displaying posts 701 to 725 of 1309
Pages (53): first .. 28 [29] 30 .. last
Author Subject: Daveyboy's Rallye Race car
Post #701
rich_w wrote:
I think the standard head chamber volumes are around 38cc in the head alone.
Jim - I wrote an Excel spread-sheet for calculating compression ratios on this engine for when I was building my engine [and others].
If you want I could pop over one eveing, could plug your figures in?
I may end up having to mill some material off the tops of the pistons to get the chamber volume back something like right.
Smile
Well if thats the case I need to find about 4-5 more ccs, and the head has'nt even been skimmed yet! Crazy
Posted 15th Apr 2010 at 15:53
bobdylan_55
Post #702
Smile
get the bowls worked is the best option as you dont really want to be machining them pistons or adding spacer plates. I surpose you could take a tiny bit off the top of the piston, but would probably wreck the squish area and design of them. just get the bowls opened up slightly.
309 GTi6-T
Posted 15th Apr 2010 at 16:23
Post #703
Smile
I don't think shaving a few mm off the tops of the pistons will make an awful lot of difference to the burn rate, they have a large rectangular flat section in the centre, I would just take some material from the top of that if necessary. First things first though, I've got to go over all the measurents again and make sure I have'nt gone drasticly wrong as thie figures are a long way from where the piston manufacturer says they should be.
Posted 15th Apr 2010 at 16:38
Post #704
37.5cc iirc sandy said, 36cc with a max skim of 0.25, more can be removed but its not sensible to do so as you get close to the valve seats.
1.2mm gasket as mentioned, repair gasket is 1.4mm.
Posted 15th Apr 2010 at 20:16
Post #705
I definitely don't want to remove anymore than is absolutely necessary from the head, I have a horrible feeling I'm going to have too much compression as it is...
Posted 15th Apr 2010 at 21:41
chris with a pug
Post #706
but think how quick it will be in the 10mins before it blows up LOLRazz
Posted 15th Apr 2010 at 21:46
Post #707
Are you talking about yours Chris? Razz
Posted 16th Apr 2010 at 01:20
Post #708
Update from Guy Croft today, my valve guides are made and inserted, work can now begin on valve seats and the valves themselves.
Here are some pics. (For some reason he thinks its an S16, but I have'nt had the heart to correct him!)
Starting to get excited about bolting this back together now...
Posted 6th May 2010 at 04:34
Post #709
Got my oil pump rebuild kit from Rich W yesterday too, so next week the block will be %100 finished. Good times Smile
Looks like I'm going to end up with a CR more like 13:1 but I'm told this won't be an issue as long as it's mapped very prescisely and I stick to high octane fuel.
Posted 6th May 2010 at 15:32
chris with a pug
Post #710
how much was the kit? what is in it?
Posted 6th May 2010 at 21:41
Post #711
No idea as I have'nt seen a bill yet, I got a piston, a gasket and a spring, plus a new drive chain.
Posted 7th May 2010 at 01:48
chris with a pug
Post #712
I had a spare gasket here!!!! dofus.
Posted 8th May 2010 at 01:58
Post #713
I still needed the piston and spring Razz
Posted 11th May 2010 at 01:53
chris with a pug
Post #714
they are pennies! the gasket about 8 quid
Posted 11th May 2010 at 01:58
Post #715
Well why did you buy two then? Crazy
Posted 11th May 2010 at 14:33
Post #716
39.6cc is the chamber volume I have ended up with, so it looks like I won't have a CR that is too mental after all, that's a relief! (Thats before skimming, but that won't change it by much)
Posted 12th May 2010 at 04:29
chris with a pug
Post #717
I got one in the gasket kit, but had already rebuilt the oil pump
Posted 11th May 2010 at 20:19
Post #718
Are we talking about that stainless shim type gasket?
Posted 11th May 2010 at 21:57
chris with a pug
Post #719
the one that goes in the middle of the pump yeah!
Posted 11th May 2010 at 21:59
Post #720
I'll check with you next time I order anything then Big grin
Posted 11th May 2010 at 22:00
chris with a pug
Post #721
I have doubles of most things!!
Posted 11th May 2010 at 22:01
Post #722
Including chins Shut up LOL
Posted 14th May 2010 at 02:09
Post #723
its had some material taken from the chamber then, 37.5 IIRC is standard, down to 36cc if skimmed 0.25mm, much more and you get rather close to the valve seats.
when is it all going together?
Posted 14th May 2010 at 02:31
ken
Post #724
love this build! Big grin
if anyone knows which i expect you all do lol!
abouve th epower steering tank, there is a breather pipe leading to the manifold and wires etc,
do i need them mate as i notced you removedd/relocated them!
just curious thankyou Big grin
Team Black Rallye Big grin
xbox live - Xx 7 kenny 7 xX
Posted 14th May 2010 at 03:16
Post #725
Yeah, by me, I de-burred it, got rid of anything sharp and gave the casting marks a little cleanup and de-coke. Guess a little material removal translates to a fair sized change in volume in a chamber that size.
Posted 14th May 2010 at 18:30
