displaying posts 51 to 75 of 256
Pages (11): first .. 2 [3] 4 .. last
Author Subject: Birks Supercharged Gti6
birk
Post #51
Well, i had the TB welded onto the charger this morning, finished off all the main bits of the setup and fired it up.
The outlet on the charger is just running a silicone hose for now, borrowd one off my mate just to get it running, will need changeing though, as it collapses at idle
I think the heads tapping and thers something wrong with the idle, i have a petrol leak, a water leak and a powersteering leak Sad
It sits at 2k, give it some revs and back on idle, it hunts, up and down, up and down.
Icv was fine before i started all this.
The leaks are easy fixed though, fuel pressure regulator has lost its clip i noticed, so think thats sorted when i find one, powersteering, i think it might have sorted itself out, but if not i know where the problem lays, bottom hose on the pump will be loose i reckon
water leak is from thermostat cover, the plastic bit, just get some instand gasket on ther Smile
I should feel great thats its atleast working, but i can help but feel shit Sad
[URL=http://s72.photobucket.com/albums/i162/birk69/?action=view
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 23rd Dec 2008 at 01:33
midlife
Post #52
Just spat my tea out all over my deskLaugh my ass off
Cool
Team 330™Cool
Team "no front end or engine"
Posted 23rd Dec 2008 at 02:24
birk
Post #53
thats erm... my sister Whistle LOL
07889376885
Dan
Posted 23rd Dec 2008 at 02:51
puglover Banned!
Post #54
think you might have the throttle cable to tight birk Wink
Posted 23rd Dec 2008 at 02:56
nafeun
Post #55
well played getting it started, did you hear the engine run before you put it in? (i.e. the tapping?)
No man remains quite what he was when he recognises himself and buys a 6 172 Cup RS Megane R26 DONK EDITION
Posted 23rd Dec 2008 at 02:58
birk
Post #56
Wouldnt that leave the throttle bodie open ? by the looks of it from the outside, i can see the plastic bit sits correctly at its resting point
Unfortunatly i didnt hear the engine running before, but it was from a respected member, so i fear it may have been me that might have fooked it up doing the cambelt, although the engine has been stood for a very long time, it might just sound rough, it did get quieter you see, guna see what its like after a good run
07889376885
Dan
Posted 23rd Dec 2008 at 03:01
djinuk
Post #57
hunting would usally mean to me there is a vacume leak somwhere, check your inlet manifold gasket, and check any hoses etc after the afm.. sorry im not 100% sure on these engines, only just learning but speaking from past experiance here.. and hunting is usally air leaks aswell as high idling, failing that could it not be a sensor?
Posted 23rd Dec 2008 at 03:22
birk
Post #58
Yea, i was thinking the same aswell.
Im guna be checking over the vac system, maybe replacing the pipes, i have some braided hose in the right size iirc
Then if things dont improve, will be looking at the inlet manifold ptfe gasket, and also the icv and the various sensors ive had to extend
07889376885
Dan
Posted 23rd Dec 2008 at 03:34
puglover Banned!
Post #59
did you use gasket compound on all the throttle body work?
Posted 23rd Dec 2008 at 03:35
birk
Post #60
used some sealant on the heater blanking plate, has a normal paper gasket, havent used anything where the reducer plate is, should i have used some ther like ?
07889376885
Dan
Posted 23rd Dec 2008 at 03:39
birk
Post #61
bollox, just re-read the guide, does indeed say sealant must be used on all TB components LOL
07889376885
Dan
Posted 23rd Dec 2008 at 03:45
puglover Banned!
Post #62
does your pipe work route round ok then?? im guessing there is no room for the likes of an oil cooler rad or any other rad at all at the front then??
Posted 23rd Dec 2008 at 03:47
birk
Post #63
Ive had to remove the washer bottle and its bracket, but other than that, it goes round ok, the pipe sits hard against the chassis leg and is very close to the belt, but its not going to touch, i need to wedge the front pipe or pull it forward somemore to get it to clear, havent figured how im going to do that though.
I shall be messing with the battery tray to house the new washer bottle setup, and also to hold the ecu properly, then i will have space for a catch tank behind, maybe incorporated in the box, the manifold cooler pipe is going to be in the way, but i shall trim the box down to suit, be easy large enough for a washer bottle, will just have to get one fabricated to fit inside Smile
07889376885
Dan
Posted 23rd Dec 2008 at 03:54
djinuk
Post #64
trick i learnt was to buy a can of "easy start" or similar, and give all inlet manifolds etc a quirt around the joints, whilst the engine is running, if there is a air leak you should hear it suck it in , and the revs will raise, not sure how possible that will though due to the hunting.
Posted 23rd Dec 2008 at 12:28
fletch
Track Head
Post #65
Yes
Agreed, Carb spray or similar helps identify leaks easy
Posted 23rd Dec 2008 at 13:11
jib
Post #66
Quick update for everyone.
Birk has now got his car on the road with the charging running.
Few idling issues but is running sweet apart from that.
My god does it shift Cool
Posted 25th Dec 2008 at 03:18
birk
Post #67
Yes it is indeed on the road and running
The old TB heater pipe is the problem to the bad idle i think, i noticed it was a bit loose and has an odd size pipe conecting it to the TB bit, so will be having a look at that 2moz
The rad is a bit old and tired aswell, it has a small leak on the bottom bit where the hose goes in, but im not sure if thats just because it hasnt sealed right, also another thing to look at
Smile
07889376885
Dan
Posted 25th Dec 2008 at 05:14
jib
Post #68
Just a short vid i got of birk's car tonight:
Posted 26th Dec 2008 at 04:00
mabgti
NV motors
Post #69
forkin helll is the right wordBig grin
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 26th Dec 2008 at 04:09
midlife
Post #70
x 2 Ninja
Cool
Team 330™Cool
Posted 26th Dec 2008 at 04:49
mabgti
NV motors
Post #71
more vids pleaseBig grin
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 26th Dec 2008 at 05:10
john gordon
Post #72
Is it me or can i hear a boost leak in that vid?
FORD PUMA: the gay car that will have the 6 in the twisties.
Posted 26th Dec 2008 at 05:19
puglover Banned!
Post #73
nah hes bouncing of the limiter LOL
Posted 26th Dec 2008 at 05:20
birk
Post #74
Could be the wheelspin
I knew some one would say that puglover LOL
Probly the first time ive set off hard in it, so it wheelspan a bit and hit limiter Smile
07889376885
Dan
Posted 26th Dec 2008 at 05:22
john gordon
Post #75
goes like stink. top job.
Posted 26th Dec 2008 at 05:23
