Author Subject: Squeeling Brembos
zac
Finally fitted my new brake setup, and they're awesome. However, I thought that with the Xantia discs they wouldn't squeel?
I've not applied any copper grease to the backs of the pads, would this help prevent squeel?
If I've got to accept it then so be it, but if I could get rid I'd be grateful for any advice! Laugh
They're coupled to Mintex M1144 pads BTW.
Hit the limiter in 6th gear at 169mph (GPS - TomTom on the German autobahn). Still pulling like a train too. Cheers
- Phase 3 GTi-6 (409hp 'charged weekend toy)
- Phase 2.5 Rallye (daily driver)
R.I.P Pete Sims
Posted 10th Sep 2008 at 13:54
chris with a pug
It seems to be pot luck, daveyboy runs and identical set up and they squeek like hell, he tried copper slip and some other stuff, which helped for a bit but now they squeek.
If you can solve this you will be a very popular person
Posted 10th Sep 2008 at 14:27
rallyestyle
Copper Slip should be used yep but as said it's unlikely to stop the squeeling completely No
Have a chat to Mike (Cosmic Spanner) and Carl (Mech repairs) as i believed they have both used some special liquid Whistle to good effect Yes Thumbs up
Just Drive It
Posted 10th Sep 2008 at 14:37
mugen_power
Clicky Thumbs up
rikky wrote:
there are no pictures of breasts or meatwallets anywhere so it is bringing nothing to the table, so to speak
Posted 10th Sep 2008 at 15:35
phippsy
Somebody help him...please! Razz
Posted 22nd Sep 2008 at 04:08
dan_s16
Am I the only one whose Brembos don't squeel?
They very very rarly let out the odd squeek when braking very lightly but no more than than the standard ones did and just pushing on the pedal a little firmer shuts them up.
I've never done anything special to them either, just copper slip on the backs of the pads. DS2500 pads and I think Tarox G88 discs.
Posted 22nd Sep 2008 at 05:34
E-mail Mintex and mention your 1144's are squeeling like bugger and do that have any recommendations to stop it - they'll normally send you some rubber shims out.
Posted 22nd Sep 2008 at 04:47
lotek
JESUS CHRIST ...HOW BLOODY LOUD IS THE SQUEEL!!!!!!!
Laugh my ass off
and i have the TRW pads with a rubber backing on them !! LMAO!!!
Posted 7th Nov 2009 at 01:04
pgti6
I've heard that Kent Brake Pad Silencer P/N 50160 is meant to work effectively.
"Brake Pad silencer has been formulated to prevent and cure brake noise generated from the friction material on the brake pad such as squeal. This noise is generated by air trapped in the pits and voids on the face of the pad, being expelled during braking. BT72 soaks into the pad and fills these voids, ensuring that the problem is removed. It is totally unique in the market, all other systems using greases to the back of the brake pad to try and disguise the noise. Applications are on all vehicles with brake discs."
It's what I intend to try when I fit my Brembos to the 405 track car (as soon as I can find lightweight 15" rims to suit).
N5 XU10J4RS Road car
D60 XU9J4 Track car 120Kw atw
Posted 7th Nov 2009 at 07:40
lotek
its stopped now! it only does it when you press lightsly and for a long time : Cool
Posted 7th Nov 2009 at 17:49
vts_gav
anyone tried fitting a 406 master cylinder..... more pistons to move more fluid to move std one might not do it quick enough or something?
Posted 19th Nov 2009 at 01:43
chas
Are the Brembos anything like the old Porsche/Ferrari Brembos with stainless steel plates where the backing plates touch at the top and bottom of the caliper? If so, check to see if there is plate lift there. If there is, it will need to be sorted or your brakes will forever be squealing.
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 19th Nov 2009 at 02:57
craigyboy. Banned!
somebody sovle this pleeeeeeeeeeeeeeeeese!
Posted 19th Nov 2009 at 06:10
lukejenks101
the kent stuff didn't stop mine, have applied it 4 times now, has anyone tried genuine pads from peugeot?
Im using ds2500 pads and brembo oe discs
PS3 I.D - jenkers101
Live i.d - Lukejenks1201
Posted 19th Nov 2009 at 14:11
anderoo
Yes
Mine had a load of corrosion behind them. I couldn't get the screws undone to get them off but managed to prise them up enough to file them flat behind.
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 19th Nov 2009 at 14:21
russbez
guess its pot luck... i would try it but no paying
My Rallye project thread
Posted 19th Nov 2009 at 14:24
lukejenks101
anderoo wrote:
Yes
did this stop them squealing?
Posted 19th Nov 2009 at 14:48
anderoo
Mine haven't ever squealed so far but I have the 330mm kit from ash, cleaned the corrosion and filed the plates so the pads moved easily and used mintex cera tec instead of copper slip.
Pics of my 6
Posted 19th Nov 2009 at 15:27
