displaying posts 326 to 350 of 542
Pages (22): first .. 13 [14] 15 .. last
Author Subject: My 306 Gti6 Throttle Boddies Race Car
Post #326
roberts_306 wrote:
Yeah that sounds good, what kind of price?
Also the car has a full magnex and no cat so not sure if that would make much difference.
With those cams you have do you know how much work is involved and what kind of power would you get with Throttle Bodies?
I did'nt realise this at first when I offered you the cams but they won't be any good to you unless you can find a set of solid lifters, they are pretty mild too, similar to a PT 81 I believe so if you go to the trouble of rebuilding the head fitting solid followers etc. you would probably want to fit something a bit more lairy, of course that means pocketed pistons...
As for the map, I was thinking £80. I just need to power up my ECU and link it to a laptop to retrieve the MAP. As far as exhaust spec thats pretty close as I was running a Scorpion with decat at the time too. Max RPM was 7,200 which was where it was mapped to as well.
Posted 15th Jun 2010 at 03:53
roberts_306
Post #327
I went over to Carls @ Leicester today and brought a set of 306 BTCC magnesium wheels which I have been searching for ages now.
www.pugsport-racing.co.uk
Posted 11th Jul 2010 at 00:45
Carl Chambers
Post #328
Angry I was suppose to have them but Carl never answered my messages!
they look good aswell!
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
Posted 11th Jul 2010 at 01:27
roberts_306
Post #329
Major update - Carl Chambers has been hard at work.
New OMP steering wheel fitted
Jenvey Manifold fitted onto engine
Jenvey 45's fitted onto Manfold
With the proper airbox the washer bottle neck was in the way as you can see in the picture below
So Carl came up with this to replace the washer bottle
Oil catch tank fitted with breather
Bonnet cut to allow space for the airbox - do people think I should cut the rest of the bonnet?
Thanks to Carl for all the hard work Wink
Posted 13th Jul 2010 at 02:09
roberts_306
Post #330
Front shot of airbox
Posted 13th Jul 2010 at 02:13
cwspellowe
Post #331
This is gonna sound really naive but.. is the airbox the right way round? Dunno
Bye bye Sundance Kid Sad
Posted 13th Jul 2010 at 05:56
Carl Chambers
Post #332
because the throttle bodies Dave bought should have been for a Vauxhall! I was going to turn it around but then the screws to release the cover would be on the underside and impossible to get to once the rad goes in!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 13th Jul 2010 at 14:10
Post #333
Decent airfeed through the wing there anyway. Not so bad to move the PAS and sort the washer bottle. Looks really good guys!
If you do cut the bonnet, let me know how much weight you take out Wink
Posted 13th Jul 2010 at 14:58
Post #334
if you cut the whole bonnet apart like i did with mine you can expect it to weigh 7kg tops with pins Yes flimsy though, and needs 4 pins minimum
Posted 13th Jul 2010 at 15:06
roberts_306
Post #335
I have decided the bonnet would look better if cut out leaving the bracing like Carl did
Posted 13th Jul 2010 at 16:13
Post #336
What do they normally weigh?
Posted 13th Jul 2010 at 16:52
cwspellowe
Post #337
Ah ok Thumbs up
Where'd the mani come from? You buy it separately from Jenvey or make your own?
Posted 13th Jul 2010 at 17:46
roberts_306
Post #338
The manifold came direct from Jenvey, the throttle bodies I purchased from ebay (they were new but set up for a Vauxhall Manifold hence why they would not bolt directly on)
Carl soon sorted this out
Posted 13th Jul 2010 at 19:17
Carl Chambers
Post #339
the pas bottle is now a washer bottle if you look closely, the washer pump is on the bottom pipe and top pipe is blank off. Daves car was already running electric pas from a 106 from when it was supercharged!
original washer bottle removed and cold air feed will come up through where it was direct from the o/s fog light hole.
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 14th Jul 2010 at 02:13
Carl Chambers
Post #340
i cut my bonnet like this;
not sure of its weight but its light enough to only need 1 bonnet strut to lift it and still nice and strong around the edges, so does not flap or need bonnet pins
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 14th Jul 2010 at 02:28
Post #341
btcc rep = weight is your enemy
washer bottle is a pain in the arse, i relocated mine inside
Posted 14th Jul 2010 at 02:34
roberts_306
Post #342
More update from Carl Chambers
I said to him I think it would be better to cut the other side to match the side he has already cut, which he has done I was going to get him to cut all metal like he did to his but its risky not to wreck the paint and stickers on the bonnet
Primed
Throttle Cable bracket from a 205 GTi
New fuel pipes connected to fuel rail, just need Jenvey to send the fuel housing holder
Omex loom before any work (this has ford plugs fitted as it was purchased second hand)
Here is the standard loom before it chopped into
I hope we have some good luck with the wiring then we need to get a map sorted and then a quick tune on a rolling road to set the Throttle Bodies up
Posted 14th Jul 2010 at 03:11
roberts_306
Post #343
More update
Standard wiring loom chopped
This is the bit off the standard wiring loom that is not needed
Here is a wiring hell as described by GKZ_206 lol
Progress is finally being made so it does not seem far away before hopefully the engine can be started, good work Carl
Posted 15th Jul 2010 at 02:45
rallyeash
Post #344
good job! although you can run the ford coilpack...
309 3dr K20 Type R
Posted 15th Jul 2010 at 20:51
Carl Chambers
Post #345
it will be running on the ford coilpack!Smile
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 16th Jul 2010 at 01:41
jammamayhew Banned!
Post #346
roberts_306 wrote:
Never seen a car with its guts handing out like this beforeLOL
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 16th Jul 2010 at 01:46
rallyeash
Post #347
ah cool, for some reason i thought it was going to be using a 8v tu coilpack.
309 3dr K20 Type R
Posted 16th Jul 2010 at 13:42
roberts_306
Post #348
Update
Plug leads fitted
Coil Pack and Leads
Cover cut to allow plug leads
Fuel Pressure Regulator Housing with GTi6 fuel regulator
Omex 600 mounted under dash
Posted 25th Jul 2010 at 23:22
spiky
Post #349
I would strongly advise moving that ecu, it will get very very hot there
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 25th Jul 2010 at 23:43
Post #350
+1, with or without heat shields.
Posted 26th Jul 2010 at 02:37
