Author Subject: knocking from rear
burnvaler
just got 1998 306 122k miles i have a loud knocking noise when going over bumps,its just past a mot last week any suggestions where to startWink Wink
Posted 16th Feb 2009 at 16:38
jonnyvandijk
Rear axle bushes by the sound of it. There are four in total, and just cost me
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
Posted 16th Feb 2009 at 16:41
burnvaler
could rear axle bushes cause knocking while driving/how could i check
Posted 16th Feb 2009 at 20:13
notch000
spare tire craddle loose ?
Posted 16th Feb 2009 at 20:21
jonnyvandijk
Get under the car and have a look, or failing that get a mechanic to have a look. Usually the rubber comes unstuck from the metal part of the bush, and bangs on the bolt which attaches the whole lot together.
Posted 16th Feb 2009 at 20:43
aaron6
Sounds like the beam mounts indeed.Change them for the solid baker ones from miles on here.
Posted 16th Feb 2009 at 21:17
jon kirby
quote:
and just cost me
Posted 16th Feb 2009 at 21:31
burnvaler
supported car on axle stands and used trolley jack under shock bottom mount and when i lifted jack found front rubber bush moved up approx 5mm should ther be any movement,does this mean it needs changing rea rubber mount han no movement.should i change all 4 or just the problem one
Posted 16th Feb 2009 at 23:14
burnvaler
back end very loose under cornering i take it this is a definite worn rear bushes i will change all
Posted 17th Feb 2009 at 14:43
cress87
Could be a rear shock clunking too...
Posted 17th Feb 2009 at 14:46
bennn
I had this same noise and it turned out to be the rear beam mountings. Cost me
Cherry Red 306 HDI
Posted 17th Feb 2009 at 18:49
jonnyvandijk
bennn wrote:
Cost me
Posted 17th Feb 2009 at 19:11
burnvaler
ordered full setof rear bushes will change all at weekend
Posted 17th Feb 2009 at 20:19
jonnyvandijk
Lets hope its definately the bushes then.
What car have you actually got? Your profile says other.
Posted 17th Feb 2009 at 20:42
burnvaler
r reg 1.9td goes well
Posted 18th Feb 2009 at 00:28
rich-6
Can't have had anything quick then Whistle
Cool
RIP Pete Sims
Posted 18th Feb 2009 at 00:38
burnvaler
not really but its quick enough for me
Posted 18th Feb 2009 at 11:44
burnvaler
just changed all 4 rear mount simple enough job,used guide on this forum thanks .they didnt look that bad so i thought i wasted money but the knocking noise is gone now good result
Posted 21st Feb 2009 at 22:41
blondie
Dirty Diesel Pro
Do you have to disconnect the rear brakes to do this? (pipes or handbrake)
A 306 EnthusiastWink
phillipm wrote:
But diesel is the devils fuel Devil
Ps3 IDRazzhils306
“S-H-I-T-H-O-L-E.. Shithole!”
Posted 22nd Feb 2009 at 15:01
gtisid
if it is your bushes i have a virtually brand new set that i removed from my car 3 -4 months back . genuine O/E front mounts and oldish looking rears but still intact you can have them all for 65 inc postage
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 22nd Feb 2009 at 19:22
willygti
No.
Team Ducati 748
2003 Subaru Impreza STi
Posted 22nd Feb 2009 at 19:23
paul_gti6_uk
Sounds like this is my problem then. I have a knock coming from the rear mostly under sudden cornering loads or when the suspension tops out.
What is odd is my rear mounts are only 15,000miles old and they are genuine pug ones. I have done one track day on them but I wouldn't think that would have destroyed them that quickly would it?
At 95,000miles old I am getting worried the clunk noises might be because the bearings inside the beam need changing.
China Blue 306GTI-6 Big grin Ph3
Team Now Bikeless Sad
Posted 8th Jan 2010 at 15:47
Sad
Posted 8th Jan 2010 at 23:41
lotek
most likely bearings mate, is the beam lowered? if so then its even more likely.
i have the same problem amongst others. just gotta wait for the snow to go before i put my new beam on Sad
Posted 8th Jan 2010 at 23:48
paul_gti6_uk
I have a set of solid mounts sat under the bed waiting to be fitted. Got them last year but havent gotten around to fitting them yet.
Lotek I am worried it is what you say though and yes the rear end was lowered about 15000miles ago. I'm just not sure how you distinguish the knocking noise between bearings and rear mounts failing.
Posted 13th Jan 2010 at 01:13
