displaying posts 1 to 25 of 51
Pages (3): [1] 2 3
Author Subject: ZX 16v Turbo Project
robertinho
Hello everybody,
it's my first post here, sorry for my poor english, but let's try...
I'm doing some modifications on my 97' ZX 16v, here in Brazil it's called Dakar.
I'm chasing pure performance, it explain the turbo choice
this is like it was, 6 months ago
the first step was the exhaust manifold, made in stainless steel, in order to use a big turbo we decided to fit the turbo in the battery's
original location.
due to manifold's size it is divided in 2 parts, easy maintenance too.
this was the firt stage of the project, the worst, 4 months to conclude,
next step: front mount intercooler, 3" pipes, 3" downpipe, 3" exhaust
http://www.belquip.com/produto/1043
then the car finally was going to my mechanic.
we passed a lot of night working on the car, new seals, bearing, belts, rings, oil pump, water pump, etc... changing everyhing possible in order to garantee a lit bit more of security.
I didn't know yet, but there was a lot of mistakes on the exhaust manifold, it was the main reason of my problems,
firt, i couldn't use the water pipe localizated on the back side of the engine, the pipe that circulates water trough thermostatic valve, i needed to isolate that pipe and the litle gate on the radiator, eliminating the thermostatic valve.
second, the wastegate was too close of the water entrance, we need to make a new one, we used the opel vectra's flange.
when the engine was opened and dismantled we tryed to upgrade every single details, as head's flow, manifold's flow, more press on the oil sump, etc...
some pics of the extense work.
we done all the turbo work of pass new fuel lines, turbo oil catch and return, air boost / vacum lines, etc
a ugraded fuel pump fitted in tank fills an external surge tank and from this surge 2 external fuel pumps sends the alcool to the engine.
fuel press is regulated by a HPI regulator, increases the fuel press acording manifold's boost.
(red one near the right headlamp)
the car uses a alfa 164's oil radiator, fitted on the foglight housing.
on the suspension i'm using eibach springs, upgrades original shock (40%+ harder), superior town sway bar, P.U inferior.
Here in Brazil we don't have any upgrade to our car, so we need to develop EVERYTHING!
EBC TGD Brakes discs, Fiat Marea Turbo's EBC yellow stuff pads (perfect mount, bigger contact area) aeroquip lines, DOT 5.1 fluid.
ceramic clutch, 1200 lbs to support the new torque
well, this is my little project, it's not ready, this we i'm going to make a dyno run to calibrates the car. using perfect power smt6
this is how the car is actually,
when i remember more details i'll report here, any questions i'll try to explain!
Posted 8th Mar 2009 at 20:41
looks very sleeper-ish Ninja tidy work!
Posted 8th Mar 2009 at 20:45
Cracking work there mate Thumbs up,and your english is alot better than most british members! Laugh
Posted 8th Mar 2009 at 21:06
cool
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 8th Mar 2009 at 21:09
lemones
Can't wait to take a ride on it!
Sleeper-ish...and maybe one day it'll be the basis of my Xsara VTS (for the European Members, I'm another Brazilian dude who has a XU10J4RS). This Dakar was "well-born" one that already used to rock. Now, it'll be a Heavy Metal Track/Street car.
Congratulatons on it...and I'm quite sure during these months, you were abso-f*cking-lutely wishing to see you bloody project working...STRONGLY!
Any help, you know I'd go give a support.
XU10J4RS Xsara VTS
Posted 8th Mar 2009 at 21:18
chris with a pug
That is one big turbo you have there. What clutch is you you are using
Posted 8th Mar 2009 at 21:39
nev6
judging by the size of that turbo this isn't going to be a low boost conversion, are you fitting forged pistons and rods?
if not i wouldn't expect it to run for very long
ex team astor
still team miami 205 gti-6
Posted 8th Mar 2009 at 22:43
Hmm I was just wondering what rods and pistons are being used ? surely you would of had to use low comp forged pistons and rods ??
Posted 8th Mar 2009 at 22:56
mabgti
NV motors
im liking that.. great work on the manifold and i'd be eager to see how versatile the smt6 isYes
think its gonna be an alcoholic high boostYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 8th Mar 2009 at 23:08
robertinho
the factory is called "Displat
Posted 8th Mar 2009 at 23:25
robertinho
the turbo is a specific Garret
.50/.70
axles/rotors .60
the intention is a big turbo to get boost only at high RPMS, it's better to put the power on the road and i like more progressive cars, the intention is rev 8000RPMs
Posted 8th Mar 2009 at 23:32
robertinho
for this stage it's everything stock, now will be a basic car, 0,7 bar, i want to develop the car in the track, more boost with this suspension/transmission setup will worse the track performance.
i'm trying to import a Quaife, just after after install Quaife and R888 that i will think in upgrade the torque/power.
Posted 8th Mar 2009 at 23:36
robertinho
the car actually is "driveable" just with a inicial tunning in the HPI fuel regulator, this week my mechanic with do a fine chip tunning in the DYNOJET, he garantee that it will be enough to get to perfection.
if we can't tune the car than we will install the SMT-6!
Posted 8th Mar 2009 at 23:39
vts_tibi
that turbo is bigger than my 2.5 STI's LOL Blink
I want to see a video of this beast out of a tight corner, just when the turbo spools up -> tooooorque steeeeeeer (but it's hell of a fun LOL )
VTS
best 60' : 2.272
Team Trackday™
Posted 9th Mar 2009 at 00:13
nev6
so your running low boost with that turbo? surely a smaller turbo which spools up quicker would be far more progressive and more driveable? the turbo lag on that must be immense!
ex team astor
Posted 9th Mar 2009 at 00:35
robertinho
when i get the car i'll post the video, you will get surprise.
the turbo is "spooling" earlier as i was planning. full boost around 4000 rpms!
Posted 9th Mar 2009 at 03:51
edsonmassao
Insane project from an insane owner. Too much pals are waiting anxiously to see this running, and we expecting good results with low boost, big turbo and ethanol Smile
Posted 9th Mar 2009 at 04:31
vts_tibi
is there an avarage person in Brasil?
Thiago with the nitrous VTS (200hp shot Blink )
George with the turbo VTS (same stuff as this ZX)
Rafael with the other ZX beast
(what are you guys smoking? seems like a decent stuff! Farmer )
VTS
best 60' : 2.272
Team Trackday™
Posted 10th Mar 2009 at 02:24
binkagti
How much power are you planning to run? around 600bhp at a guess?
And you say you are going to run standard internals but on low boost, even so i blew apart uprated wossner conrods with just 400bhp, imagine what you will do with this lol.
Good luck to you mate
TEAM Supercharged Rallye
Posted 10th Mar 2009 at 20:30
vernam616
lovely Turbo............ sorry but not a fan of the ZX at all, grandad car IMO just out curiousity, is it Astor Grey?
Audi S3 Black Edition
Posted 11th Mar 2009 at 01:38
robertinho
I am planning around 350whp, i think it's the structure limit, more then this i'll need to make big changes in suspension/ structure and gearbox.
DaLuz offer us a XU forged KIT, IAPEL piston and TFC rods, if a change my mind this will be internal...
Posted 11th Mar 2009 at 07:51
robertinho
i agree with you, but we don't have more than 20 GTIs in brazil, and the ZX is very cheap, i like ZX because it is very ugly and squared, everybody gets surprised when tries to chase hehehe
I don't know the paint name, the code is ETWER
Posted 11th Mar 2009 at 07:59
mabgti
NV motors
350whp on standard internalsConfused
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 11th Mar 2009 at 20:14
vladimir
Roll eyes
My citropug (ZX+306)
vladimir has attached the following image:
Posted 11th Mar 2009 at 20:26
zxturbo1905
cool carLove
i hand two 5dr zx's before movin to pugs, just a quick question what ball joints do you use on your zx?
cause i used standard ones from citroen and they only lasted two weeks at bestUnsure
pug 205 1.9 GTi(limited)-g492 umb- sold.
pug 306 1.9 dturbo- stage 1 tune, straight through exhaust and GTi6 brakes, rear beam, bosch pump and injectors, 101bhp atw and 155ft-lb atw LOL.
"no smoke no poke"
Posted 12th Mar 2009 at 05:31
Pages (3): [1] 2 3
