displaying posts 1 to 25 of 51
Pages (3): [1] 2 3
Author Subject: engine flush question
ive got some new oil and filter from pug and also have a engine flush.
is it better to add it then take it for a run?
or add it and just let it tickover for 10 mins??
then drain and refill/sweap filter.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th Feb 2009 at 14:44
al4x
how about reading the instructions on the tin Whistle
Posted 26th Feb 2009 at 15:05
drew o
let it tickover for 10minutes if its the wurth one they give but make sure the engine is warm before you put it in
306 GTi-6 In Moonstone FTWBig grin
Team Speedline Turini
PS3-Drew_o
Posted 26th Feb 2009 at 15:06
stella artois says anjoy responsibly on the tin but most people dont!!!!LOL
i was just wondering if it would be better taking it for a quick run or letting it tick over for ten minutes, thats what it says on the tin!
Posted 26th Feb 2009 at 15:11
drew o
warm it up for 5 minutes then put the flush in for 10, drain and refill Smile
PS3-Drew_o
Posted 26th Feb 2009 at 15:23
will do that, thanks drew
Posted 26th Feb 2009 at 15:25
jose
your better off getting 5l of flushing oil if you really want to do it properly:
Flushing Oils These are very thin oils so never drive your car with these oils in the engine as it will not last very long. These oils are designed to clean out the deposits in the oil ways of your engine. To use them, drain the oil engine oil but leave the old filter in place. Fill up with flushing oil and then run the engine at fast idle (very low load) for 20 to 30 minutes then drain the oil and see what comes out.Change the oil and filter and then fill up with your preferred engine oil. Be warned using flushing oil can sometimes do more harm than good especially in an old engine ( in most classics) as the flushing oil removes deposits which have built up over the years, these deposits can seal up parts of the engine (sump gaskets, head gaskets and even seal the piston rings). Once the deposits have gone the engine can leak or worse blow past the pistons rendering the engine scrap.
Nile Blue GTi6
Alpine White 205 GTi 1.9 - Project
Air Con Pipes Thread.......
Machine Polishing - Paint Correction - Swirl Removal in West London - PM for details
Posted 26th Feb 2009 at 23:11
jcphat
Top advice jose- my dad was an engineer who dealt with a lot of old style engines classics as you describe them- and he would never reccomend flushing- a week of every day motoring with supermarket oil and a new filter and decent oil is as far as you should go. A 6 engine unless very worn should be ok with flushing but never drive with flushing oil!!
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 26th Feb 2009 at 23:26
I'd never use engine flush - just let the car warm up then drop the oil ? If you do it more regular intervals you will never have any reason to use that thinin crap Smile
Posted 26th Feb 2009 at 23:31
ok ive done the engine flush today, and i wouldnt want to drive it to end of road and back, it sounded awful 10 mins after the engine was ticking over with the stuff in.
Posted 27th Feb 2009 at 00:22
Suggest you take it out asap put in some new oil then change it again after 500 miles Wink
And the filter !
Never do it again !
Posted 27th Feb 2009 at 00:26
i allready have mate, i left it ticking over with the engine flush in for 15 minutes then drained in adn changed the filter and refilled with nice new shiny stuff!!
i said i wouldnt want to drive it to the end of the road and back with that in, not that i had, and i certainly wouldnt of left it in, it was what peugeot dealer gave me so i was more confident in using it then i would of with motor spares shop stuff.
Posted 27th Feb 2009 at 00:37
its seems to run much smoother and sound beter now ive performed the flush, dont know if its phychological or not as ive not had the car out for 3 weeks till the other day, but it is a total pleisure to drive again.
Posted 1st Mar 2009 at 15:51
drew o
it makes alot smoother accleration and flow of oil so should feel much better to drive Smile
PS3-Drew_o
Posted 1st Mar 2009 at 22:08
gtisid
why the alarm bells about flushing the engine bowen?
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 2nd Mar 2009 at 22:59
he thought i had taken it for a spin with the flush in and then left the flush in, as i asked if this is what i should do, after hearing the car running with it in after 20 minutes i said i wouldnt want to drive it even to the end of the road with that stuff in, it sounded terrible after 20 mins!!
sounds much beter and smoother now, im sure its added a bit more bottom end torque
Posted 2nd Mar 2009 at 23:42
gilesy
Is it better to leave it for 10 or 20 minutes in your opinion?
Posted 29th Mar 2013 at 18:06
Thread from the dead... Surprised its not been deleted!!LOL
Posted 29th Mar 2013 at 18:20
Better not to use it at all imoThumbs up
Can't see the need, my engine is knocking on the door of 100k miles and the oil stays very cleanSmile
Posted 29th Mar 2013 at 18:21
gilesy
Your engine is knocking??
Posted 29th Mar 2013 at 18:23
Couldn't agree more Kev. Thumbs up
Posted 29th Mar 2013 at 18:24
NoWink
But yours will be if you put flush threw it!!!!LOL
Posted 29th Mar 2013 at 18:26
I can't even remember using it, oh well I have a new engine now anyway
Posted 30th Mar 2013 at 23:07
24seven
As Kev said, really this is something to avoid using! Am I right in thinking some '6s have oil temperature gauges where the oil pressure gauge (as I have on my phase 1) would otherwise be?
If you don't have an oil temp gauge, just waiting until the coolant is up to temperature isn't enough - if you let the engine get hot enough for the fans to kick in (i.e. not only is the coolant in the engine itself hot, but the entire cooling system is too) then you're getting there, but even then I'd keep going a little bit to make sure the oil is nice and hot before draining it.
With the flush stuff, you can never guarantee that all of the oil thinner will drain out of the engine, so when you fill it back up your fresh oil is compromised right from the start.
Posted 31st Mar 2013 at 02:57
Yep, Phase 2 and 3 have oil temp gauges on the dash. Yes
Posted 31st Mar 2013 at 08:01
Pages (3): [1] 2 3
