displaying posts 76 to 100 of 610
Pages (25): first .. 3 [4] 5 .. last
Author Subject: Supercharged Dimma
al4x
Post #76
going to need a grinder to cut the welds to move that cage
Posted 10th Mar 2009 at 22:08
birk
Post #77
Yea, thought as much LOL
Wont be messing with the cage for a while, i should have the new coil pack soon, so gota get that sorted when i have a spare 5min, im at college 2moz and working thur and fri, then on sat, the old engine will come out, needs to be done pretty soon to take it to bodyshop to be jigged
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 10th Mar 2009 at 22:25
gtisid
Post #78
That is how a cage should be fitted, have mentioned it a few times on here in the past as a lot of track day guys seem to think it is ok to weld directly to the floor and should the car ever roll the cage leg will punch a hole straight through the floor, also enables the cage to sit higher up in the cabin so you dont crack your bonce everytime you get in and out of the thing
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 10th Mar 2009 at 23:03
rallyestyle
Post #79
You have indeed mentioned it a few times Yes I now have some pics i can work too Ninja
Just Drive It
Posted 11th Mar 2009 at 20:50
Post #80
It's a bit worrying that the rear part of the cage not only has a plate welded to the chassis that it's been bolted to, but has also had the bolting plate (which appears to be too thin anyway) welded over afterwards...
And why has the cage moved at some point?
Posted 11th Mar 2009 at 20:55
al4x
Post #81
thats only the mount thats not welded and has moved after he's taken the bolts out I think
Posted 11th Mar 2009 at 21:04
Post #82
my god what an abomination of a cage Sad
Posted 11th Mar 2009 at 21:15
Post #83
No, the plate is welded to the stiffening plate too?
And it's bent like a banana....
Posted 11th Mar 2009 at 22:26
birk
Post #84
The back bit on the arch has been welded to the stiffening plate and is bent yea phill.
Guess im just guna have to grind the weldes off the cage and see if i can move the fooker, what a ball ache LOL
07889376885
Dan
Posted 11th Mar 2009 at 23:39
Post #85
i seriously would rip that shell to bits and start again, f*ck that cage off!
maybe its just me but when i see one thing untidy i presume something else isnt right and would pull it apart
Posted 11th Mar 2009 at 23:49
birk
Post #86
But ive gota take the back arches off and risk fooking them up, plus i'd need a donor car, which i cant afford, im also not allowed 2 cars at home at once LOL and i wont be allowed to strip both of them down either, as much as i'd love to swop all the bits over onto a blank canvess, its just not viable realy
07889376885
Dan
Post #87
donor car doesn't even need to be a gti6 though...
Posted 12th Mar 2009 at 00:39
4doorgti
Post #88
Hey, i think the work your doing Birk is great, will be lovley when its finished..
I do think though you could save yourself money & time with this beauty, its the "Proper" Dimma as well
http://www.pistonheads.co.uk/classifieds/935630.htm
lol LOL
aaronBig grin Big grin Big grin Smile Big grin Big grin Big grin
4doorgti has attached the following image:
Posted 12th Mar 2009 at 05:00
brownboy
Post #89
LOL
Posted 12th Mar 2009 at 04:53
hman205
Post #90
as far as I know the cage was fitted by Star Garage in Plymouth and I don't think Deejay was tatally impressed think they had the car nearly a month
I see the new rear lights have made it on already lol LOL
Another Broken one
Posted 12th Mar 2009 at 20:37
jcphat
Post #91
Birk- there it is- already fully developed and turbo rather than supercharged- what a relief for you no need to do all the difficult good taste and cool things just buy a rolling jukebox with
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 12th Mar 2009 at 20:59
rallyestyle
Post #92
So lets get this straight, the front mounts where the cage bolts to the box looking mount welded to the floorpan are ok?
The rear mounts that are bolted and welded to a mounting plate which in turn is welded to the arch are gash Dunno If the cage mount wasnt welded but just bolted to the mounting plate would that be ok?
Cheers all Thumbs up
Just Drive It
Posted 12th Mar 2009 at 21:16
Post #93
The questions you need to ask are:
1) Why is the rear bolt-in mounting plate so thin
2) Why, when they already have a reinforcement plate welded in, have they then had to weld the cage in as well as bolt it down?
3) Why is it bent........
Posted 12th Mar 2009 at 21:18
birk
Post #94
I managed to get the cage seperated today and get the dash half out before i got annoyed and gave in.
I had to grind the welds off the bits at the back of the cage, undo all the bolts and go nuts with a hammer and chizel LOL
My quaife LSD arrived today aswell, so im please with that Smile
Im working tomorrow, so i shall be working at the weekend, will have the dash, engine and wiring loom off by sunday i reckon, then it can go to get jigged Smile
07889376885
Dan
Posted 12th Mar 2009 at 21:31
SteviePut
Post #95
FFS haven't you finished this yet??? Whistle
Posted 12th Mar 2009 at 21:53
bennywidag
Post #96
Boxes on floor are also another way to have shorter legs, so you can sight and weld on the backstays around the top, then weld in the main loop.
Another way is to make a hole in the floor for the hoop legs, then you can drop the arms through to weld the top of the backstays.
Its seems like a bolt in though so im talking cack.
1.9DTurbo
Childminder of 2.0 4WD Cosworth Maxi
www.nur-motorsport.co.uk for Carbon Bits.
Posted 12th Mar 2009 at 22:28
marksorrento205
Post #97
What front and rear suspension is it running? Or is it std with spacers?
Posted 12th Mar 2009 at 23:51
birk
Post #98
Wide track conversion, the wishbones are wider, aswell as the shafts, track rod ends, pugsport suspension
back is standard i think with just wider wheels to suit
07889376885
Dan
Posted 13th Mar 2009 at 00:16
avirally
Post #99
Birk if you get new wheels and you want to sell the old wheels i might get them off you as one of mine is kerbed thanks avi
1995 306 maxi the best fwd car ever build
Posted 13th Mar 2009 at 02:36
birk
Post #100
Wont be selling them for a while tbh fella
Got the driveshafts off today, they dont look very good, ever so thin, solid ones maybe??? they need new CV boots, and they dont seem very stable, so im on the look out for some new ones some how.
Anyways... this is how i got on today
I also got these this morning for
07889376885
Dan
Posted 15th Mar 2009 at 00:46
