displaying posts 51 to 65 of 65
Pages (3): 1 2 [3]
Author Subject: Maxi Rallying
Post #51
if its a Peugeot box you need to use Peugeot spec oil, i,e 75w80, not the oil recommended for the diff as it doesn't work very well at all with pug internals.
Posted 16th Jan 2009 at 01:42
martinj
Post #52
....well, a change of oil to Kaaz oil - welshpug thanks for the reply but when I spoke to the guy who fitted the diff in the original box, that is what he put in it and it was spot on in the box, both for the diff and the box itself - and in this one, normal service has returned with the diff. It no long sounds like a tarmac spec impreza wrc on lock and I am now relaxed about the gearbox swap as everything seems spot on.
Next on the list is the ceramic coated exhaust manifold, just want to take some temperature readings of the standard one first to see how much difference it makes swapping to the cermic coated one....oh yes, and find a bit of time to swap over the new evolution rear axle with its hub spacers....
Martin
- Maxi rear axle hub spacers +53mm per side
- Maxi front steering rack extensions +40mm per side
Posted 18th Jan 2009 at 01:47
bono
Post #53
martinj wrote:
Hi,
Just thought I would put up an update, things have been a bit quiet with the car lately for many reasons, and I think next year's rally activity may be a bit sparse due to an extension on the house - but we'll have to see....
I have now picked up the spare set of axle spacers for the rear beam from the engineering shop and they have confirmed that they will be able to make further sets (min of 2 axle sets per run) for
///M5
Posted 25th Mar 2009 at 15:56
birk
Post #54
Brings them down to pug offset so he can fit pug wheels with offset 16mm
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 25th Mar 2009 at 16:00
bono
Post #55
ah ok, how can i go about getting these steering rack extensions?
I have two, but one is a little bent Sad
///M5
Posted 25th Mar 2009 at 16:01
martinj
Post #56
Hi Bono,
I am just waiting on a quote from the engineers and then will be able to give you a price for the steering rack extensions.
As per Dan's reply above, the rear spacers allow the use of standard peugeot ETs, I run a 7x17 with an ET18.
Martin
Posted 25th Mar 2009 at 17:45
martinj
Post #57
Have had a call back from the engineering company today with a figure of
Posted 27th Mar 2009 at 15:51
puglover Banned!
Post #58
me and wayne possibly. Ill take 2 sets if they are only
Posted 29th Mar 2009 at 21:02
martinj
Post #59
The rack extensions are being made by the engineering company, have asked them to make seven sets based on response.
If you would like a set(s) please can you add your name to the maxi/dimma rack extension for sale thread and I will make sure you are kept up to date on the progress when I get it from the engineering company.
Thanks,
Martin
Posted 30th Mar 2009 at 22:38
jonnie205
Post #60
have you got a xsara vts rack on the car martin?
Posted 4th Apr 2009 at 16:58
martinj
Post #61
Hi Jonnie,
No, just the standard 306 rallye item.
Martin
Posted 5th Apr 2009 at 00:16
martinj
Post #62
Hi,
Quick update, the engineer's have taken a bit longer than hoped but I have now received the rack extensions.
Martin
martinj has attached the following image:
Posted 24th May 2009 at 19:36
puglover Banned!
Post #63
cool, can i still take a set or 2??
Posted 24th May 2009 at 19:31
martinj
Post #64
Hi John,
Not a problem, do you want two sets? I will work out the cost of postage to you.
Martin
Posted 24th May 2009 at 19:37
puglover Banned!
Post #65
ill just take one set actually abit skint. Ill pm you and sort out payment, cheers martin
Posted 24th May 2009 at 19:45
Pages (3): 1 2 [3]
