displaying posts 26 to 50 of 51
Pages (3): 1 [2] 3
Author Subject: ZX 16v Turbo Project
robertinho
what is ball joint?
that little bar the connects stabilyzer bar to the shocks?
Posted 12th Mar 2009 at 07:39
vladimir
zxturbo1905 wrote:
cool carLove
i hand two 5dr zx's before movin to pugs, just a quick question what ball joints do you use on your zx?
cause i used standard ones from citroen and they only lasted two weeks at bestUnsure
never had problems with them. What was standard ones - citroen\peugeot original?
Posted 12th Mar 2009 at 14:12
zxturbo1905
vladimir wrote:
zxturbo1905 wrote:
cool carLove
never had problems with them. What was standard ones - citroenpeugeot original?
they were from citroen and cost about
pug 205 1.9 GTi(limited)-g492 umb- sold.
pug 306 1.9 dturbo- stage 1 tune, straight through exhaust and GTi6 brakes, rear beam, bosch pump and injectors, 101bhp atw and 155ft-lb atw LOL.
"no smoke no poke"
Posted 12th Mar 2009 at 20:16
zxturbo1905
robertinho wrote:
what is ball joint?
balljoint is the bit on the wishbones/bottom arm that has three bolts through it.
"no smoke no poke"
Posted 12th Mar 2009 at 20:18
mabgti
NV motors
that citropug looks well odd! is it just bolt on?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 12th Mar 2009 at 20:19
vladimir
No, there was a lot of work.
http://www.youtube.com/watch?v=N-Fzg8GRqWs
vladimir has attached the following image:
Posted 12th Mar 2009 at 21:29
robertinho
the car is already running,
0,5 bar,
0,78 wide band lambda (is it very hot round here these days)
the car is very progressive, full bost around 4000 rpms and it has torque until 7200 (ignition cut)
i will post a video, next week it goes to a dynojet to make a perfect chip tunning and 0,7 bar.
i'm very happy, the car's behavior is exactly as i wanted
Posted 16th Mar 2009 at 04:40
mechanical_repairs
You Sir are mental, looking good though.
Carl
Posted 16th Mar 2009 at 13:35
robertinho
First Dynojet Run:
310 whp @ 6500 rpm
34 kgfm @ 5500 rpm
using 0,7 bar!
Posted 24th Mar 2009 at 06:28
[l\'e$kro]
Post #35
Sweeeet!
I sent pictures of your manifold to my manifold builder
I like the idea of it being in two parts, to avoid having to remove the engine all the time
what's next? is the engine still in one piece or did you slip on the pressure tap?
Nicolas
205 gti xu10j4rs
ms2 extra sequential
Posted 10th May 2009 at 15:13
robertinho
Post #36
the mechanic is still 100%,
drag racing every day in the highways.
the problem is the gearbox, it broke firt time last week, the 4th gear, but the piecs destroyed ALL the others gears.
i put a everything new and was everything ok, this weekend me and my friends went to a drag event, 201 mts, just for fun
some videos:
http://www.youtube.com/watch?v=0GKW_pglG8U&feature=related
http://www.youtube.com/watch?v=L0knNhnKr6Y&feature=related
Posted 11th May 2009 at 05:10
[l\'e$kro]
Post #37
I'm afraid your BE gearbox wont cope with over 300bhps and will break again and again
The only reliable solution is to fit a ME gearbox from a xu10j2te engine. You'll have to make a custom gearbox mount under the turbo and make driveshafts out of ZX outer halves + 605 (or xm ...) inner halves. You'll also have to make custom gear linkage rods.
Send me a PM if you want more infos about this, as this conversion has been made by at least 3 people here in France
Nicolas
205 gti xu10j4rs
Posted 11th May 2009 at 16:13
dr-evil
Post #38
Awesome video's - rolls gently off the line then annilates the scoobies lead and passes it - all in third gear LOL
Is the engine stock internally or have you now upgraded to forged rods and pistons ? I know that with ethanol you can get away with higher compression ratios but is this running a spacer to drop it ?
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 12th May 2009 at 23:34
[l\'e$kro]
Post #39
I think he's running standard compression ratio (standard block)
I presume in Brasil they have e100 ethanol without having any petrol in it, which helps avoiding detonations
Nicolas
205 gti xu10j4rs
Posted 12th May 2009 at 23:59
robertinho
Post #40
exactly, stock internal, 10,8:1 compression rate, running on ethanol, stock gearbox, stock fuel injection.
my turbo is very big, the torque comes only at high rpms, very progressive, it helps the engine to don't explode hehehe.
I really want to make a onboard video, but nobody wants to get a ride with me...
Posted 13th May 2009 at 01:52
daviewonder
Post #41
Nicolas
does it need a custom gearbox mount? ive got one in a 205 and it uses the standard mount.
Why is it that shoe repairers are so good at cutting keys? - Harry Hill.
Posted 13th May 2009 at 02:47
greenbelt
Post #42
Robertinho clicky 1
Robertinho clicky 2
Standard Black 6
Black HBSC6 Smoke
Posted 13th May 2009 at 04:23
o_tateuk
Post #43
Loving the sleeper look! Nice work mate! Cool
Ex team china wish i hadnt done it but oh well.
Now saving up the dollas for a nice bianca rallye! May the search commence!!!!
205 1.8 Derv! (The work run slag) Big grin
2nd 205 but with D-Turbo power! Big grin
Posted 13th May 2009 at 04:33
robertinho
Post #44
hot news,
I've got an Evasion 2.0 Turbo Gearbox! hehehe
now starts the process of addapting on the XU, I liked the car running 1 bar, very strong.
If anybody could help me with many photos about putting the gearbox on a XU I would appreciate.
Posted 13th May 2009 at 19:13
tom tom go
Tom Tom GONE!!
Post #45
By all means if you want someone to film it, get my a flight ticket out there and ill sit in your passenger seat all day long sir ! LOL
Anyway, good luck with it, you off your tits, but good luck and i lookforward to the updates ! Big grin
Cherry RALLYE
Posted 13th May 2009 at 20:38
cuemanlew
Post #46
ithink he means has anyone done the gearbox conversion! he wants pictures to help him!!
THE PRODIGY
khj100 wrote:
Beginning to think you're taking the **** now.
Could you at least try to post in the right section, and try using the search before starting new threads. All the information you want already exists and it'll elicit a much more positive response from the rest of the members on here if you put a little more effort into researching yourself before asking daft questions.
Posted 14th May 2009 at 03:47
robertinho
Post #47
Nicolas is helping me a lot, send me some pictures/projects,
m
e and my mechanic are studing how to do, because it is a big change, clutch, flyweel, mounts, axles, rods, etc... and it will be an experience
we don't know nobody who have already done it, so we don't know if the result will be good.
Posted 14th May 2009 at 04:09
robertinho
Post #48
hello everybody,
i've already addpted the evasion's gearbox,
it was VERY difficult to addapt everything, i had to build a lot of parts.
but the stuff is working!
i'm runing 1 bar on stock internals, stock ECU, ethanol and 404 whp on Dynojet.
a few pics of the car actually
(this is a site of my friends, all these are street cars)
http://www.racingstyle.com.br/dakar.html
Posted 27th Aug 2009 at 01:56
robertinho
Post #49
bad news,
unfortunelly I sold the car last week, good times toogether, but was time to go..
good news,
I put the car on Dynojet again, result: 442 hps on the wheels using 1.3 bar.
The gearbox didn't break again. I used the car like this for 6 months !
some video:
http://www.youtube.com/watch?v=wORZhvEfHqQ
I bought another zx 16v, and I'm planing to build an 205 XU RS to have fun on the tracks!
Posted 25th Jan 2010 at 11:43
[l\'e$kro]
Post #50
Too bad you had to get rid of it...
1.3 bars on standard internals with stock compression ratio? Who said the rods are weak on the Xu10j4rs?!
Impressive car
can't wait to get news about your next project
Nicolas
205 gti xu10j4rs
Posted 25th Jan 2010 at 16:24
Pages (3): 1 [2] 3
