of things Yes plus have added a roof bar and gussets
Posted 11th Jul 2009 at 00:09
Post #132
I'm lucky enough to have access to those machines (not mine but I have a customer that owes me a favour or two) I'm hopeful however that after contacting them and going through the problems the firment issues will be cleared up. Heres hoping...Big grin
Posted 11th Jul 2009 at 00:14
chris with a pug
Post #133
wtf the a 3 point roller?
Posted 12th Jul 2009 at 00:40
Post #134
Tube rollers, 3 of them in a triangle formation, the two rollers go on one side of the tube, the lone one goes on the other. The clever bit is that the midle roller is pressed into the tube via a ram or screw an as the tube is fed through the rollers it gets bent. Simples Big grin
Posted 12th Jul 2009 at 00:47
Post #135
Lets you do long arcs instead of bends - so you can roll a tube that follows the windscreen top and bottom perfectly for example.
You'd get away without 'em, we just used them to put a tiny little bit of roll on the dash bar to get it fitting spot on, and make sure it fires the dash away from you in a big shunt.
I wouldn't fit another one though, even if they sort the hoop issues, there were other niggles. For me, it'd be faster just to make one from scratch, rather than keep having to fettle theirs together until it fits.
Be fine for someone installing at home though, it just took more time than usual, but I'm sticking to fitting SD cages! LOL
Least Jim's welding should be the best of the lot!
Posted 12th Jul 2009 at 04:41
Post #136
No pressure LOL Unfortunately my juob involves more talking about welding than ACTUAL welding so we'll see how well it goes in practice.Unsure LOL
Posted 12th Jul 2009 at 04:58
Post #137
LOL
I expect it to be perfection!
We can get good, strong welds with good penetration every time, but making it pretty is an artists work with a nice TIG setup (hence the email about the new TIG order!).
So it better be pretty or we might stick with that little MIG Razz
Posted 12th Jul 2009 at 04:46
Post #138
No Nails Ultra it is then!
Posted 12th Jul 2009 at 05:01
Post #139
Yeah, I'm not worrieed about the strength side of things either, I know my welds are fine in that respect. I havent decided on a process yet tho, MIG is deffinitely faster but TIG does look the best, Hmmm
Posted 12th Jul 2009 at 05:02
Post #140
MIG the tube joints, TIG the floorpan and gusset plates.
Hope Rikky doesn't mind me putting these up, might be giving away trade secrets, look at the lightweight invisible bonnet! LOL
Here's how I spent my Friday night, 5pm, thinking about a nice, cold pint and a night out, start work:
Oh dear, 11pm, chances of cold pint receding faster than hairline, still tweaking tubes:
2am Saturday morning, can't remember what that 'pint' thing was, but last bit of welding, woo!
Tow car outside up to little workshop, pack tools up, fall asleep in chair in corner of workshop...LOL
Ooh look, the moon:
Posted 12th Jul 2009 at 05:13
Post #141
If I fire up a one of our synergic pulse migs I can probably put in a double pulse programme that will give me the overlapping bead effect you get with tig anyway, best of both worlds. Big grin If I get the settings right that is...
Posted 12th Jul 2009 at 05:07
Post #142
Not got a lot to practise on is the problem, and to cheer you up, all the tubes are different thicknesses, especially in the cross in the back, for no apparent reason LOL
Stop replying before I've finished editing the old post LOL
Posted 12th Jul 2009 at 05:11
Post #143
The things we do for money, you should have seen the look on peoples faces when I walked into my local Indian to pick up my tea after that polishing job on friday, they were all staring at me with their mouths open. When I got home I saw that my face was as black as the ace of spades from all the polishing soap that gets flung around! LOL
Post #144
What size MIG wire do you use Phill?
Posted 12th Jul 2009 at 05:14
Post #145
LOL
Grinding dust is just as much fun, or that lovely bit of weld spatter as you fire the MIG up when it's not quite set perfectly, which promptly finds the only hole in your clothing and rattles down your sleeve to burn a hole in your elbow...
edit: 1mm in the little MIG, 1.2mm in the bigger 'un
Posted 12th Jul 2009 at 05:18
Post #146
phillipm wrote:
LOL
Or better still falls in your earhole when your jammed under something with no hope of moving, leaving you little choice other than to sit there grinding your teeth listening to it sizzle as you wait for it to cool down!Angry
Posted 12th Jul 2009 at 05:16
Post #147
LOL
That must happen to every poor bugger who has to pick up a welder at some point.
Posted 12th Jul 2009 at 05:19
Post #148
Got myself a nice proban hood now, looks like shite but at least it keeps what's left of my hair from catching fire and sparks in the ears are a thing of the past. Wave Thumbs up
Posted 12th Jul 2009 at 05:22
Post #149
Meh, no hair anyway!
Posted 12th Jul 2009 at 05:26
Post #150
LOL I'm not at such an advanced stage of follical retreat yet, so I'm keen to look after what I've got left!
Posted 12th Jul 2009 at 05:31
