Author Subject: Stopping the interior fan?
winno
I've done a search and looked in the FAQ section but still don't know the answer.
Anyway, how can I stop the interior fan from working when the control is set to the "off" position?
In this position it still blows air and the air con still works.
When I switch it to off, I'd actually like it to be off.
Any ideas anyone?
Can the existing switch be modified?
What about adding an additional switch somewhere?
Thanks for the help.
'99 306Gti
Posted 31st Mar 2008 at 10:17
dan_s16
The fan runs all the time to keep the fan speed controller (in the bottom of the fan unit) cool as it only turns off with the ignition.
I haven't really looked into it but you could possible switch the relay that supplies power to the fan controller which would then turn off the motor but i'm not sure if it would damage the a/c controller (like I said i've not looked in to it much).
Posted 31st Mar 2008 at 14:52
stupotgti6
i have the same problem(fan staying on all the time).
i changed the heater controls and still the fan is on all the time.
please help
99 GTI-6 (china blue) SOLD
03 ASTRA TURBO CONVERTIBLE
84 ROVER SD1 VP EFi (3.9 V8)
01 AUDI S4 AVANT
Posted 1st Apr 2008 at 20:18
ted
they stay on all the time as standard
Monkey see monkey do
Posted 1st Apr 2008 at 21:35
winno
Any other ideas people?
'99 306Gti
Posted 9th Apr 2008 at 12:17
scottie
Mine doesn't stay onUnsure
Cars dont get older, they just get lower!!
Posted 10th Apr 2008 at 01:05
Yours won't stay on all the time, because you have a Rallye with the non-Aircon setup. Yes
Only air-con equipped cars will have this scenario. Wink
Stan.
Posted 16th Apr 2008 at 03:45
winno
But in turning off the motor wouldn't the need for the fan controler be negated?
I'm looking to add the relay as you stated but have the trigger off the ignition wire intead of off the acc.
There are three wires to the blower assembly - two thick (12V and earth) and another thinner wire. What's this thinner wire for?
'99 306Gti
Posted 22nd Jun 2010 at 17:32
brochloon
Stan.
I have a Rallye non AC set-up on my 6 (aircon pump removed) so is there anyway I can install a switch somewhere to turn the fan off? Or maybe wire it up to the AC button? AS obviously my AC button doesn't do anything anyway
PH3 Cherry 6
Posted 22nd Jun 2010 at 23:10
