I will PM you quotes for work as requested above.
Regards,
Contact Details:rich@lynxpowerengineering.co.uk
07732 822546
| Author | Subject: Billet Steel Flywheels [Light weight] |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
Post #276
Guys,I will PM you quotes for work as requested above. Regards, Rich ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
rich_w
Post #277
Friday morning bump ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
rich_w
Post #278
BTT ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
schumi
Newbie Location: Istanbul Registered: 13 Aug 2010 Posts: 36 Status: Offline |
Post #279
I think it is not possible install on 206gti180 with stock BE4R gearbox. Am I right ?________________________________________ 2005 - 206 RC/GTI180 Red |
rich_w
Post #280
schumi wrote: I think it is not possible install on 206gti180 with stock BE4R gearbox. Am I right ? Hi, Yes, unfortunately it won't fit that engine / gearbox. Regards, Rich ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
Disco_Stu
Regular Location: County Durham Registered: 09 Aug 2008 Posts: 243 Status: Offline |
Post #281
rich_w wrote: gti-dan wrote: How much for both flywheel and pulley? Do u need to swap cambelt if changing crank pulley? Hi, I can do both for £310 delivered. No need to touch the timing belt when changing the pulley as Mike said. Let me know if you would like to order. Cheers Rich ![]() Hi, Is this price still correct? If so can I order them - how do you want paying? Quick question about the starter motor, can you use the standard one or do you need a different model (seem to remember this being mentioned sometime ago, but can't remember now) Stuart ________________________________________ Peugeot 306 Gti-6 Track car (soon to be supercharged)Project page Blog |
rich_w
Post #282
Disco_Stu wrote: rich_w wrote: gti-dan wrote: How much for both flywheel and pulley? Do u need to swap cambelt if changing crank pulley? Hi, I can do both for £310 delivered. No need to touch the timing belt when changing the pulley as Mike said. Let me know if you would like to order. Cheers Rich ![]() Hi, Is this price still correct? If so can I order them - how do you want paying? Quick question about the starter motor, can you use the standard one or do you need a different model (seem to remember this being mentioned sometime ago, but can't remember now) Stuart Stuart, I will send you a PM. Thanks, Rich ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
rich_w
Post #283
Chaps,Unfortunately the supplier for these flywheels have increased their prices, due increased material and engineering costs. With immediate effect, the revised cost is £258 delivered i.e. an £18 price increase Please note, this is still substantially cheaper than Demon Tweeks who sell the same product for £340 delivered!! Thanks, Rich ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
paul_13
Senior User Location: Reading Registered: 10 Dec 2008 Posts: 693 Status: Offline |
Post #284
Can you hold one for me for the next few weeks please. Will definately have one as engine is being put back together.Does your flywheel come with the bolts to hold the pressure plate on? ________________________________________ 205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit.![]() Private work, not a prob |
beez_neez_gt
Post #285
Yes they do Paul but you will need to drill the pressure plate holes bigger to 8mm so they fit. I used a hoover to suck up the shreds when drilling etc. Dont file them else they wont be a very tight fitting.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
sergioiacobucci
Senior User Location: High Wycombe Registered: 27 Nov 2007 Posts: 526 Status: Offline |
Post #286
Whats the cost of fitting one of these?________________________________________ Phase 1 silver track car335i daily |
Post #287
beez_neez_gt wrote: Yes they do Paul but you will need to drill the pressure plate holes bigger to 8mm so they fit. I used a hoover to suck up the shreds when drilling etc. Dont file them else they wont be a very tight fitting. The dowels do the location, not the bolt shanks. It's a lot more likely to go on easy without crossed threads if you drill at say 8.2mm and put a nice chamfer on the holes with a countersink. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
paul_13
Post #288
We got away with filing a mates one before mate.Didn't touch dowel holes just bolt holes. As Davey boy says the dowels do the location not the bolts. Reason I ask about the pressure plate bolts is because a mate on here, his lightened flywheel did not come with these and I don't have the time to be arsing around trying to get some ________________________________________ 205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit.![]() Private work, not a prob |
masekwm
Junior User Location: Dunstable Registered: 25 Aug 2008 Posts: 61 Status: Offline |
Post #289
Mine came with them Paul, perhaps the other didn't come from Rich? |
paul_13
Post #290
Ok, cheers. The other one was off RichW ________________________________________ 205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit.![]() Private work, not a prob |
Post #291
paul_xiii wrote: Ok, cheers. The other one was off RichW He might have just forgot to supply them then, just make sure to ask for them when you place your order. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
beez_neez_gt
Post #292
daveyboy wrote: beez_neez_gt wrote: Yes they do Paul but you will need to drill the pressure plate holes bigger to 8mm so they fit. I used a hoover to suck up the shreds when drilling etc. Dont file them else they wont be a very tight fitting. The dowels do the location, not the bolt shanks. It's a lot more likely to go on easy without crossed threads if you drill at say 8.2mm and put a nice chamfer on the holes with a countersink. It never had any countersunk holes originally and i drilled mine 8mm and they fitted perfectly, any larger and there could be movement on the pressure plate. I had trouble trying to locate the plate onto the dowels, it was very stiff. Because of this all the bolts had to be screwed in till the plate was on the surface all the way round equally. Once this is done i then used thread lock and torqued them all up in a triangle fashion. My clutch is the mi16 Helix race clutch type. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
monty-69
Senior User Location: Colne Registered: 02 Jul 2006 Posts: 792 Status: Offline |
Post #293
Mine arrived in the post faster than the Americans left Pearl harbour, looks a top notch product, thanks rich |
rich_w
Post #294
monty-69 wrote: Mine arrived in the post faster than the Americans left Pearl harbour, looks a top notch product, thanks rich Glad it turned up OK ![]() Just to let you all know, there's two flywheels left from the current batch, it's then likely to be circa 6 weeks until the next batch is ready. Rich ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
aphyx
Regular Location: Castle Cary Registered: 26 Feb 2010 Posts: 403 Status: Offline |
Post #295
Received and fitted today.Top job! ________________________________________ Onward to the Edge! |
rich_w
Post #296
aphyx wrote: Received and fitted today. Top job! Glad you got it OK ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
rich_w
Post #297
Chaps,I should have a new batch of these ready around the end of next week (26th August). Please PM me with your orders. Thanks, Rich ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
rich_w
Post #298
The new batch of these is now ready for delivery ![]() Please contact me if you're interested. Thanks, Rich ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
shadows entity
Regular Location: Dover Registered: 08 Dec 2010 Posts: 101 Status: Offline |
Post #299
Don't suppose you can make them for a d turbo or are they the same size/fitment? |
daytime6
Regular Location: devizes Registered: 20 Jul 2011 Posts: 146 Status: Offline |
Post #300
are these flywheels a direct fit to the old one as thinking of getting one myself ? |
