displaying posts 526 to 550 of 608
Pages (25): first .. 21 [22] 23 .. last
Author Subject: Project Rallye!
Carl Chambers
Post #526
Brakes will stay as the are for now, the calipers and discs etc are all brand new so may as well use them!
As said this is just a stepping stone to get used to racing then hope to move up to the touring car which has all the good bits on anyway!
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 5th Jan 2012 at 22:10
Carl Chambers
Post #527
engine bay all done and extingiser nozzle fitted;
pull cable fitted;
battery and extingiser mounted and plumbed in;
battery cover made and fitted;
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Jan 2012 at 09:28
Post #528
any plans for the gearshift? standard stick just looks wrong in there now LOL
Posted 8th Jan 2012 at 09:53
Carl Chambers
Post #529
no leaving that as it is, as said this is just a car to go racing and learn in, not to go out and win!
car is all finished now with the seat etc in so had the car wieghed today and was totally amazed!
I was hoping for just under 1000kgs but bettered that by miles!
Turns out its 30kg lighter than my 205 was! though that still had the Power steering etc still on it!
so total wieght is............. 870kgs!!!!!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 8th Jan 2012 at 17:30
steve954
Post #530
870kgShock
stevie
09 308 gt140 cc
03 octavia vrs
IF IT AIN'T BROKE, IT AIN'T A GTI6
Posted 8th Jan 2012 at 17:33
atterz
Post #531
Fecking hell, Rallyes can really be lightweight then! What would need to be removed to get it just under 1000kg?
owain wrote:
Posted 8th Jan 2012 at 18:46
steve954
Post #532
read back through!! this has nothing in it!
most wiring removed
new engine mounts
no pas pump or pipes
metal cut away
if it isn't needed it hasn't got itLOL
stevie
09 308 gt140 cc
03 octavia vrs
Posted 8th Jan 2012 at 18:58
atterz
Post #533
Ive read the whole thread mate, its just the 50kg that Rallyes are lighter than 6s as standard isnt that much but this thing is as light/lighter than a 205!
And just curious what a sensible strip down to get it around a ton was, without making it a completley dedicated track car.
Posted 8th Jan 2012 at 19:01
Post #534
Need to have a better read through this then as need to get rid of some more weight in mine.
I need to loose about another 40kg from mine.
870kg though is a fantastic effort! Clapping
Posted 9th Jan 2012 at 11:42
Post #535
its not lighter than a proper 205, Colin satchell's hillclimber was under 700 kilos with an iron block 2.2 iirc.
Posted 9th Jan 2012 at 11:45
atterz
Post #536
Given! Lighter than a Standard 205 is bloody impressive though!
Posted 9th Jan 2012 at 18:02
roberts_306
Post #537
Too right ^ my next step is to get mine the same, already started on it
www.pugsport-racing.co.uk
Posted 9th Jan 2012 at 18:05
Post #538
Can you post up pictures and weights of what you remove?
Need to find more things to remove from mine Smile
Posted 9th Jan 2012 at 18:07
roberts_306
Post #539
Yeah sure will, so far Horn and both front fans and surround have gone. ABS will go next. I will get all weights and post them on my project page
Posted 9th Jan 2012 at 18:13
atterz
Post #540
Cheers for the above mate!
Posted 9th Jan 2012 at 18:17
Carl Chambers
Post #541
You need to remove a lot of stuff to get down to that weight!
But to give you some ideas,
rear wiper motor is just over 1kg
seatbelts are about the same each
cooling fans are 1.5kgs
o/s alternator/pas/engine mount is 8.5 kgs
sound deadening behind the dash is 7.5 kgs
there is about 3-4kgs of sound deadening stuck to the floor!
carpets are a good 7-8kgs at least
But then you get carried away, every bracket that not used has been cut off no matter how small it looks, extra buls have all gone, the wiring harness weighs a ton!
you just have to decide what you want the car for and what you really need in it!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 9th Jan 2012 at 21:04
Carl Chambers
Post #542
picture of my seat and harness fitted;
and my carbon fibre 306 Maxi door cards;
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 9th Jan 2012 at 21:24
judge dead
Post #543
nice m8 get that door arm rest carbon fibre wrapped Smile
Posted 9th Jan 2012 at 21:28
Carl Chambers
Post #544
And some weights for you, all done on a proper MOT test brake roller which weigh the car to work out the braking efficiency so is fully calibrated every few months to ensure it is correct!
all weights are with me sitting in the car, I weigh 75kgs so you have to take that weight off the figure shown
my standard 205 1.9 GTI with factory sunroof, 914.4kgs with my weight taken off
my 205 GTI with full interior and factory sunroof with MI16 engine and gearbox, 936.3kgs
my 205 GTI stripped and omp roll cage, with 306 GTi-6 engine and gearbox, 911.7kgs
and lastly my 306 Rallye with nothing in! yet still has standard glass still in! 868.3kgs
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 9th Jan 2012 at 21:38
Post #545
Its for a weekend toy/track car and have already got rid of most things on your list. Currently weighs 1040kg with heavy half cage. That will go this year for a proper cage so will gain weight there. Aim to get as close to a ton as possible without spending lots of money Smile
Posted 9th Jan 2012 at 21:46
roberts_306
Post #546
Get rid of the ABS and wiring, plastic windows, light weight alloys 15's
Posted 9th Jan 2012 at 21:51
Post #547
Don't want to clog up Carl's thread, post your ideas in my project thread (link in sig)
Got rid of most of the obvious/easy things Smile
Posted 9th Jan 2012 at 21:53
atterz
Post #548
Where did you get them door cards from mate? Clear the door Bars nicely Big grin.
Posted 9th Jan 2012 at 21:58
Carl Chambers
Post #549
I have had the door cards since the start of this project a few years ago and only now got round to fitting them! They came from Italy and were bloody expensive!!
as Dave says light weight wheels is another thing to look at, the BTCC wheels on this are 5 kgs a wheel lighter than the standard cyclones so thats 20kgs saving there alone!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 9th Jan 2012 at 22:07
roberts_306
Post #550
Good luck with finding some tho, took me ages
Posted 9th Jan 2012 at 22:45
