displaying posts 26 to 50 of 51
Pages (3): 1 [2] 3
Author Subject: engine flush question
24seven
There we go then get the oil well up to temperature and let it drain thoroughly without using a flush. Big grin
Posted 1st Apr 2013 at 02:31
beez_neez_gt
Is this now a war against buzz and gilesy as reposting their old threads again and again or what ??
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 1st Apr 2013 at 07:02
I'd use the flush, people worried about contaminating their new oil are getting in a flap over nothing. The very idea of flushing oil is that it's thin enough to drain down almost completely therefore leaving almost nothing behind, it should also carry any sludgy crap from the sump that would normally stay put with a normal oil change.
If you you don't use a flushing oil, you get more of a contamination from the old dirty oil clinging to every surface within the engine mixing with your new fresh oil.
Posted 1st Apr 2013 at 09:27
Completely disagree to be honest, would never touch the stuff. No
Posted 1st Apr 2013 at 10:07
I know what flushing oil is for and the benefits, that's why I use it. I even rinse out my coolers and blow air down them and the remote pipes to get rid of every last bit of old oil I can. I jack the car up unevenly too so the drain plug really is at the lowest point on the engine.
Given the choice of two teaspoons full of oil thinner (what flushing oil is) or two teaspoons of old carbon and metal impregnated oil left over inside the engine at each oil change I know which I choose.
Posted 3rd Apr 2013 at 13:58
I see what you're saying Jim, but I have to say that my engine oil is not contaminated when I drain it as I do it regularly. Yes
i.e. Every 1000 miles.
Posted 3rd Apr 2013 at 16:17
aaron6
I do mine every 7k miles and when it comes out its nearly as clean as when it went in. I have to say, I understand the principle of the benefits but if theres a chance I may actually damage an engine using it, I simply wouldnt. Id just change the oil with cheaper stuff, drive a bit and then drain that and use the good stuff.
Posted 3rd Apr 2013 at 16:55
Then your comments aren't really relevant to someone who changes their oil yearly or at 10,000 mile intervals? They will have contaminated oil and sludge in the sump, and will benefit from using a flushing agent.
Posted 3rd Apr 2013 at 16:58
That's ridiculous, flushing oil doesn't damage engines, as for wasting good engine oil by using it as a flushing agent, that's madness.
Just before oil change time, get the car hot, switch off, pour in a can of Wynns engine flush, fast idle for 5 mins, drop sump plug. Leave for a good hour to fully drain down. Replace filter, top up, fire up, stop engine, check level, fill as necessary, forget for 6,00 miles, simple.
Posted 3rd Apr 2013 at 17:01
Post #35
I just get the engine hot after a drive, drop the lot out whilst it flows like water, bugger the flush.
I might pour half a litre of cheap atf or whatever I have to hand straight down from the head to wash out any oil that's still clinging if it's been a while since the last change, but that's about all.
Posted 3rd Apr 2013 at 17:17
Post #36
Atf is a flushing oil though? Thin oil, good detergent properties, picks up all the grime and drains down well as it's thin.
You've basically just said I don't flush, then said you do LOL
Posted 3rd Apr 2013 at 17:30
Post #37
Nah, I don't run the engine on it, I just put a bit through the top to push out the old stuff that's clinging, ATF if it's at hand, just some normal cheap oil if not, or part of the bottle of new oil that's going in.
It's all pretty damned thin when it hits the hot block that's been out for a thrash Big grin
Posted 3rd Apr 2013 at 17:37
Post #38
Like Phill said, just get it bloody hot then drain it straight away, comes out like thinners, unless its a diesel LOL
Posted 3rd Apr 2013 at 17:47
Post #39
I wouldn't worry about idling an engine on flushing oil, I've seen engines run with no oil at all but just using friction modified additives. I'm not saying it's a good idea, but a fast idle with a can of flush added, then a good drain down won't do any harm to your engine whatsoever. I wouldn't want to drive it with the flush added though, certainly not hard anyway.
But this is more aimed at people who miss oil change intervals and do lots of stop start town driving than motorway mile munchers or cosseted racers that get attention lavished on them and regular changes of fresh golden oil.
Posted 3rd Apr 2013 at 17:50
Post #40
*touche*
Is there any need to be so aggressive? In this modern day and age, most engines run very clean, engine flush is a thing of the past now IMO. Yes
Posted 3rd Apr 2013 at 17:54
honestly3k
Post #41
As mine is mostly a motorway cruiser, I try to change my oil every 10k or 3-4 times yearly LOL
As said I just take it out, give her a roasting then dump the oil. Seems to come out with no issues.
My brother is a fan of using that ATF and running his car/gearbox with some of it in for a week then dumping it....he swears by it but ive never tried so cant really comment there!
Posted 3rd Apr 2013 at 17:58
Post #42
Depends how you read it Stan, it's just stating a fact. A rebuilt engine that gets serviced at 1,000 mile intervals will be in no real need of a flush. (I probably still would as the Royal Purple racing oil used in SC applications is thick as treacle, but that's just me)
However, as we are seeing in more than one thread of late, in the main, the rest of the guys on here do things a little differently to you, in as much as they use their cars on a daily basis, rack up some serious miles, and I'd go so far as to say some will even skip service intervals, thrash from cold and use cheap, or inferior oils. These are the people who would benefit from a flush and they are who my suggestions were aimed at.
You are special and exempt from normal generalisations.
Posted 3rd Apr 2013 at 18:03
Post #43
I wouldn't run the car on the ATF for a week, you can get foaming issues where it meets additive packages of normal engine oil, at most just let it idle on it, or just pour it through with the block hot.
Posted 3rd Apr 2013 at 18:14
Post #44
^^^ I'm pretty sure most flushing instructions don't recommend you drive with the flush added, fast idle for 10-15 mins max is usually the instruction on the tin.
Posted 3rd Apr 2013 at 18:24
Post #45
Probably don't, but I was responding to Honestly's comment about his brother....Big grin
Posted 3rd Apr 2013 at 18:32
honestly3k
Post #46
Its probably not advised but in said week he wont do that many miles, maybe 100...his cars always perform better than standard on the rollers so cant be that detrimental Smile
Swears by it for cleaning up the gear change on a notchy gearbox also
Posted 3rd Apr 2013 at 18:58
Post #47
Yeah, I can see where you're coming from with that Jim, it does make sense for people whom treat their engines with rather less respect than they perhaps should. Yes
This made me LOL
Nice one. Cool
Posted 3rd Apr 2013 at 19:00
Post #48
Works well on notchy boxes because it's quite thin compared to normal gear oils and has a controlled friction level.
Posted 3rd Apr 2013 at 19:10
Post #49
So your basically saying that you never change your oil
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 4th Apr 2013 at 20:11
Post #50
This made me LOL
Nice one. Cool
When I bought the car i didn't know how it was treat the last few years and it also had a slight tap when warm(not a tapper) that's why I thought I'd try it.
As said though now I have a nice New engine and I know it's cherished I wouldn't consider it.
Posted 4th Apr 2013 at 20:23
Pages (3): 1 [2] 3
