displaying posts 51 to 75 of 106
Pages (5): first .. 2 [3] 4 .. last
Author Subject: 306 GTi-6 > 205 GTi-5 Project
paul_13
Post #51
LOL I get you.
What driveshafts are you using 205 items?
Although the 306 ones fit aswell
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 26th Jul 2009 at 05:07
306andy
Post #52
paul_xiii wrote:
LOL I get you.
I am using the 205 ones indeed
How do the 306 ones fit? I thought they'd be far too long?
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
xbox Live tag: SilverGTi6
Posted 26th Jul 2009 at 05:08
paul_13
Post #53
They are too long indeed but they fit in the gearbox.
Has the gearbox had an aftermarket diff fitted?
Posted 26th Jul 2009 at 05:10
306andy
Post #54
No no no Paul, its only the tripod/roller collar that won't fit in the female ends. (hopefully you understand what i mean or i'll be fetching the ol' MS paint skills out!)
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 26th Jul 2009 at 05:12
paul_13
Post #55
LOL the CV end then...
None of the roller bearings have fallen out/getting in the way?
I've learnt the hard way a few times with it coming apart lol.
Posted 26th Jul 2009 at 05:14
306andy
Post #56
At one point they had fallen out, yet I have fitted them back together (oh what a joyfull occasion that was Big grin ). Its possible that some of the needles have come loose again and are blocking its path Dunno
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 26th Jul 2009 at 05:16
paul_13
Post #57
LOL Oh what joy you must of had!
I'd scoop all the CV grease out and have a good look around. See if anythings lying around.
What gearbox is it 1.9?
Posted 26th Jul 2009 at 05:22
306andy
Post #58
Yeah its the 1900 gearbox
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 26th Jul 2009 at 05:25
paul_13
Post #59
Do the driveshafts only go in half way or not at all?
Did you do the wiring or buy a loom off Spiky
Posted 26th Jul 2009 at 05:27
306andy
Post #60
they go in a little bit but won't go any further.
I'll be sending the loom off to spiky upon the arrival of July's paycheck
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 26th Jul 2009 at 05:28
paul_13
Post #61
Sounds like somethings in the way...
Spikys a top geezer, v. helpful with any problems that might arrise, shouldn't be any problems though should be plug and play Wink
Just be wary that if that starter comes on with the second click of the key, the constant live and switched live are the wrong way round.
Just a case of swapping to wires in the brown multiplugs, easy to do Big grin
Posted 26th Jul 2009 at 05:32
fripper
Post #62
Very nice project indeed, to bad we have all kind of laws here in Finland who prohibits us from moddin/changing the engines in ours car.
Love my 306 GTI
Posted 26th Jul 2009 at 22:51
paul_13
Post #63
Any luck with the drumsticks?
Posted 27th Jul 2009 at 03:58
cliff7110
Post #64
looks like a good project.
was just looking back on page two at the master cylinder. will it hit the cam belt guards/rocker cover when coming on/off throttle?
Posted 28th Jul 2009 at 00:36
306andy
Post #65
Paul - Not yet, not been over there yet. Been too busy sorting some family issues out.
Cliff - I guess only time will tell but its on solid mounts so movement will be minimal.
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 28th Jul 2009 at 02:10
paul_13
Post #66
It should be alright with solid mounts, mines got bugger all play in it, just reangle the pedal box or take a file to the cam covers (metal/plastic bits)
Posted 28th Jul 2009 at 17:09
306andy
Post #67
Well I guess its time to update this thread, its been a few days since I last updated...
As most of you know, i've been struggling with the driveshafts Sad
Not anymore! Big grin
The Passanger side slid straight in, as the strut would come away from the hub on this side. Yet the drivers side was more troublesome...alas both shafts are fitted now!
That done I started work on the Coolant System, namely a T-Piece off the Header Tank
Then I finished the fuel system off completely, well very nearly....i just need a connection between the two feed pipes and its a go go!
Yes its untidy at the moment, but i endeavour to tidy the whole car up once its up and running
Then I fitted the Thermostat housing and the top hose ready to be modified
And finally, I lowered it back onto its wheels! Big grin Big grin Big grin
I'm man enough to admit it was an emotional moment knowing that it is essentially mobile again
Then I just gave the wings a bit of a wipe over as they were greasy and oily...
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 5th Aug 2009 at 22:02
captaink
Post #68
Good job ! Big grin
When I got home last night, my G/F demanded that I take her somewhere expensive - so, I took her to a petrol station.
1993 L reg 205 with GTi6 engine and GTi6 brakes
1995 M reg FTO GPX manual
Posted 6th Aug 2009 at 18:04
paul_13
Post #69
I don't know why I havent recieve any suscription emails from this any more. Nice project hope the PM about the exhaust helps
Posted 6th Dec 2009 at 14:33
306andy
Post #70
Right, i guess its time for a bit of an update...
Since August, i've:
Fitted new Gear Linkages
Fitted a BakerBM Thermo Adapter
Fitted the Radiator
Finished off the coolant system
Finsished off the Driveshafts
Fitted new Droplinks
Reworked the fuel system (had it the wrong way round)
Fitted an Oil Cooler
Fitted the Fan Assembly
Fitted the reworked bumper (for the oil cooler)
Swapped the Brakes over off the GTi-6
Fitted a new Brake Amplifier Valve (old one was in 3-pieces)
Fitted and Drilled the bonnet Wink (still awaiting the pins!!!)
Various Pictures in no particular order...
Next up is getting the Brakes bled, but owing to my shift pattern, its sometimes difficult to grab someone to help me do them.
Then its a case of getting the exhaust finished (thanks Paul Smile)
....oh, and its running now Big grin
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 7th Dec 2009 at 00:46
spiky
Post #71
hi dude,
great progess, nice idea with the oil cooler.
replied to your pm, sorry if it's to late
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 7th Dec 2009 at 00:52
paul_13
Post #72
Nice pics and good job with the oil cooler.
How you tensioning the belt? Or is that way you kept the PS pump?
Posted 8th Dec 2009 at 01:35
306andy
Post #73
I'm keeping the Pump mate. Just running a bit of hose to return back into it Smile
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 8th Dec 2009 at 01:38
paul_13
Post #74
I see, have you started the exhaust yet?
I warned you a few tools went flying when I did mine
Posted 8th Dec 2009 at 01:48
306andy
Post #75
No Paul, I've been at work all day today. Depending on the condition of the 205 Downpipe, i may make a start tomorrow....Or use the 306 Downpipe Devil
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
Posted 8th Dec 2009 at 01:50
