Author Subject: xsara VTS master cylinder
24seven
This the same as the 6 one? after a bigger one to go with the bigger brakes up front and have been offered one off a VTS, which I'll take if its the same.
Cheers.
Posted 12th Jan 2009 at 01:29
SteviePut
Would have thought it's the same as the 6 as they share the same brake set upSmile
Posted 12th Jan 2009 at 01:30
24seven
Definitely the same? I think I read somewhere that the VTS used the same calipers as the S16 but something tells me I'm making that up.
Posted 12th Jan 2009 at 01:37
SteviePut
My VTS had GTi-6 brakesWink
Check out GSF for part numbers etc, You'll see they match up
Posted 12th Jan 2009 at 01:41
mechanical_repairs
I have a gti 6 master cylinder you can have for
Posted 12th Jan 2009 at 01:50
24seven
with reservoir?
Posted 12th Jan 2009 at 01:52
mechanical_repairs
24seven wrote:
with reservoir?
You can swop that from yours mate, i dont have the res no sorry.
Carl
Posted 12th Jan 2009 at 03:16
24seven
ahh bugger. need a reservoir as well as mine is split near the cap.
Cheers anyways tho.
Posted 12th Jan 2009 at 03:24
c.a.r.
Cheers anyways tho.
Have a spare resevoir but this hasn't got the filter in the top of the filler neck.
Yours for the cost of postage as it was going in the bin...
'99 1.8 XS - Sold
'00 GTi6 - Killed by armco
'01 Cabriolet 1.8 - Sold
'96 Eunos Roadster 1.8 Import
Posted 12th Jan 2009 at 06:13
Welly Forum Admin
Read this
Vrs power!!
Posted 14th Jan 2009 at 05:13
jord294
sorry to hi-jack Blush
so am i right in thinking that the 283mm discs on the xsara vts will fit gti6 ? Unsure
Posted 30th Dec 2009 at 16:44
they are the same part number....
Posted 30th Dec 2009 at 16:58
vts_gav
xara vtsph1 and ph2 brakes are same. in the 2003 ph2.5 (bug eye with seperate fogs) calipers were changed and thicker front discs used....... the ones that brembos fit over correctly same as gti 180
Posted 30th Dec 2009 at 21:53
