displaying posts 126 to 150 of 379
Pages (16): first .. 5 [6] 7 .. last
Author Subject: 205 gti 6
mechanical_repairs
Post #126
Got back on to this again today,
Started by putting the suspension back together, using a few bits that are not meant for the 205 so i am keeping it quiet at the minute untill i know its going to work, coimplete new top mount kit and new springs putting all together with new shocks-
Was a real arse to do as they are a little special but once fitted to the car look good and seem to clear ok, looking spankly too-
Then i started to slowly put all the bits back from where they origianally came from, most of the bits removed have been powder coated so look like new, even went to the local fixing's shop and got new nuts and bolts LOL-
Come to a bit of a stand still again as i forgot to get the servo powder coated and cant do much more untill this is refitted.
Carl
Posted 27th Oct 2008 at 21:04
garry
Post #127
Awesome build Carl.
You may want to get a different header tank cap, the spring on the 205 cap is quite weak compared to the 306 one.
205 GTI6 S
Posted 27th Oct 2008 at 23:42
Carl Chambers
Post #128
garry wrote:
Awesome build Carl.
Yeah I have found that to, but it is only on track that it was a problem, on the road it never pushed the water out!
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 27th Oct 2008 at 23:51
mechanical_repairs
Post #129
garry wrote:
Awesome build Carl.
I have heard that, i will use the one from the Nissens radiator as it looks just the same.
Your car still going strong? What radiator did you use just the standard 205 one?
Glad i have the 1.6 205 so i can look at it and see where bits go, was a while since i stripped it.
Carl
Posted 27th Oct 2008 at 23:55
mangledmetal
Post #130
i had a std but new 309 oone on my sixed goodwood without any issues at all fella!
Going through the gates of Hell Backwards, in a ball of flames!
I'll, save you a place!!
Posted 28th Oct 2008 at 00:00
Carl Chambers
Post #131
Mine just got a standard 205 1.9 GTI alloy nissans one, on track the water never get hot even being out there for 30mins its the oil that gets hot and mines got a proper oil cooler!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 28th Oct 2008 at 00:06
mechanical_repairs
Post #132
Thanks for the replies, just hoping when the engine goes in the exhaust will clear the bulk head, i have re angled the manifold but there seems to be a few horror stories out there regarding this.
Some people alter the lower mount, i want to avoid this if i can.
Carl
Posted 28th Oct 2008 at 00:29
psjunkie
Post #133
saw the car on sat looks a beauty Thumbs up
was a bit gutted when ya turned up in the old derv wanted a ride in the charged Devil
1997 P1 Gti 6 Charged
Posted 28th Oct 2008 at 01:22
Carl Chambers
Post #134
Carl
Yeah I have heard that if its angled too much it will hit the gear linkage!
I cut and re-shaped my bulkhead, but mines just a track car now so it didnt matter!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 28th Oct 2008 at 13:43
rallyeash
Post #135
my mounts are in the standard possition, there isnt much clearance but theres enough for it not to touch with a 6 manifold
309 3dr K20 Type R
Posted 28th Oct 2008 at 15:42
garry
Post #136
Carl
I used to run a nissens rad before the charger, the car always got hot but I have since found the headbolts were not very tight and the gasket was failing.
I use a radtec rad now to allow the boost pipes over the top. Very nice bit of kit, but quite expensive though.
As you have the engine out I would suggest you get a bronze linkage bush from Miles (same design as the 306). It fits in the 'L' shaped bracket that goes on top of the sub frame.
I used to find the securing bolt used to work loose when giving it some stick resulting in a sloppy gear change.
I don't think you will be able to get the securing bolt out with the manifold fitted due to the limited clearance.
205 GTI6 S
Posted 28th Oct 2008 at 15:44
captaink
Post #137
I have a standard 205 1.9 GTi radiator on my 205 GTi6. Never really gets hot enough at all - to be honest it runs cooler than my original 1.9 engine.
When I got home last night, my G/F demanded that I take her somewhere expensive - so, I took her to a petrol station.
1993 L reg 205 with GTi6 engine and GTi6 brakes
1995 M reg FTO GPX manual
Posted 28th Oct 2008 at 18:36
mechanical_repairs
Post #138
Well on saturday i received the final bits i needed back from the powder coaters (it's a desease) so hopefully this will be finished pretty soon.
Had a pair of hub carriers painted black-
Fitted the wheel bearings, trying not to damage the paint-
The servo came back looking great in anthracite, much better than the rusty crap it looked like before.
Ordered the last few bits i need so i am hoping by the end of the week to have a six lump sitting in the bay looking very pretty.
I have my fingers crossed that the master cylinder will clear and that i have no issues with the exhaust manifold. Time will tell.
The calipers i have had powder coated too-
Brakes all built back up and fitted, painted the centre of the disc's, once the car has been driven it will remove the over spray and will leave a nice coated centre that wont look horrible when the metal corrodes-
This is what it is looking like now-
Carl
Posted 10th Nov 2008 at 23:22
Carl Chambers
Post #139
Carl
Its getting there, I like all the nice shiney paint bits, but you missed painting the brake master cylinderWhistle
Get the paint out or better still get a new oneRazz
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 10th Nov 2008 at 22:53
mechanical_repairs
Post #140
quote:
quote:
Carl
A new one is on order, thought the six one would fit but forgot that was for abs so does'nt fit, doh, that was was painted and looked mint LOL
Posted 10th Nov 2008 at 23:13
fletch
Track Head
Post #141
Looking a lot tidier than last time I saw it Carl, engine bay looks good Yes
Do you do a powdercoating service? I have some calipers that I could do with powder coating...
Posted 10th Nov 2008 at 23:36
mechanical_repairs
Post #142
I dont personally but if you send them to me stripped down i will get them done for you, or you could buy a set from me already done with the rear sliders to matchUnsure
Carl
Posted 10th Nov 2008 at 23:59
Post #143
noticed you had fitted rubber brake lines, why? also, you'll need longer than standard ones, PM Miles for some 205-gti6 fit ones Wink
Posted 11th Nov 2008 at 00:26
mechanical_repairs
Post #144
I dont quite get the point, all of them are fitted with flexi hoses?
I have fitted longer ones and they are fully fitted and are fine. What do you mean, have you any pictures?
Carl
Posted 11th Nov 2008 at 00:32
Post #145
just wondering why you are going to the effort of all this shiny stuff, then not using braided lines.
didn't know there were any suitable o.e type lines, AFAIK there aren't any of the right fitment for a 205.
Posted 11th Nov 2008 at 00:41
alastairh
Post #146
Carl
Wise advice. Mine use to rattel its self loose on my old 205'6 and 205 S16.
Looking good though Smile
205 GTI6
Primera GT
Xsara VTS
306 GTI6
Posted 11th Nov 2008 at 01:09
Carl Chambers
Post #147
I just have standard 306 GTi6 ones on my 205 with gti6 brakes! They fit perfectly!Crazy
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 11th Nov 2008 at 15:01
sacko_gti6
Post #148
looks Love
Build Date - 30 September 1997 - Tuesday's car..is full of pace? Wink
Posted 11th Nov 2008 at 15:04
jonnyvandijk
Post #149
The calipers looks great, wish I could get mine finished to that standard!
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
Posted 11th Nov 2008 at 18:30
silky
Post #150
How much do all these things cost to powdercoat (roughly) ?
Posted 11th Nov 2008 at 19:40
