displaying posts 1 to 25 of 45
Author Subject: Custom shelf build
alcon
Just finished making my custom parcel shelf and this is how I did it, if anyone
alcon has attached the following image:
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 25th Jan 2009 at 23:28
alcon
2. Take your jigsaw and cut the shelf to shape.
1999 Rallye (black)
Posted 25th Jan 2009 at 23:35
alcon
3. With the shelf facing up the correct way, use the router and a
1999 Rallye (black)
alcon
4. Now turn the shelf upside down and round over the wiper motor cut out. All of this can be done with rough grit sandpaper if you don
1999 Rallye (black)
Posted 25th Jan 2009 at 23:36
alcon
5. Fit the shelf in the car to make sure it all fits ok, and close the tailgate to make sure there is no fouling. If there is or it
1999 Rallye (black)
alcon
6. Next, pull the two plastic hinge pins from the original shelf and keep handy.
1999 Rallye (black)
Posted 25th Jan 2009 at 23:37
alcon
7. Now take your piece of wood (I used a length of pine I had in my shed), cut it to the same length as the seat edge of the shelf and the clamp in place. Drill and screw it to the underside of the shelf as shown in the pics. Mark a line 30mm in from the edge and drill a 12mm hole centred on your line, in both ends of the shelf. The holes need to be at least the same depth as the length of the hinge pin. The holes should be drilled half in the MDF and half in the strip of would if you
1999 Rallye (black)
alcon
1999 Rallye (black)
Posted 25th Jan 2009 at 23:38
alcon
pic
1999 Rallye (black)
alcon
8. If you
1999 Rallye (black)
Posted 25th Jan 2009 at 23:39
alcon
pic
1999 Rallye (black)
alcon
9. Now decide where you want to mount your speakers and using the templates, draw on the underside of the shelf the positions, then cut them out with a jigsaw.
1999 Rallye (black)
alcon
pic
1999 Rallye (black)
alcon
10. Now is a good time to do final preparations to shelf before it gets covered. I used a small round-over bit to smooth all the hard edges but sandpaper will do the same job
1999 Rallye (black)
Posted 25th Jan 2009 at 23:40
alcon
11. Unscrew the strip of wood and stick a length of double sided tape to the TOP face (the top face is the side that gets screwed to the shelf if that makes sense). Peel off the backing and stick the edge of your cloth to it. Position the shelf upside down with the hinge edge closest to you. Screw the strip of wood back down which should now jam the cloth between the wooden strip and shelf. Wrap the cloth around the strip (conveniently covering the screws) and right round onto the top of the shelf (refer to pics to see what I
1999 Rallye (black)
alcon
pic
1999 Rallye (black)
alcon
pic
1999 Rallye (black)
Posted 25th Jan 2009 at 23:41
alcon
12. Reach for your stapler and start to tack it to the underside of the shelf. You need to pull the cloth taught as you do this to avoid any sags or wrinkles. Trim off any excess cloth and pay particular attention to trimming around the wiper motor cut out
1999 Rallye (black)
alcon
pic
1999 Rallye (black)
alcon
pic
1999 Rallye (black)
Posted 25th Jan 2009 at 23:42
alcon
13. You should now have a shelf that looks something like mine in the pic (or better!)
1999 Rallye (black)
alcon
14. Now to cover the underside of the shelf. I used spray on adhesive which I bought in Maplins for a few quid as it
1999 Rallye (black)
alcon
pic
1999 Rallye (black)
Posted 25th Jan 2009 at 23:43
alcon
pic
1999 Rallye (black)
Posted 25th Jan 2009 at 23:44
alcon
15. Gently tap/hammer the plastic hinge pins into the holes. I wrapped them with some leccy tape for a tight fit.
1999 Rallye (black)
