displaying posts 76 to 100 of 106
Pages (5): first .. 3 [4] 5
Author Subject: 306 GTi-6 > 205 GTi-5 Project
paul_13
Post #76
It's probably possible that you could chop the 6 one up, it'll be better to use as most 205 DP's have a split down the middle.
I was looking at your bottom pulley, it looks alot different to mine, is it a std 6 one?
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 8th Dec 2009 at 02:49
306andy
Post #77
Its a genuine Magnex Decat pipe mate, just a case of getting the rest of the system shortened to match and welded in place.
As for the Bottom Pulley, as far as i'm aware its OE mate
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
xbox Live tag: SilverGTi6
Posted 8th Dec 2009 at 04:22
allesclar
Post #78
nice thread Smile
Team allesclar ®
Posted 8th Dec 2009 at 04:34
306andy
Post #79
Right, Brakes....
I'm currently running the Standard GTi-6 Front Brake setup, coupled with a 406 Non-ABS Master Cylinder. I've replaced the Amp Valve above the Vac Pump as it was in a few bits :S and i've bled the system today with a mate.
Now, without the engine running, pressure is there and the pedal is solid, yet upon starting the engine, the pedal sinks to the floor. There is very little pressure at the end of the travel, but when i turn off the engine, the pressure is back!???
I've read about adjusting the pushrod in the Servo but would a 1-2mm (22.2mm - 24.2mm adjustment range IIRC) really make such a difference considering the pedal travels a good few inches further? (4-5")
Any help or opinions would be greatly appreciated
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 10th Dec 2009 at 00:43
nick205gti6
Post #80
I wouldnt be too hopeful your driveshafts wont be noisyI Ive yet to hear a set of 'repaired' driveshafts that are silent.
1990 205 GTI-6
Posted 10th Dec 2009 at 01:07
306andy
Post #81
Thanks
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 10th Dec 2009 at 01:09
paul_13
Post #82
306andy wrote:
Right, Brakes....
Thats odd...
Whats this amp valve you talk about?
I've got 307 hdi brakes on 406 mc, didnt change anything just bolted it on an it worked.
Is this existing setup a 1.9 or 1.6 system?
Posted 10th Dec 2009 at 03:38
306andy
Post #83
The amplifier valve is the small plastic black and white piece that takes the vac off the pump. It links into the inlet manifold and the servo.
The system is a 1.6 Paul.
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 10th Dec 2009 at 03:43
paul_13
Post #84
It does sound like there is air in there still, I had a similar problem and had to bleed the bottom 2 pipes on the MC first and then bleed the 2 pipes near(er) to the engine. This was doing them at the same time.
How long did you allow the fluid to p!ss out for?
I take it you have 4 pipes coming out and no blanking plugs
Posted 10th Dec 2009 at 03:50
306andy
Post #85
Err...a whole bottles worth Razz
Yeah it has 4 unions on the M/C mate
I've bled the system for a good hour today and the symptom still persists.
Faulty M/C?
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 10th Dec 2009 at 03:52
paul_13
Post #86
I see rule out air then, sounds like a faulty MC.
Is it new or s/h?
Posted 10th Dec 2009 at 03:56
306andy
Post #87
its second hand mate. I'm tempted to just buy a new one from Peugeot if its gonna sort the brakes out
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 10th Dec 2009 at 03:57
paul_13
Post #88
Wouldn't half arse with brakes lol
Get 'em sorted properly lad
Get stuck or owt feel free to pm and i'll try n' help
Posted 10th Dec 2009 at 04:06
306andy
Post #89
Its never been a "half-arsed" attempt mate, but I fully understand your point. I appreciate your help thus far and i'm sure over time i'll drop you a PM or three.
I'll phone Peugeot tomorrow and get it ordered in. If it doesn't sure the problem, at least i can tick it off the list, meaning i'm one step closer to having it on the road
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 10th Dec 2009 at 04:13
306andy
Post #90
Black eye Err....
Hmmm....
I currently feel as stupid as they come. Its been a complete oversight on my part, i take full responsability for my lack of sense....
Wizard I FORGOT THE REAR BRAKES NEED BLEEDING TOO! Sheeeeeeeeeeeeeeeeeeeeeeeeeet!!!
*fetches coat* Doh
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 11th Dec 2009 at 02:19
paul_13
Post #91
HA!
HA!
HA!
Sorry had to laugh
HA!
Posted 11th Dec 2009 at 02:36
Post #92
Laugh my ass off
Posted 11th Dec 2009 at 03:59
miles
Post #93
DOH, LOL
But the 306 D/P do fit but it doesn;t fit well if you know what I mean, Easy way is just use a re-angled manifold and 205 D/P without the split in and job done and no driveshaft issue's either
www.pugracing.com
Posted 11th Dec 2009 at 06:04
spiky
Post #94
i run a 205 D/P with split, and never caused me any issues Big grin
i reangled mine a second time, after i mounted the engine in it's not position and i cut the split out, as not much was holting it on.
DOH on rear brakes, easy fix though Big grin
i would get some GKN shaft's fit and forget Big grin
i persoannly would not use the STD fuel lines to then fuel rail, as they prone to leaking,
if you are going to use them, put come jubilee clips on them Big grin
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 11th Dec 2009 at 14:47
306andy
Post #95
Right! Time for a mini-update i guess:
I'm still struggling with the brakes! They just don't want to play ball at all.
I've bled them, front AND rear, starting with the furthest nipple from the M/C and working forwards. I've changed over the vac pump amp valve which was cracked. I've double checked all the lines go to opposite corners on each side of the M/C. I've adjusted the pushrod in the servo, and now i'm all out of ideas...
Other than that its done. The exhaust is fitted, it holds both water and water temp (fans cut in), hold both oil and oil temp. Its finished, bar the f**king brakes!
Any ideas???
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 19th Jan 2010 at 20:46
spiky
Post #96
whats wrong with the brakes?
MY YouTube Videos'
Posted 19th Jan 2010 at 21:12
Post #97
how fast does the fluid come out of the rear nipples when you pump the pedal?
Posted 19th Jan 2010 at 21:28
sport1901966
Post #98
If your thinking bias valve I had the same problem - definately worth a check
Posted 19th Jan 2010 at 21:44
paul_13
Post #99
Are there 4 lines coming out the MC? No blanking plugs that could be holding air behind it.
Are you using the one man bleeding kit or a mate helping you?
Bias valve is all I can suggest otherwise
Posted 19th Jan 2010 at 22:46
306andy
Post #100
Err nothing like the fronts I guess? Its reasonably slow in comparison. They are drums though if that makes a difference?
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 20th Jan 2010 at 00:04
