displaying posts 26 to 50 of 169
Pages (7): 1 [2] 3 .. last
Author Subject: Phase 1 Supercharged Track Weapon
farmer
UPDATE:
Driveshaft oil seals have been changed, driveshafts back in, and gearbox oil re-filled.
Roller bearing wishbones are now fitted with new balljoints, and replaced a knackered track rod end.
Sump and gearbox all cleaned up with degreaser, a wire brush, and an old toothbrush.
The leak the car has had since I have owned it has been resolved now too it would appear in faffing about with everything Big grin
It was back on its wheels on Saturday afternoon, so I then set to sorting out hacking about the dash.
Cut my panel to sit in the centre console area, will get a pic up of this tomorrow.
Dash and wiring have been installed tonight and I have finished removing the tar crap from the scuttle area and re-painted it 1st coat.
Will get a 2nd coat in the morning before I go to work (if its not raining) and ill refit the wipers tomorrow evening, along with mounting the centre console panel, with switches and gauges (or the ones I have anyway).
Then that just leaves me to shape the roll cage mounting plates ready for the weekend when I am hoping they can be welded in and the cage bolted down.
Car will be insured again as of Saturday Hyper
Sooo looking forward to driving this; not been out in the 6 since the end of Jan!
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 10th Jun 2009 at 04:48
rikky wrote:
interesting on the weight. i must get mine weighed, it's had so much removed i have lost track of what's even left
There's some corner weights down here if I can prise them out of Guy's hand for ten minutes...
Posted 10th Jun 2009 at 04:45
farmer wrote:
You even got the PAS and ABS left in yours Rich?
no all long gone, nothing left tbh
phil i have a contact at a paper weighbridge which is very accurate, i was just wondering what it was *roughly*, think the p1 is about 1200 standard. nevermind, another 50kg going in it!
farmer
So are you running your steering rack dry then or did you get a non-PAS rack? presumably if its a non-PAS rack then its not shortened on the right lock?
I weighed my P1 before I started and it came out at 1200Kgs bang on, but it wasn't full of fuel.
Fuel corrected, it came to 1230Kgs, but this was a sunroof model so would have weighed more to start.
XBL ID: farmer uk1
Posted 10th Jun 2009 at 04:50
i am running it dry at the moment, and removed everything completely, and made up some unions with sealed ends to keep shit out of the rack
dont forget my car is 5spd and xsi subframe/rack..
there really is nothing left atall, although it's painted inside so that's added a touch of weight. really gone to town removing brackets and namely wiring and stuff. the PAS and ABS was the heaviest bits i think, the PAS has all sorts of guards and pipework hidden, the pump and also fecked the idler off. quite a productive week actually, few bits on order so it should start looking like a car again soon! plenty to do though, suspension needs attention, opening an account with phillipm soon.. 90 days credit apparently..
makes me sad lookign @ pics of it a few years ago with the gti6 interior and black cyclones, i think "wow what have i done to it Sad" but nevermind!
Posted 10th Jun 2009 at 04:56
farmer
Ahh yes, forgot about that little fact.
I did contemplate ditching the hydraulics when it was all drained down for the s/c fitment but I didnt know if the rack would be very happy running dry.
Would a dry PAS rack feel heavier then a non-PAS rack does anyone know? Contemplating putting a lower model's non-PAS rack on the car and using a friendly MOT tester...
XBL ID: farmer uk1
its about comparible with my D reg 1.9 gti in terms of steering feel.. LOL i have turned into a muscle warrior overnight
Posted 10th Jun 2009 at 04:57
farmer
For a change I have done one area of the car before you then, regarding suspension LOL
Start off your project thread, I need to steal some of your ideas Razz
XBL ID: farmer uk1
Posted 10th Jun 2009 at 04:59
I just filled mine with oil before bunging the ports up...
Posted 10th Jun 2009 at 05:02
Post #35
yeah i thought about doing that until i rounded a union off when i slipped screwing it in..
Posted 10th Jun 2009 at 05:04
Post #36
LOL
Post #37
is having no PAS on a PAS-born car even a failure?! (if that's what you mean?)
i'd have thought if it's there it's tested, if not then they can't test it! same with the ABS
or you mean if it catches on lock but so you can keep your box? (just weld a stopper on)
Posted 10th Jun 2009 at 05:15
Post #38
So long as the unions are properly sealed off so dirt can't get into the rack it should be fine.
Posted 10th Jun 2009 at 05:16
Post #39
http://www.rikky.net/upload/bare.jpg
(old pic tho)
so much more room to work on things with all the shit gone. i remember trying to change the pipework that goes into the thermostat in the dark last year when it blew in Chatsworth leaving me stranded, batery tray etc all in the way, impossible
Posted 10th Jun 2009 at 05:22
Post #40
Even more room with a weeny 1.4 under there LOL
Posted 10th Jun 2009 at 05:34
dhampton
Post #41
Is it possible to cure the fuel starvation problems with ph2/3 parts? I remember driving a ph1 and getting fuel starvation on a gentle motorway bend! I thought I'd broken it! Laugh
Clio 182 FF 306 Rallye (track) 306 Gti-6 Megane R26 Clio 172 Cup (track) 106 Rallye S2 (track) 306 Rallye Saxo VTR 106 Zest2
Posted 10th Jun 2009 at 14:31
farmer
Post #42
Im sure someone around here had changed a ph1 tank / pump / level assembly for a ph2/3 but im not sure who tbh.
I did contemplate it, but after looking into it a bit, I think it will be less grief just to put a swirl pot in tbh.
XBL ID: farmer uk1
Posted 11th Jun 2009 at 04:46
daw5on
Post #43
Wasn't it Birk that did this on the Dimma
Cotton Villiers 1967 (Just fully restored)
1988 Yamaha Ty250 Mono (being Built)
Yamaha TY80 (In bits)
Peugeot Speedfight 50 (Daily Ride)
Posted 11th Jun 2009 at 04:50
birk
Post #44
Twas me Yes
Although i have ph2 wirring in the car now.
The ph1 tank has two seperate holes, one for the pump and the other thing i dont know what it is
Where as the ph2 tank just has the one hole with the pump, so the wirring is a little different.
I have a swirl pot ready to fit, but i got raped for a inline fuel pump from america a few months back and have yet to buy another Sad
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 11th Jun 2009 at 05:45
smighall
Smeg-all
Post #45
I assume the second hole in the Ph1 will be for the level sender Dunno
Meh
Posted 11th Jun 2009 at 06:07
birk
Post #46
That would make sense yea Thumbs up, obviously the ph2 pump has it built in with the teabag type device at the end of it.
07889376885
Dan
Posted 11th Jun 2009 at 06:12
6waysforward
Post #47
did the ph1 not have a level sensor(float) built into the pump then??
Posted 11th Jun 2009 at 16:29
birk
Post #48
Dont think it did!
07889376885
Dan
Posted 11th Jun 2009 at 16:34
Post #49
I does on some of the very, very early cars with the little bosch pump (which sits right in the bottom of the tank with a teabag filter and doesn't suffer the fuel starvation issues)
Posted 11th Jun 2009 at 16:42
6waysforward
Post #50
havin never owned a ph1, i dont know but i am on a quest to find out.
im goin to the scrappy later so i will rummage about.
Posted 11th Jun 2009 at 16:44
