Author Subject: Help!! - Driveshaft Seal
willygti
Having a nightmare getting the correct driveshaft seal for the drivers side (the smaller one that goes into the speedo housing).
Basically the one i want looks like the one pictured below with the white insert but peugeot are saying that the part number listed for all 306 gti's is 312144.
I bought this yesterday, and surprise surprise it has no insert. Just called them now and they confirmed all seals are the same throughout the range and the part number listed (312144) doesn't have the white insert Crazy
This is what they should look like:
And this is what i've been given:
(picture uploading)
Team Ducati 748
2003 Subaru Impreza STi
Posted 14th Feb 2009 at 15:49
willygti
Problem solved finding Pete's old thread (here after a more extensive search) Big grin
Seems they've updated the seal.
Team Ducati 748
Posted 14th Feb 2009 at 15:54
that looks 100% fine Smile
I don't think I've ever seen the larger one with an insert.
Posted 14th Feb 2009 at 16:39
im sure the one that i bought not so long back had been changed from the original that was allready in there, the newer one doesnt look as good as the original does it, although by the sounds of it, its been improved
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 14th Feb 2009 at 17:52
willygti
Team Ducati 748
Posted 14th Feb 2009 at 20:10
yes, they come out easy enough
Posted 14th Feb 2009 at 19:50
whats with the edit willie, are you embarresed about having to ask how to remove them seals, its nothing to be ashamed of dude
Posted 15th Feb 2009 at 01:25
chas
Anything I should look out for when changing the seal? I'm doing my passenger side lower arm tomorrow, and figured I best change it considering that the seal is 'misting' (not a bad leak, but it is weeping a little).
It looks straightforward, but as always I like to be prepared Smile.
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 20th Feb 2009 at 06:15
miles
Wrong, Both seals should look like the one on the left, the pattern (GSF, ECP etc)parts normally look like the ones in your picture and I've found leak too often so I always use the OE ones
www.pugracing.com
Posted 21st Feb 2009 at 01:07
silky
So all new OE seals are the black rubber type ?
Having changed my driveshafts last week I now have a leak, so going to have to do the seals ASAP.
Easy enough to get in and out ?
Posted 31st Mar 2009 at 12:55
yes matey, well easy
Posted 31st Mar 2009 at 13:38
silky
Do you just get your fingers in there and pull them out sort of thing ?
Posted 31st Mar 2009 at 13:49
dave
or carefully with a screw driver or similar object for leverage.
Posted 31st Mar 2009 at 14:35
silky
Is it the same seal for both sides ?
Posted 31st Mar 2009 at 14:37
willygti
No, both sides are different mate. Ones slightly larger than t'other Wink
Team Ducati 748
Posted 31st Mar 2009 at 14:48
silky
Ah right, so does the larger seal of the two go in the drivers longer shaft side ?
Posted 31st Mar 2009 at 15:06
willygti
yeh the larger one is on the side nearest the wheel. the smaller one fits into teh speedo housing
Team Ducati 748
Posted 31st Mar 2009 at 15:08
silky
Not sure what you mean there fella
Posted 31st Mar 2009 at 15:27
dave
think it means the large seal goes to the side with the shortest drive shaft and the smaller one goes on the longer side.
Posted 31st Mar 2009 at 15:57
silky
Does anyone know if the seals are different between the 6 box and the 5 speed XSI/HDI boxes ?
Posted 31st Mar 2009 at 16:14
Rich E Forum Admin
No, they are the same on pretty much all PSA cars.
Posted 31st Mar 2009 at 18:09
silky
So are the Part Numbers
312144 Pass Side
312146 Drivers Side
Posted 31st Mar 2009 at 17:31
silky
Do you have to take the long shaft out, then take the speedo housing off to get the seal in ?
Posted 31st Mar 2009 at 22:02
drew o
they changed the seals but the part number is the same but they change every 3 months back to fully rubber still have two sets if anyone wants a set
306 GTi-6™ In Moonstone FTWBig grin
Team Speedline Turini
PS3-Drew_o
Posted 1st Apr 2009 at 00:51
jimbamboon
Epic thread revival yes, but better than starting a new one. Had my driveshaft seals replaced by Carl G when he did my clutch, long and short of it, does this look in anyway right? I would say, ignore the oil on the seal as i think thats from a spillage by myself and i think a bit leaks from somewhere above, but the seal or dust cover seems to stick out a mile!
clicky code for my benefit
Posted 21st Jul 2011 at 15:42
