displaying posts 1 to 25 of 37
Author Subject: rear brake bias compensator
24seven
Can someone take a picture of one for me please? just found the actuator rattling on mine with the compensator seized in the fully on position (ie fully compensating for extra weight). I think there's a spring missing from around the actuator, but would like a picture of a working setup to compare, if possible.
Cheers.
Posted 17th Jul 2008 at 01:26
midlife
Cool
Team 330™Cool
Team "no front end or engine"
Posted 17th Jul 2008 at 02:00
24seven
hmm. looks exactly as mine did. I unseized it and took the actuator off completely, because there was nothing returning it to the off position, and as it goes over bumps it would only end up being sat on full anyway.
there's a big spring pushing the valve into the fuly on position, and a smaller spring pulling it the same way, but I can't see anythin to move it to the off position when the back of the car is unloaded.
Posted 17th Jul 2008 at 02:12
midlife
Its the nut on the end of the shaft at the rhs that moves it to "the off position"
Cool
Team 330™Cool
Posted 17th Jul 2008 at 02:15
24seven
wouldn't it make sense for that nut to be against the other side of the arm when the spring is fully decompressed then? Mine was fully decompressed, with the suspension sitting high (the back of my car seems to ride unusually high for some reason) and it was rattling around, not operating at all.
Posted 17th Jul 2008 at 02:20
not entirely sure how it works but I think hydraulic pressure with the valve unloaded makes it close.
Posted 17th Jul 2008 at 02:46
24seven
hmm. that could be it. either way with the spring and rod assembly completely removed from my car the thing handles and drives so much better! For the first time I'm able to feel the passive rear steering of the car, I need less steering input to go round corners than I used to, the car accelerates quicker and the brakes at the front at least) feel more responsive. I wonder if it being stuck on was causing my rear brakes to bind slightly. perhaps now that it's unseized from the fully on position it'll stay like that if I refit the rod/spring gizmos. will try that tomorrow.
Posted 17th Jul 2008 at 06:10
chris with a pug
is your car lowered?
If it is you should remove a coil or two big spring to compensate
Posted 24th Jul 2008 at 16:53
i was just about to mention that lowering may alter the brake bias to back wheels but you beat me to it
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th Jul 2008 at 14:58
cwspellowe
Mega revival
Erm, just went to free up my compensator and the main rod thing that goes through it appears to be completely missing, just the flappy springy bit there.
I should be concerned, shouldn't i?
Bye bye Sundance Kid Sad
Posted 24th Jun 2011 at 02:09
yarp LOL
Posted 24th Jun 2011 at 02:24
cwspellowe
Crap, where the f*ck could it be?!
Thought it was a bit weird it loosened up easily and went all flappy, couldn't figure out how it was supposed to work Ninja
Posted 24th Jun 2011 at 02:25
cwspellowe
Erm, spot the difference?
I don't see what anything's supposed to be attached to though?
Posted 24th Jun 2011 at 02:46
LOL meant to be a bracket on the lower damper bolt.
best get down a scrappy and find a bracket springy thing and rod Thumbs up
Posted 24th Jun 2011 at 02:49
cwspellowe
Ahh ya f*cker. Do all 306's have them, even ones with drums?
What's it doing at the minute then? It was seized solid and i worked it free, have I just sent all the bias to the rear now?
EDIT I have also deduced from picture evidence that it appears to have been missing since at least November last year. Could that explain why the brakes have felt shit for a while despite several bleeds?
Posted 24th Jun 2011 at 03:00
drum cars with ABS have them, and most with discs.
Posted 24th Jun 2011 at 03:03
Lecktorious
aka G.
306 Meridan in UPI Chris, from memory it's a TU.
'98 Nile Blue 306 GTi 6
Posted 24th Jun 2011 at 03:27
No rod = Less/no rear brakes.
Posted 24th Jun 2011 at 12:27
Mate that's pretty funny Yes
Posted 24th Jun 2011 at 13:06
blondie
Dirty Diesel Pro
Yep non abs drum models have them tooWink
A 306 EnthusiastWink
phillipm wrote:
But diesel is the devils fuel Devil
Ps3 IDRazzhils306
“S-H-I-T-H-O-L-E.. Shithole!”
Posted 25th Jun 2011 at 04:11
naah, they have inbuilt pressure limiters in the rear wheel cylinders.
Posted 25th Jun 2011 at 04:14
^^What he said.
No pesky feckin' compensators on mine.
Posted 25th Jun 2011 at 04:29
cwspellowe
Hmm would explain why the rear brakes have seized up then, lots of rusty patches on the rear discs.
Best get a new rod (snigger) to poke (snigger) the rear brakes into life
Posted 25th Jun 2011 at 05:00
smegal
I hope that you have better luck with yours than I did mine. I ended up with a new one as it was the only way I could get my rear brakes to show on an MOT machine.
Ex SC-6
Now in a Megane R26
Posted 25th Jun 2011 at 22:00
pinkfloyd
Any idea if the rod can be left off on a lowered car. I was wondering if I could lock the compensator into a position that would suit track use?
Liverpool Motor Club Sprint champion 2017
Longton & District Motor Club Sprint champion 2017
Liverpool Motor Club Sprint champion 2016
Liverpool Motor Club Sprint champion 2015
Lancashire & Cheshire Speed Championship
Winner 2014
2nd 2013
Winner 2012
2nd 2011
Winner 2010
Winner 2009
Winner 2008
Winner 2007
2nd 2006.
Posted 5th Nov 2011 at 07:22
