Author Subject: Fitting throttle position sensor and coolant sensor
davenegus
Hi again guys, ive ordered the two above parts and plan to fit them at weekend
Are they both simply take off and replace affairs or is there more to it ? If they are as easy as changing the MAP sensor was then id be happy =P
dave
Posted 28th May 2008 at 05:00
fletch
Track Head
Take off and replace affairs Yes Very straightforward.
Posted 28th May 2008 at 05:03
khj100
TPS is just 2 (or maybe 3) little torx screws. Easy peasy.
The only issue with the CTS is finding a spanner big enough to fit it. When you remove it, just be aware you may introduce an air pocket in the thermostat housing so might want to bleed the coolant... Probably not necessary though.
Posted 28th May 2008 at 05:19
smighall
Smeg-all
TPS is 2 torx screws (T20 IIRC)
And CTS is a 19mm spanner Wink
Meh
Posted 28th May 2008 at 05:43
davenegus
just ordered new stepper motor as figure might as well replace that if taking it apart to clean it, least that way i can rule it out once done, gonna be most of my saturday gone no doubt but hopefully worth it =P
Posted 28th May 2008 at 05:47
khj100
You're obviously feeling flush if you've ordered all that from Peugeot!
Posted 28th May 2008 at 14:55
davenegus
hehe no from online automotive mainly =P
Posted 28th May 2008 at 14:58
163wed
hello guys, i have a little problem...
i have a peugeot 306 gt-6 16v 2.0, 1998, 163cp, and now im looking to replace the TPS sensor.
can you tell me where is this sensor located?
thank you very much.
Posted 25th Jul 2010 at 00:09
vernam616
Under the throttle body, the throttle body will need to come off, it takes longer to remove everything than actually swap the bloody thing !
Audi S3 Black Edition
Posted 25th Jul 2010 at 02:39
163wed
@vernam616: thank you for both of your replies. My trouble starts when in the RPM meter varies from 900 to 700 rpm, and at a point, my engine stops. This is very stressed situation, stoping the car at junctions, stops the engine too.
Reading the posts in here, i managed to say that the TPS sensor can cause this. On the throtle body, i have 2 electrical couples, one in front between throtle body and radiator, and one in the back of the throtle, between the throtle body and driver.
Which one is for the TPS sensor? I rather test it unplugged before changing anything.
Excuse my english, im from Romania, and i didn`t wrote nothing in english for 5-6 years already.
Posted 25th Jul 2010 at 15:52
vernam616
You have to take the air feed, to the throttle body off and slide your hand between the throttle body and coolant pipe, its acutally on the bottom of the throttle body, should be a 3 pin plug
Posted 25th Jul 2010 at 17:36
163wed
ok, found it, disconnected it, but still no change.
same problem persists.
any other solutions? Smile
Posted 25th Jul 2010 at 17:41
vernam616
Your problem sounds more like a broken/dirty idle control valve
situated on the inlet manifold close to the throttle body, there is a FAQ on how to remove, quite easy really, 2 10mm bolts, remove small air pipe, pull it out, disconnect multiplug, remove the 2 phillips screws to release the sensor from its housing then clean the inside and tip of the sensor with carb cleaner/WD-40 (i find carb cleaner works better though)
Posted 25th Jul 2010 at 21:19
163wed
Ok, last night, i cleaned up the idle valve and the map sensor, but still no changes. Actually, there was a little improvement, but not 100% repaired.
I also have a question, the motor of idle valve, is it ok not to move that axe with bare hands? Or it should move with the hand? Mine is not moving with the hand at all.
Thank you.
Posted 26th Jul 2010 at 14:53
vernam616
Thank you.
More than likely broken then, hence why you dont see much difference when cleaning
Posted 27th Jul 2010 at 02:35
163wed
damn.
that valve costs over than 150 euros in Romania.
good for me, i still have to buy it if i want to drive in peace.
vernam, thanks for your help again.
another thing that bothers me is the dashboard, the lights are out, doesn`t light, i checked the fuses and they are all ok, any sugestions?
Posted 27th Jul 2010 at 14:30
vernam616
If your on about the lights behind the heater controls... then these are known for failing, many people dont bother changing as they can be a bas**rd to get to
Try banging the dash with the lights turned on to see if you can get any of them working
Posted 28th Jul 2010 at 21:51
CUJ
Just change the bulbs on the heater control panel, costs pence and these bulbs do have a habit of blowing, as I can confirm.
340 horses
Posted 28th Jul 2010 at 21:58
163wed
ok, thanks for the help of both of you.
now to refraze this problem, none of my lights, dash and other doesn`t work / light. just the headlights and the tail lights working, with the signal lights and backward lights. Smile
Posted 30th Jul 2010 at 00:16
sixysix
Probably a blown fuse then Smile
Take a look
Posted 31st Jul 2010 at 02:55
