displaying posts 176 to 200 of 379
Pages (16): first .. 7 [8] 9 .. last
Author Subject: 205 gti 6
bonzo
Post #176
Love That really does look awesome Carl, you obviously take great pride in your work.
Ninja Black Rallye Ninja
Posted 20th Nov 2008 at 16:37
mechanical_repairs
Post #177
bakes100 wrote:
Carl, thats looking superb, tempting me to whip mine out and paint the bay..hmmmmm Big grin
You tilting the master cylinder? Also is that a standard bottom mount bush I can spot in the photos?
It is a standard mount at the minute i am going to replace it though as it is suppose to give problems otherwise.
Thanks for all the good comments, it has taken a while to do it to this standard but i hope once it is finished it will all be worth it.
Not done a great deal to it since i had it running, going to remove the rear mount housing and press in the aftermarket bush then just sort the exhaust out are go from there, i seem to be having a few issues mounting and routing the coolant pipes around the back of the block, it all seems to run too close to the manifold and i need to find the coolant hoses i need.
Carl
Posted 20th Nov 2008 at 16:45
bakes100
Post #178
I found if you use a 306 Xsi distro block on the back of the block you then block off one of the outlets, you can then connect the expansion tank to the metal pipe that runs along the back of the block, this mean you only have one hose near the manifold which is the one for the heater matrix, then run the other heater matrix pipe into the back of the thermostat housing, this is how mine is set up and have no temperature problems whatsoever. I put an 'S' shaped hose coming out of the distro block which moves the standard heater matrix hose away from the manifold.
With a slightly lower theromostat mine runs about 5 degrees cooler than the standard gti6.
Hope that makes some kind of sence! Smile
Also I would say one of BBM's bottom bushes or similar is a must have as its all rather tight.
205 GTi-6 = 179.2 Bhp @ 6650Rpm - SOLD
Seat Leon Cupra R 225
Posted 20th Nov 2008 at 16:55
mechanical_repairs
Post #179
Done a little more to it today, managed to fit the rest of the exhaust to the car including a cat so it will run just as it intended like in the 306's, had to fit a cat pipe from the 306 and mate it to the original cat off of the 205, i can tell you it looks a work of art.
Also fitted the linkage to the subframe and fitted one linkage the larger of the two, not to sure on which one is used for the short one as a standard 306 one seems to small, anyone help on that small matter?
Other than perfecting the wiring loom on sat/sun and fitting all the last bits in i think its about there.
Things to finish-
Perfecting the wiring loom (hopefully this weekend)
Fit the missing linkage unsure which it is? LOL
Plumb in the coolant hoses
Fit stiffer rear engine mounting
fit o/s drive shaft
Fill gearbox with oil
Fit the rest of the car back together, front bumper and trim, then it is going home to hibernate till next summer.
I may have missed something.
Carl
Posted 30th Nov 2008 at 16:31
gti6girl
Post #180
the gear change uses standard 205 linkages.
Posted 22nd Nov 2008 at 01:06
mechanical_repairs
Post #181
Thanks for that, thought i must have been doing something wrong.
Carl Crazy
Posted 22nd Nov 2008 at 01:11
gti6girl
Post #182
Did you extend the arm on the gearbox? (not the selector the other)
Posted 22nd Nov 2008 at 01:17
gtisid
Post #183
does all the battery gubbins fit in the hole carl?, cant see why it wouldnt.
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 22nd Nov 2008 at 22:36
taylorspug
Post #184
Standard of work is very impressive, reminds me when i built my original MI engined car a few years ago!
Just a word of caution with the master cylinder clearance. When i originally dropped my engine in I had similar clearance to you, however once on the road the engine settled and the master cylinder touched that tapped lug on the cam cover. So much so in fact the engine was pushing the master cylinder in and dragging the brakes on. This was using a full set of BBM solid mounts. You may get lucky but its likely you will have to reangle the master cylinder and/or chop that lug off the cam cover.
205 GTI6- Ledas, Tran-X diff, billet 4 pots, big bar rear beam, Jenveys and Emerald.
Black P2 306 Gti6- Lowered, PTS rear spoiler- the daily hack!
Posted 25th Nov 2008 at 06:34
pugjim
Post #185
If your still using the selector arm circled in the picture you might have problems fitting the 205 linkages. Best to change that for one off the original 205 box.
Posted 25th Nov 2008 at 15:40
alastairh
Post #186
Mine was exactly the same.
Al
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 26th Nov 2008 at 00:55
mechanical_repairs
Post #187
Thought that gearbox looked similerLOL
Yes i have ordered the new selector arm from peugeot, the one needed is a straight arm with the fitting for the linkage underneath.
Carl
Posted 26th Nov 2008 at 01:49
Post #188
lol, im sure i painted the end part thats bolted on the end of the box in silver hammerite not long ago, well its not painted now, just looks like it did before, hehe , that powder coating would be safe though i would of thought. i didnt think the gearbox would get hot enough to make the paint go walkies!!
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th Nov 2008 at 03:18
gti6girl
Post #189
its not powder coat Wink
Posted 26th Nov 2008 at 22:20
Post #190
It doesn't if it's painted right Razz LOL
Posted 26th Nov 2008 at 22:23
mechanical_repairs
Post #191
Wahoo, my loom works, plugged it in and turned the key first position.......we have ignition.......turn the key and she fired up!!!
Well impressed, just got to put the rest of it back together then sort the rev counter out, someone said about removing a diode, anyone have any more details for me?
Thanks, Carl
Posted 30th Nov 2008 at 14:52
idboo
Post #192
Drop pugjim a PM mate, he's got all the info and pics of sorting the rev counter out, he's done a couple of them now.
HTH.
Posted 30th Nov 2008 at 16:30
Post #193
lol that hammerite brush paint i used i bought in about 1997!! i found it when cleaning the garage out was unopened!
Posted 30th Nov 2008 at 16:53
smighall
Smeg-all
Post #194
Thanks, Carl
The way i did it was to solder a wire from the input pin on the board to pin 1 on the chip.
Meh
Posted 30th Nov 2008 at 17:28
mechanical_repairs
Post #195
Thanks, Carl
Thanks mate i will have a goosy and see if it does the trick, at the minute i have no rev counter at all, should that be the case and when your mod is done it will come to life?
Carl
Posted 30th Nov 2008 at 21:30
smighall
Smeg-all
Post #196
Mine did and i got that off the 205 site a couple of years ago. Mine seemed to work fine, but i'm not sure if it's the "proper" way of doing so to speak.
Meh
Posted 30th Nov 2008 at 22:16
Post #197
Are you going to use the old '6' heat shield to stop the heater pipes melting or do you have a plan?
Posted 30th Nov 2008 at 23:04
stue306
Scarface Pilot
Post #198
ill make sure i have a nosey at it when i pick the paxo upWink and also try and blag a go in the s/c rallyeWhistle
R.I.P pete,see you at the crossroadsWink
so i dont forgetWhistle [url =copyandpastelink]type a clicky title[/url]LOL
p2 gti-6, scooby wagon'restoration project'
Posted 30th Nov 2008 at 23:25
Post #199
1N4004 rectifier diode, 1 per coil.
1N4744 Zener diode
1Watt, 1Kohm resistor.
Image shows for wasted spark single Amplifier setup, add another 2 for the gti6 setup as its sequential.
just hook them up to the coilpack triggers next to the ECU and connect the feed wire to wire 112 (tacho)
saves taking the dash apart.
Posted 30th Nov 2008 at 23:32
mechanical_repairs
Post #200
Thanks for the help lads.
The car is not finished yet regard's the heater hoses etc. I am sure i will think of something.
Carl
Posted 30th Nov 2008 at 23:36
