Author Subject: Removing Seats FAQ
Now this may seem glaringly obvious but from a prior thread it wasn't. So as I was breaking a car that weekend I said I'd add pictures to the directions/instructions the member had been given from others of how to remove seats
Tools needs:-
Torx 40 bit
13mm bit
10mm bit if also removing the carpet in the rear
Firstly, I would start with the rear seats although these are very simple to remove.
Firstly pull the seat squab upwards using the tab attached to the rear of the seat.
Once these are pulled up you will see these are hinged losely, just pull up and out. If removing the carpet as part of stripping for a track slag you will need to remove the 4 hinges with 10mm bolts holding them onto the vehicle.
Next fold down the rear seats using the release buttons on the top of the seat.
This exposes the fixing points into the chasis these are 13mm bolts.
Once the rear is removed it is time to move on to the fronts.
To remove these the outer runners of the seats are mounted to the side of the car and the inner runners on the floor pan.
Firstly push the seat fully forward to expose the two bolts within the runners.
Side mounted one:-
Floor mounted one:-
Once these have been removed, slide the seat fully back to expose the remaining two bolts.
Side mounted one:-
Floor mounted one:-
Please note that on the drivers site the bolt is not exposed as the seat cowling covers the bolt.
However a rachet fits under the cowling with a bit of gentle persuasion.
Now the seat is fully unbolted you can roll the seat back and can then unclip all the connectors and remove the seats.
Also note as late PBS/Phase 3, side airbag seats there is an additional connector, eitherway disconnect all these on your model.
If replacing then obviously fitting is the reverse of removal.
Not rockect science but still handy to have a FAQ.
Disclaimer any damage caused is not liable to myself. The vehicle this was undertaken in had the battery disconnected at the time as the drivers airbag was being removed.
Posted 10th Feb 2009 at 10:54
zedx19
Handy little FAQ, very easy job tbh but still good to have this for those unsure.
149bhp ATW stripped GTi-6 & B6 Passat TDi daily drive
HyperGTi-6.co.uk - Videos and PicturesHyper
Posted 10th Feb 2009 at 17:59
ksung17
cheers thugpugging like you said LOL
im going to start on mine now Big grin
Posted 10th Feb 2009 at 21:59
midlife
Nice JobThumbs up
What next Dunno
How to put air in the tyres FAQ
How to adjust rear view mirror FAQ
Whistle
Cool
Team 330™Cool
Team "no front end or engine"
Posted 10th Feb 2009 at 22:59
puglover Banned!
midlife wrote:
Nice JobThumbs up
What next Dunno
Whistle
Cool
LOL
Posted 10th Feb 2009 at 23:00
Can we have a 'How not to fall off the road in .0003mm of snow' FAQ?
midlife
We are on fire tonightLaugh my ass off
Cool
Team 330™Cool
Posted 10th Feb 2009 at 23:03
jesus has jon got a lob-on over that blaze six they broke or what?? LOL
Posted 10th Feb 2009 at 23:06
midlife
Rust envyWhistle
Cool
Team 330™Cool
Posted 10th Feb 2009 at 23:39
midlife wrote:
What next Dunno
I'll do a phase 2 keyfob battery change FAQ actually Laugh
Rikky not really but it does wake me up a bit more when I leave for work so maybe a slightly different morning glory.
I know it's crap as stated but it's helped one person then it was worth the 5 minutes it took.
Anyway I'll leave Nev to do the next one.
Posted 10th Feb 2009 at 23:55
This thread has been locked
