displaying posts 351 to 375 of 394
Pages (16): first .. 14 [15] 16
Author Subject: AST Sportline I. coilovers!!!!! please read!
Post #351
from AST LOL
Posted 28th Oct 2010 at 02:30
chris with a pug
Post #352
Really? Wow thanks
Any one got a number for them?
Posted 28th Oct 2010 at 02:29
Post #353
AST
Posted 28th Oct 2010 at 02:31
clen666
Post #354
theres a number on the right of that contact form chris
Team 'unintentional rat look'
Posted 28th Oct 2010 at 02:35
Post #355
Posted 7th Dec 2010 at 02:39
Post #356
i hope you fall off the road and the zx goes to shitroen heaven Dry
Posted 7th Dec 2010 at 03:14
dead_poetic
Post #357
have you had these set up long enough on your car to give these a rating?
  • Alexisonfire - Happiness By The Kilowatt
  • 36 Crazyfists - Northern November
  • [bullet]Poison The Well - Lazzaro
    Posted 7th Dec 2010 at 04:21
    Post #358
    nope, done about 15 miles on dodgy roads LOL
    will only really be able to compare them against tired standard dampers and Koni dampers really as I have no experience of anything else on my car.
    I did drive Adam's rallye that has stiffer springs than these though, and they really didn't feel that stiff at all when you consider the spring rate was over double the standard one.
    (mine were an Ebay purchase, intended for a 206 rally car and specced with 171 lb springs, an epic price and I am going to try them as they are for now, get them re-valved and stiffer springs if required)
    Posted 7th Dec 2010 at 04:28
    dead_poetic
    Post #359
    LOL well i've only ever experienced standard and spax, and the rallye is sitting on standard at the mo. just couldn't get on with the spax that i bought. i don't mind spending a pretty penny as long as it's the dogs' bits Big grin i'm just scared of spending money on something i could potentially hate!
    Posted 7th Dec 2010 at 04:39
    Post #360
    ahhh I've experienced those on someone else's car, its safe to say these are a world apart LOL (in a very very good way)
    Posted 7th Dec 2010 at 14:38
    t5 hdj
    Post #361
    Mine are fantastic. Highly recommended here.
    WANTED: Mint crystal headlamps
    Posted 7th Dec 2010 at 20:44
    Post #362
    My fronts (impreza) are being re-valved next tuesday as they aren't damping enough - James the new guy learning the ropes Doh
    On my second set now and even with the slightly bouncy front end they do work very well. I think my 306 on reflection needed stiffer rear springs (was standard) to get the balance right, but it still cornered and handled well.
    Posted 8th Dec 2010 at 18:48
    Post #363
    You'll have to try Mine Adam, so far so good but haven't been pushing it, seems to be a bit more pointy and adjustable on throttle.
    Posted 8th Dec 2010 at 21:44
    Post #364
    anyone know how long the 306 kit springs are and the damper stroke?
    Posted 8th Dec 2011 at 18:37
    Post #365
    Give them a ring and ask...
    Posted 9th Dec 2011 at 09:55
    Post #366
    good shout LOL
    Posted 9th Dec 2011 at 10:22
    atterz
    Post #367
    Gonna send a PM when i get chance. Speak about spring rates etc Adam on the wallye!
    owain wrote:
    Posted 9th Dec 2011 at 14:06
    Post #368
    What did you wish to know..?
    Posted 9th Dec 2011 at 22:55
    atterz
    Post #369
    Things such as spring rates, the TB size you would have preffered to go for etc. I really want a new beam for it. The welded on ARB endplate is funny and all of the handbrake cable mounts are snapped and cable ties dont last long.
    After reading RussianGuys thread and also looking at the AST website would a twin spring system of benefitted you? The handling on the Rallye is ok but there is somthing that definatly isnt right!
    Posted 10th Dec 2011 at 12:48
    Post #370
    It was good with straight 285s, but I'd probably go 240ish on reflection.
    I would get the beam sorted then consider the rest after.
    Posted 10th Dec 2011 at 16:25
    atterz
    Post #371
    With what size torsion beams? Fast road and Beginner track usage come the new year? The ARB will still be fine wont it as the end plates detach?
    Posted 10th Dec 2011 at 17:37
    Post #372
    Should be ok yes.
    No idea really, people seem to go for 21mm and they are readily available. Depends on the front springs you currently have and what dampers you are hoping to use.
    Posted 10th Dec 2011 at 19:52
    atterz
    Post #373
    I currently have the avo GTZ setup. And i have no idea what the spring rate is on the fronts but i have had them bottom out with me. This is with the height set to coinicide with the rear beam which i assume hasnt changed height since you had it? I wouldnt mind 21mm TBs or slightly bigger and would have to change the rear dampers i would imagine?
    I went in a track prepped 306 the other day that had 400lb springs front with 21mm rear and the car handled brilliantly in my mind! The dampers are only cheapo shitty Raceland ones though!
    Posted 10th Dec 2011 at 20:06
    Post #374
    AFAIK the end plate was not welded when it left Adam, just had an M12 bolt holding the l/h one on rather than an M8 due to the threads being damaged by the poor fit of the Hybrid ARB to the end plate.
    It was standard 20mm hence the comment that 240lb would be better possibly.
    400ft and 21mm rear is a tad imbalanced, would be even better with stiffer bars (I've driven a 205 with 200lb ft and standard 19mm rears, bloody awful!)
    depends how you like the car to behave though.
    at the mo I have 180 ish ft 23mm rear, I do have some 228's but I think they may be too short.
    Posted 10th Dec 2011 at 20:43
    fatlapit
    Post #375
    They aren't cheap shit like Gaz matey...
    with gaz gold coming in at £800????
    Posted 4th Jan 2012 at 13:08
